Sticky Clients
This thread has been viewed 24 times
  • 1.  Sticky Clients
    Posted Aug 16, 2013 07:09 PM
    I have a 3200 controller running 6.1.3.8 and it looks like devices are hanging on for long periods of time based on the number of clients connect to it.  If I reboot the controller  will it release all of the clients?
    #3200
  • 2.  RE: Sticky Clients
    Posted Aug 16, 2013 07:20 PM
    Do you mean the devices are sticking to an AP and not roaming or devices
    aren't aging out of the user table when they deassociate from the network?
  • 3.  RE: Sticky Clients
    Posted Aug 16, 2013 07:29 PM
  • 4.  RE: Sticky Clients
    Posted Aug 16, 2013 07:46 PM
    You can clear the user table without reloading the controller by issue the
    command "aaa user delete all"
  • 5.  RE: Sticky Clients
    Posted Aug 16, 2013 07:56 PM
    Thank you.  That did the trick "for now".  This install is in a hotel and I am also wondering it I am running out of IP address.  Currently the controller is running DHCP.
  • 6.  RE: Sticky Clients
    Posted Aug 16, 2013 08:01 PM
    Also check your user idle timeout. It defaults to 5 minutes.
    Configuration > Security > Authentication > Advanced
  • 7.  RE: Sticky Clients
    Posted Aug 16, 2013 08:32 PM
    Currently it is set to:
  • 8.  RE: Sticky Clients
    Posted Aug 16, 2013 08:36 PM
    That's a long time. That means it could be up to 4 hours after your client leaves the network that they are cleared out of the user table. You may want to try and lower it to 1800 seconds (30 mins).
