Statss of data protocols
  • 1.  Statss of data protocols
    Posted Nov 21, 2020 09:33 PM
    Hi.
    I'm wondering if it is possible to see a breakdown of the protocols being used by my wireless clients. For example, I'd like see what percentage of traffic is broadcast, mulitcast, etc.
    I have IAPs (8.6.0.2) as well as AirWave. Is there a way to see this sort of data?
    Thanks.
  • 2.  RE: Statss of data protocols
    Posted Nov 24, 2020 05:06 PM
    yes you can get that info from both Instant APs and Airwave.
    from instant APs, you need to go to the Instant VC dashboard select anyone of the APs in the cluster and then click on the AppRF
  • 3.  RE: Statss of data protocols
    Posted Nov 24, 2020 08:58 PM
    Thanks for responding ariyap. That information is at an application level (i.e. Web traffic, messaging traffic, etc), I'm looking for something that will show broadcasts, multicasts, etc.
    Matthew Collins
  • 4.  RE: Statss of data protocols
    Posted Nov 25, 2020 02:24 AM
    i think bcast counters are under radio stats that can be viewed in AW.
