Stop across vlan airprint
  • 1.  Stop across vlan airprint
    Posted Mar 17, 2020 07:14 AM
    We have several wireless locations and every location has it own dchp scope on different vlan. All ap's are managed from a MM with 2 MC setup as a cluster using OS8.4.0.2_70086.
    We use all sorts of wireless communication on our locations, therefore we made rule in managed network, stating everything allowed (see attached file).
    But i did'nt expect, to see airprinters showing up across all vland. I now need to find that single rule, that stops airprinter, from showing up across all my locations.
  • 2.  RE: Stop across vlan airprint
    Posted Mar 17, 2020 10:07 AM
    You need to make sure to set Airgroup to disable.
    https://www.arubanetworks.com/techdocs/ArubaOS_86_Web_Help/Content/arubaos-solutions/airgroup/conf-airg.htm
      Airgroup gives you the ability to propagate Airprint devices across VLANs, but it has an undesired effect in your situation.
  • 3.  RE: Stop across vlan airprint
    Posted Mar 20, 2020 07:45 AM
    I will test your suggestion, when i can get back to work onside again. Tnx.
