Status: Down (No radio cards found in device)
  • 1.  Status: Down (No radio cards found in device)
    Posted Oct 06, 2017 06:43 PM
    Anyone know why an autonomous Cisco AP1262 unit running 15.3(3)JD4 IOS image would be reported as:
    We know this is incorrect as we have users associated and using the AP's without issue. SNMP communities are correct as well. We're running AMP 8.2.4.1
    Thanks!
  • 2.  RE: Status: Down (No radio cards found in device)
    Posted Oct 07, 2017 03:51 AM
    Is this the only Cisco device you have configured?  Did Airwave discover it as a Cisco WLAN AP?
  • 3.  RE: Status: Down (No radio cards found in device)
    Posted Oct 16, 2017 12:25 PM
    Sorry for the delayed response, definitely not the only Cisco wireless product that is modeled. We have multiple sites, multiple WLC's and about 80 LWAPP's and a dozen or more autonomous AP's that show correctly. The issue is specifically with the autonomous AP1262 units. (We're running 15.3(3)JD4 on them FWIW.)
    Any ideas on how to get these to report correctly?
