Stop IOS from updating
  • 1.  Stop IOS from updating
    Posted Mar 02, 2016 01:24 PM
    I am trying to stop users on IOS devices from getting the update message on their devices. I have seen posts in the past that show if you setup a destination file with names mesu.apple.com and appldnld.apple.com, add it to an acl and apply it to a user role it would stop it from happening. We are running 6.3.1.14. So far that scenario doesn't work. I know in 6.4 you can use DPI but we are not ready to upgrade to 6.4 yet. Has anybody gotten this scenario to work?
  • 2.  RE: Stop IOS from updating
    Posted Mar 02, 2016 01:26 PM
    What controller are you using ?
    Do you have DNS query enabled on your controller ?
  • 3.  RE: Stop IOS from updating
    Posted Mar 02, 2016 01:40 PM
    Spoiler
    Using 7210 and 7240 controllers.Not sure about the DNS Querybeing enabled
  • 4.  RE: Stop IOS from updating
    Posted Mar 02, 2016 03:10 PM
    Try to ping something aruba.brightcloud.com from the controller CLI and see if it works.
    If not you will need to execute this from CLI and it requires a reboot to take effect:
    ip domain lookup
    ip domain-name .
    ip name-server
    Victor Fabian
    Lead Mobility Engineer
    ACMX \ ACDX \ ACCP \ CWNA \ CWAP \ ACE
    [Description: Description: Description: Description: Description: cid:image001.png@01CB0373.100D2390]
    T: 781.860.5557
    C: 781.686.4305
    vfabian@integrationpartners.com
    www.integrationpartners.com
    [cid:image002.png@01D17490.FF1872C0]
  • 5.  RE: Stop IOS from updating
    Posted Mar 02, 2016 01:27 PM
    It's a losing battle to stop the notification as it comes via APNS. Some
    type of MDM would be the proper solution.
