Strange behavior of WiFi Phone
  • 1.  Strange behavior of WiFi Phone
    Posted Oct 24, 2013 03:06 AM
    I notice a strange behavior of a WiFi Phone associated with our WiFi network, composed by 1 controller Aruba650 and 10 AP (1 AP105 + 9 AP93). The firmware version is ArubaOS 6.3.1.0.
    The phone is always in the same location, under an AP, but in the log I see the messages that I attached here on a file.
    The phone is deauthenticated by other APs, but these APs aren't the AP on which the client is associeted.
    Why I get these messages?What is the meaning oh these?
    Massimo
    #6.3
    Attachment(s)
    txt
    log WiFi phone.txt   8 KB 1 version
  • 2.  RE: Strange behavior of WiFi Phone
    Posted Oct 24, 2013 12:07 PM
    You should run the show ap association client-mac <device Mac >
    How close are those APs ? That the phone might be associating to one of those since it can hear the beacons from that AP but is not a healthy signal ?
  • 3.  RE: Strange behavior of WiFi Phone
    Posted Oct 24, 2013 12:28 PM
    Here the output of the command show ap association client-mac <device Mac >:
    The phy column shows client's operational capabilities for current association
    Flags: A: Active, B: Band Steerable, H: Hotspot(802.11u) client, K: 802.11K client, R: 802.11R client, W: WMM client, w: 802.11w client
    PHY Details: HT   : High throughput;      20: 20MHz;  40: 40MHz
                 VHT  : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
                 <n>ss: <n> spatial streams
    Association Table
    Name   bssid              mac                auth  assoc  aid  l-int  essid     vlan-id  tunnel-id  phy  assoc. time  num assoc  Flags  Band steer moves (T/S)
    APADU  00:24:6c:80:ae:b4  00:03:2a:25:1b:4a  y     y      1    1      WiFi_RED  3        0x10050    g    7h:41m:32s   1          WA     0/0
    00:03:2a:25:1b:4a-00:24:6c:80:ae:b4 Stats
    Parameter                            Value
    Channel                              6
    Channel Frame Retry Rate(%)          0
    Channel Frame Low Speed Rate(%)      0
    Channel Frame Non Unicast Rate(%)    0
    Channel Frame Fragmentation Rate(%)  0
    Channel Frame Error Rate(%)          3
    Channel Bandwidth Rate(kbps)         0
    Channel Noise                        88
    Client Frame Retry Rate(%)           0
    Client Frame Low Speed Rate(%)       0
    Client Frame Non Unicast Rate(%)     0
    Client Frame Fragmentation Rate(%)   0
    Client Frame Receive Error Rate(%)   0
    Client Bandwidth Rate(kbps)          0
    Client Tx Packets                    394045
    Client Rx Packets                    181850
    Client Tx Bytes                      53446512
    Client Rx Bytes                      37641654
    Client SNR                           67
    The APs it's not very closed, but the strange thing is that the client is always associeted on the same AP, never with the others.
