Static host list and serial number
  • 1.  Static host list and serial number
    Posted Mar 10, 2019 09:03 AM
    Hello ,
    for PXE boot , for new machines , its a challenge for a normal user to know the mac address without havingOS image .
    Can we do Static host list on basis of serial number , so if user called IT and give serial number , IT can allow or customize Static host list or any other related attribute , so that the user gets the image ?
  • 2.  RE: Static host list and serial number
    Posted Mar 10, 2019 09:36 AM
    No. Static Host Lists are for IPs or MAC addresses.
  • 3.  RE: Static host list and serial number
    Posted Mar 10, 2019 09:58 AM
    Can we use authorization as sccm and query to serial number ? Assuming IT has added serial number in sccm
  • 4.  RE: Static host list and serial number
    Posted Mar 10, 2019 10:27 AM
    If the MAC address is populated in SCCM, sure.
  • 5.  RE: Static host list and serial number
    Posted Mar 10, 2019 10:58 AM
    I am looking for something other than Mac address as authorization from sccm which user can easily tell the IT guy like serial number , user name etc .and then based on it ,it opens MAB for the user to download the image .
    Basically I am looking for some easy sort of authorization for end user having a new machine .
    We are a large entity and no prior info is available with IT which is centralized at a remote location .
  • 6.  RE: Static host list and serial number
    Posted Mar 10, 2019 11:01 AM
    The MAC address is the only thing presented to the network during a MAC authorization and is thus required.
  • 7.  RE: Static host list and serial number
    Posted Mar 10, 2019 11:08 AM
    Hi Tim ,
    We have predefined pxe ports and we will allow all mac address for those but we need a precheck before allowing mab
  • 8.  RE: Static host list and serial number
    Posted Mar 10, 2019 11:15 AM
    You still need the MAC address. It is the only identifier available.
  • 9.  RE: Static host list and serial number
    MVP EXPERT
    Posted Mar 10, 2019 03:13 PM
    An option could be to use the endpoint database with a custom attribute instead of using static hostlists. So you get a single-points of resource. But you still need the mac-adresses of your clients that you want have a "tagged" attribute.
