Static RAP inner IP address, multiple controllers
  • 1.  Static RAP inner IP address, multiple controllers
    Posted Dec 20, 2016 08:42 PM
    Is there any way to support a separate static inner IP address for a RAP using 2 different controllers?
    I can specifiy a static inner IP on the RAP whitelist on the master controller, but I assume this means it would use the same address no matter what controller it connects to.
    We can configure a RAP VPN pool with different addressing on each controller but we would like to use static IP addressing for monitoring purposes.
  • 2.  RE: Static RAP inner IP address, multiple controllers
    Posted Dec 20, 2016 08:50 PM
    Even if the RAP could maintain the same nonroutable IP address, how would you tell the infrastructure that the same nonroutable IP address resides on one controller vs. another?
  • 3.  RE: Static RAP inner IP address, multiple controllers
    Posted Dec 20, 2016 08:53 PM
    I should clarify - we would like to be able to specify a different static inner-ip address for a given AP on 2 different local controllers.
    From the GUI it looks like you can only specific a single static inner-ip in the RAP whitelist?
  • 4.  RE: Static RAP inner IP address, multiple controllers
    Correct.
