Static route to allow WiFi users to access service on internal network
  • 1.  Static route to allow WiFi users to access service on internal network
    Posted Nov 19, 2014 10:25 PM
    Hi all,
    My company uses AP105s with virtual controller assigned IPs.
    Users can access secure mail on their wireless device via cellular Internet service.
    The mail service is Natted 65.x.x.x to 208.x.x.x. on the external router
    When users connect to the AP105's WiFi on the internal network, they cannot access
    the mail service. So I take it a NAT loopback is not allowed on the external router?
    Can I create a static route on the AP105s to resolve this?
    I've attached simple diagram to illustrate.
    Thanks!
  • 2.  RE: Static route to allow WiFi users to access service on internal network
    Posted Nov 19, 2014 10:46 PM
    Are your clients resolving the 65.x.x.x IP for the mail server rather than the 208.x.x.x address?  If so, you could setup a rule on your user role that will destination NAT your requests to the internal IP (208.x.x.x) rather than the resolvable external 65.x.x.x.
    The following shows all traffic for the host destination NAT'd; but you could get more granular.
  • 3.  RE: Static route to allow WiFi users to access service on internal network
    Posted Nov 20, 2014 01:20 PM
    Clembo,
    Thank you very, very much for the reply.
    What you said and illustrated is exactly what I need to do, but I don't see any
    option on the AP105s to do so.
    The rules only have  Allow/Deny a service to a server or network.
    I don't see any that allow a re-route/redirect.
    Your illustration looks more advanced that what I have when I go to the rules.
    I've attached a pic showing an example of what I see.
    I'm on OS 6.1.2.3-2.0.0.3_31389.
    Do I need an OS upgrade to get those redirect options perhaps?
  • 4.  RE: Static route to allow WiFi users to access service on internal network
    Posted Nov 20, 2014 04:26 PM
    You'll need to upgrade to a newer Instant OS.   I don't know what version introduced those features.
  • 5.  RE: Static route to allow WiFi users to access service on internal network
    Posted Nov 20, 2014 05:18 PM
    Clembo,
    OK, I will upgrade and respond back.
    Thanks!
  • 6.  RE: Static route to allow WiFi users to access service on internal network
    Posted Dec 01, 2014 03:40 PM
    Clembo,
    The IOS devices can access the server internally now. Our vendor worked with us.
    It was still a good idea to upgrade the OS though and I did so.
    I added appropriate allow/port rules and it's working now.
    Thanks!
