Sticky Ipod Touch
  • 1.  Sticky Ipod Touch
    Posted Mar 05, 2015 09:57 AM
    We have 3 IAP 205's in a cluster. It seems the Ipod touches in our environment don't want to roam to a different ap until the signal strength is to low. Can anybody recommend the proper settings for Client Match in Aruba Central to force the switch sooner rather than later.
    Mark
  • 2.  RE: Sticky Ipod Touch
    Posted Mar 05, 2015 11:41 AM
    do you have a local probe threshold set?
  • 3.  RE: Sticky Ipod Touch
    Posted Mar 05, 2015 11:44 AM
    I do not.
  • 4.  RE: Sticky Ipod Touch
    Posted Mar 05, 2015 09:08 PM
    What's your AP transmit power set to in arm? Should be using min 12 max 18 for most situations.
