Strange behaviour with AP70 provisoned on the A2400. %0D%0A
  • 1.  Strange behaviour with AP70 provisoned on the A2400. %0D%0A
    Posted Dec 06, 2013 03:05 PM
    Dear Aruba Team,
    I have very strange problem with Ap 70 provisioned on the controller A2400. From some reason the Roaming status have been changed to Wired (remote) and also I can see some Access Points as a "Wired Access Points". Honestly speaking I have no idea what means "Wired Access Point". The Forward mode "bridge" instead Tunnel.
    I investigated all configuration on the rotuers and switches and I couldn't find any doubts.
    Could you please let me know, what I can do in mentioned case.
    Best Regards
  • 2.  RE: Strange behaviour with AP70 provisoned on the A2400. %0D%0A
    Posted Dec 06, 2013 03:10 PM
    Can you please share the following :
    show ap ap-group <ap-group name>
    show wlan virtual-ap <virtual AP name>
  • 3.  RE: Strange behaviour with AP70 provisoned on the A2400. %0D%0A
    Posted Dec 06, 2013 03:13 PM
    Additionally these Access Points are not broadcasting any SSID.
  • 4.  RE: Strange behaviour with AP70 provisoned on the A2400. %0D%0A
    Posted Dec 06, 2013 03:18 PM
    We will need to see how are these configured.
    You can configure these (AP70  / AP2E) as remote APs in bridge mode and that's probably why you see it getting categorize as a wired access points but these don't broadcast an SSID just functions as a wired bypass
  • 5.  RE: Strange behaviour with AP70 provisoned on the A2400. %0D%0A
    Posted Dec 06, 2013 03:21 PM
    it527wc01) # show wlan virtual-ap devicenet-527-vap
    Virtual AP profile "devicenet-527-vap" (Invalid: VLAN 401 does not exist)
    Parameter Value
    QinQ Outer VLAN 0
    Virtual AP enable Enabled
    Allowed band all
    AAA Profile devicenet-527-aaa
    802.11K Profile default
    SSID Profile devicenet-527
    VLAN 401
    Forward mode tunnel
    Deny time range N/A
    Mobile IP Enabled
    HA Discovery on-association Disabled
    DoS Prevention Disabled
    Station Blacklisting Enabled
    Blacklist Time 3600 sec
    Dynamic Multicast Optimization (DMO) Disabled
    Dynamic Multicast Optimization (DMO) Threshold 6
    Authentication Failure Blacklist Time 3600 sec
    Multi Association Disabled
    Strict Compliance Disabled
    VLAN Mobility Disabled
    Preserve Client VLAN Disabled
    Remote-AP Operation standard
    Drop Broadcast and Multicast Disabled
    Convert Broadcast ARP requests to unicast Disabled
    Band Steering Disabled
    Steering Mode prefer-5ghz
    VLAN POOL SIZE 0
    WMM Traffic Management Profile N/A
    ap-group "it527"
    virtual-ap "guest-guestnet-vap"
    virtual-ap "employee-tenet-mobile-v420-vap"
    virtual-ap "devicenet-527-vap"
    virtual-ap "employee-tenet-enterprise-v401-vap"
    virtual-ap "employee-tenet-mac-v401-vap"
    ap-system-profile "it527-apsettings"
    regulatory-domain-profile "italy"
  • 6.  RE: Strange behaviour with AP70 provisoned on the A2400. %0D%0A
    Posted Dec 06, 2013 03:24 PM
    The goal what I would like to achieve is take them back to the corrent settings to allow SSID broadcasting.
    Thank you for support
  • 7.  RE: Strange behaviour with AP70 provisoned on the A2400. %0D%0A
    Posted Dec 06, 2013 03:45 PM
    Will try to help you with that.
    Please run these commands from the local controller these APs are attached :
    show ap database long | include <ap mac address>
    show  ap  config ap-name <apname>
    show ap active | include <ap mac address>
    Did you recently started seeing these APs behave that way ? Were these APs broadcasting the SSIDs ?
    Has anything changed recently ?
    What AOS do you have installed ?
    Also make sure you open a TAC case just in case.
  • 8.  RE: Strange behaviour with AP70 provisoned on the A2400. %0D%0A
    Posted Dec 06, 2013 03:47 PM
    I would like to add that I have the same situation on the second controller - completely the same behaviour.
    For example AP60's can work normally.
    Do you have any idea, what can be the reason?
    Regards
    Patryk
  • 9.  RE: Strange behaviour with AP70 provisoned on the A2400. %0D%0A
    Posted Dec 06, 2013 04:02 PM
    it527wc00) #show ap database long | include 00:0b:86:c6:ba:68
    it527wa06 it527 70 10.115.114.16 Up 4m:1s 00:0b:86:c6:ba:68 A50120828 1/0 N/A N/A
    it527wc00) #show ap config ap-name it527wa06
    Configuration for AP name "it527wa06" AP group "it527"
    Parameter 802.11g 802.11a Source
    LMS IP 10.115.114.4 10.115.114.4 ap system-profile "it527-apsettings"
    Backup LMS IP N/A N/A ap system-profile "it527-apsettings"
    LMS Preemption Enabled Enabled ap system-profile "it527-apsettings"
    LMS Hold-down Period 600 sec 600 sec ap system-profile "it527-apsettings"
    Number of IPSEC retries 360 360 ap system-profile "it527-apsettings"
    LED operating mode (AP-9x/AP-10x/AP-12x/RAP-5x only) normal normal ap system-profile "it527-apsettings"
    RF Band g g ap system-profile "it527-apsettings"
    Double Encrypt Disabled Disabled ap system-profile "it527-apsettings"
    Native VLAN ID 1 1 ap system-profile "it527-apsettings"
    SAP MTU 1500 bytes 1500 bytes ap system-profile "it527-apsettings"
    Bootstrap threshold 8 8 ap system-profile "it527-apsettings"
    Request Retry Interval 10 sec 10 sec ap system-profile "it527-apsettings"
    Maximum Request Retries 10 10 ap system-profile "it527-apsettings"
    Keepalive Interval 60 sec 60 sec ap system-profile "it527-apsettings"
    Dump Server N/A N/A ap system-profile "it527-apsettings"
    Telnet Disabled Disabled ap system-profile "it527-apsettings"
    SNMP sysContact N/A N/A ap system-profile "it527-apsettings"
    AeroScout RTLS Server N/A N/A ap system-profile "it527-apsettings"
    RTLS Server configuration N/A N/A ap system-profile "it527-apsettings"
    Remote-AP DHCP Server VLAN N/A N/A ap system-profile "it527-apsettings"
    Remote-AP DHCP Server Id 192.168.11.1 192.168.11.1 ap system-profile "it527-apsettings"
    Remote-AP DHCP Default Router 192.168.11.1 192.168.11.1 ap system-profile "it527-apsettings"
    Remote-AP DHCP Pool Start 192.168.11.2 192.168.11.2 ap system-profile "it527-apsettings"
    Remote-AP DHCP Pool End 192.168.11.254 192.168.11.254 ap system-profile "it527-apsettings"
    Remote-AP DHCP Pool Netmask 255.255.255.0 255.255.255.0 ap system-profile "it527-apsettings"
    Remote-AP DHCP Lease Time 0 days 0 days ap system-profile "it527-apsettings"
    Remote-AP Backup Ports Enabled Enabled ap system-profile "it527-apsettings"
    Remote-AP uplink total bandwidth 0 kbps 0 kbps ap system-profile "it527-apsettings"
    Remote-AP bw reservation 1 N/A N/A ap system-profile "it527-apsettings"
    Remote-AP bw reservation 2 N/A N/A ap system-profile "it527-apsettings"
    Remote-AP bw reservation 3 N/A N/A ap system-profile "it527-apsettings"
    Heartbeat DSCP 0 0 ap system-profile "it527-apsettings"
    Session ACL ap-uplink-acl ap-uplink-acl ap system-profile "it527-apsettings"
    Maintenance Mode Disabled Disabled ap system-profile "it527-apsettings"
    WISPr Location-ID ISO Country Code N/A N/A ap system-profile "it527-apsettings"
    WISPr Location-ID E.164 Country Code N/A N/A ap system-profile "it527-apsettings"
    WISPr Location-ID E.164 Area Code N/A N/A ap system-profile "it527-apsettings"
    WISPr Location-ID SSID/Zone N/A N/A ap system-profile "it527-apsettings"
    WISPr Operator Name N/A N/A ap system-profile "it527-apsettings"
    WISPr Location Name N/A N/A ap system-profile "it527-apsettings"
    Remote-AP Local Network Access Disabled Disabled ap system-profile "it527-apsettings"
    Radio enable Enabled Enabled rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Mode ap-mode ap-mode rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    High throughput enable (radio) Enabled Enabled rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Channel N/A N/A rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Beacon Period 100 msec 100 msec rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Beacon Regulate Disabled Disabled rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Transmit EIRP 15 dBm 15 dBm rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Advertise 802.11d and 802.11h Capabilities Disabled Disabled rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Spectrum load balancing Disabled Disabled rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Spectrum Load balancing mode channel channel rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Spectrum load balancing update interval (sec) 30 seconds 30 seconds rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Spectrum load balancing threshold (%) 20 percent 20 percent rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Advertized regulatory max EIRP 0 0 rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Spectrum Load Balancing domain N/A N/A rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    RX Sensitivity Tuning Based Channel Reuse disable disable rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    RX Sensitivity Threshold 0 -dBm 0 -dBm rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Non 802.11 Interference Immunity Level-2 Level-2 rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Enable CSA Disabled Disabled rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    CSA Count 4 4 rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Management Frame Throttle interval 1 sec 1 sec rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Management Frame Throttle Limit 20 20 rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    ARM/WIDS Override Disabled Disabled rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Protection for 802.11b Clients Enabled N/A rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Maximum Distance 0 meters 0 meters rf dot11g-radio-profile "default" / rf dot11a-radio-profile "default"
    Assignment single-band single-band rf arm-profile "default"
    Allowed bands for 40MHz channels a-only a-only rf arm-profile "default"
    Client Aware Enabled Enabled rf arm-profile "default"
    Max Tx EIRP 127 dBm 127 dBm rf arm-profile "default"
    Min Tx EIRP 9 dBm 9 dBm rf arm-profile "default"
    Multi Band Scan Enabled Enabled rf arm-profile "default"
    Rogue AP Aware Disabled Disabled rf arm-profile "default"
    Scan Interval 10 sec 10 sec rf arm-profile "default"
    Active Scan Disabled Disabled rf arm-profile "default"
    Scanning Enabled Enabled rf arm-profile "default"
    Scan Time 110 msec 110 msec rf arm-profile "default"
    VoIP Aware Scan Disabled Disabled rf arm-profile "default"
    Power Save Aware Scan Enabled Enabled rf arm-profile "default"
    Video Aware Scan Enabled Enabled rf arm-profile "default"
    Ideal Coverage Index 10 10 rf arm-profile "default"
    Acceptable Coverage Index 4 4 rf arm-profile "default"
    Free Channel Index 25 25 rf arm-profile "default"
    Backoff Time 240 sec 240 sec rf arm-profile "default"
    Error Rate Threshold 50 % 50 % rf arm-profile "default"
    Error Rate Wait Time 30 sec 30 sec rf arm-profile "default"
    Noise Threshold 75 -dBm 75 -dBm rf arm-profile "default"
    Noise Wait Time 120 sec 120 sec rf arm-profile "default"
    Minimum Scan Time 8 8 rf arm-profile "default"
    Load aware Scan Threshold 1250000 Bps 1250000 Bps rf arm-profile "default"
    Mode Aware Arm Disabled Disabled rf arm-profile "default"
    40 MHz intolerance Disabled Disabled rf ht-radio-profile "default-g" / "default-a"
    Honor 40 MHz intolerance Enabled Enabled rf ht-radio-profile "default-g" / "default-a"
    Legacy station workaround Disabled Disabled rf ht-radio-profile "default-g" / "default-a"
    SSID enable Enabled Enabled wlan ssid-profile "guest-guestnet"
    ESSID guestnet guestnet wlan ssid-profile "guest-guestnet"
    Encryption opensystem opensystem wlan ssid-profile "guest-guestnet"
    DTIM Interval 1 beacon periods 1 beacon periods wlan ssid-profile "guest-guestnet"
    Basic Rates 1 2 6 12 24 wlan ssid-profile "guest-guestnet"
    Transmit Rates 1 2 5 6 9 11 12 18 24 36 48 54 6 9 12 18 24 36 48 54 wlan ssid-profile "guest-guestnet"
    Station Ageout Time 1000 sec 1000 sec wlan ssid-profile "guest-guestnet"
    Max Transmit Attempts 8 8 wlan ssid-profile "guest-guestnet"
    RTS Threshold 2333 bytes 2333 bytes wlan ssid-profile "guest-guestnet"
    Short Preamble Enabled N/A wlan ssid-profile "guest-guestnet"
    Max Associations 64 64 wlan ssid-profile "guest-guestnet"
    Wireless Multimedia (WMM) Disabled Disabled wlan ssid-profile "guest-guestnet"
    Wireless Multimedia U-APSD (WMM-UAPSD) Powersave Enabled Enabled wlan ssid-profile "guest-guestnet"
    WMM TSPEC Min Inactivity Interval 0 msec 0 msec wlan ssid-profile "guest-guestnet"
    Override DSCP mappings for WMM clients Disabled Disabled wlan ssid-profile "guest-guestnet"
    DSCP mapping for WMM voice AC 56 56 wlan ssid-profile "guest-guestnet"
    DSCP mapping for WMM video AC 40 40 wlan ssid-profile "guest-guestnet"
    DSCP mapping for WMM best-effort AC 24 24 wlan ssid-profile "guest-guestnet"
    DSCP mapping for WMM background AC 8 8 wlan ssid-profile "guest-guestnet"
    902il Compatibility Mode Disabled Disabled wlan ssid-profile "guest-guestnet"
    Hide SSID Disabled Disabled wlan ssid-profile "guest-guestnet"
    Deny_Broadcast Probes Disabled Disabled wlan ssid-profile "guest-guestnet"
    Local Probe Request Threshold (dB) 0 0 wlan ssid-profile "guest-guestnet"
    Disable Probe Retry Enabled Enabled wlan ssid-profile "guest-guestnet"
    Battery Boost Disabled N/A wlan ssid-profile "guest-guestnet"
    WEP Key 1 N/A N/A wlan ssid-profile "guest-guestnet"
    WEP Key 2 N/A N/A wlan ssid-profile "guest-guestnet"
    WEP Key 3 N/A N/A wlan ssid-profile "guest-guestnet"
    WEP Key 4 N/A N/A wlan ssid-profile "guest-guestnet"
    WEP Transmit Key Index 1 1 wlan ssid-profile "guest-guestnet"
    WPA Hexkey N/A N/A wlan ssid-profile "guest-guestnet"
    WPA Passphrase N/A N/A wlan ssid-profile "guest-guestnet"
    Maximum Transmit Failures 0 0 wlan ssid-profile "guest-guestnet"
    BC/MC Rate Optimization Disabled Disabled wlan ssid-profile "guest-guestnet"
    Strict Spectralink Voice Protocol (SVP) Disabled Disabled wlan ssid-profile "guest-guestnet"
    802.11g Beacon Rate default N/A wlan ssid-profile "guest-guestnet"
    802.11a Beacon Rate N/A default wlan ssid-profile "guest-guestnet"
    Advertise QBSS Load IE Disabled Disabled wlan ssid-profile "guest-guestnet"
    High throughput enable (SSID) Enabled Enabled wlan ht-ssid-profile "default"
    40 MHz channel usage Enabled Enabled wlan ht-ssid-profile "default"
    MPDU Aggregation Enabled Enabled wlan ht-ssid-profile "default"
    Max transmitted A-MPDU size 65535 bytes 65535 bytes wlan ht-ssid-profile "default"
    Max received A-MPDU size 65535 bytes 65535 bytes wlan ht-ssid-profile "default"
    Min MPDU start spacing 8 usec 8 usec wlan ht-ssid-profile "default"
    Supported MCS set 0-15 0-15 wlan ht-ssid-profile "default"
    Short guard interval in 40 MHz mode Enabled Enabled wlan ht-ssid-profile "default"
    Legacy stations Allowed Allowed wlan ht-ssid-profile "default"
    Allow weak encryption Disabled Disabled wlan ht-ssid-profile "default"
    QinQ Outer VLAN 0 0 wlan virtual-ap "guest-guestnet-vap"
    Virtual AP enable Enabled Enabled wlan virtual-ap "guest-guestnet-vap"
    Allowed band all all wlan virtual-ap "guest-guestnet-vap"
    VLAN 421 421 wlan virtual-ap "guest-guestnet-vap"
    Forward mode tunnel tunnel wlan virtual-ap "guest-guestnet-vap"
    Deny time range N/A N/A wlan virtual-ap "guest-guestnet-vap"
    Mobile IP Enabled Enabled wlan virtual-ap "guest-guestnet-vap"
    HA Discovery on-association Disabled Disabled wlan virtual-ap "guest-guestnet-vap"
    DoS Prevention Disabled Disabled wlan virtual-ap "guest-guestnet-vap"
    Station Blacklisting Enabled Enabled wlan virtual-ap "guest-guestnet-vap"
    Blacklist Time 3600 sec 3600 sec wlan virtual-ap "guest-guestnet-vap"
    Dynamic Multicast Optimization (DMO) Disabled Disabled wlan virtual-ap "guest-guestnet-vap"
    Dynamic Multicast Optimization (DMO) Threshold 6 6 wlan virtual-ap "guest-guestnet-vap"
    Authentication Failure Blacklist Time 3600 sec 3600 sec wlan virtual-ap "guest-guestnet-vap"
    Multi Association Disabled Disabled wlan virtual-ap "guest-guestnet-vap"
    Strict Compliance Disabled Disabled wlan virtual-ap "guest-guestnet-vap"
    VLAN Mobility Disabled Disabled wlan virtual-ap "guest-guestnet-vap"
    Preserve Client VLAN Disabled Disabled wlan virtual-ap "guest-guestnet-vap"
    Remote-AP Operation standard standard wlan virtual-ap "guest-guestnet-vap"
    Drop Broadcast and Multicast Disabled Disabled wlan virtual-ap "guest-guestnet-vap"
    Convert Broadcast ARP requests to unicast Disabled Disabled wlan virtual-ap "guest-guestnet-vap"
    Band Steering Disabled Disabled wlan virtual-ap "guest-guestnet-vap"
    Steering Mode prefer-5ghz prefer-5ghz wlan virtual-ap "guest-guestnet-vap"
    VLAN POOL SIZE 0 0 wlan virtual-ap "guest-guestnet-vap"
    VoIP Call Admission Control Disabled Disabled wlan voip-cac-profile "default"
    VoIP Bandwidth based CAC Disabled Disabled wlan voip-cac-profile "default"
    VoIP Call Capacity 10 10 wlan voip-cac-profile "default"
    VoIP Bandwidth Capacity (kbps) 2000 2000 wlan voip-cac-profile "default"
    VoIP Call Handoff Reservation 20 % 20 % wlan voip-cac-profile "default"
    VoIP Send SIP 100 Trying Disabled Disabled wlan voip-cac-profile "default"
    VoIP Disconnect Extra Call Disabled Disabled wlan voip-cac-profile "default"
    VOIP TSPEC Enforcement Disabled Disabled wlan voip-cac-profile "default"
    VOIP TSPEC Enforcement Period 1 sec 1 sec wlan voip-cac-profile "default"
    VoIP Drop SIP Invite and send status code (client) 486 486 wlan voip-cac-profile "default"
    VoIP Drop SIP Invite and send status code (server) 486 486 wlan voip-cac-profile "default"
    I tried to perform sh ap active, but I can see it that mentioned AP is rebooting few times - very unstable ( the same for all AP70s)
    That IOS which we are running is: 5.0.4.2
    It started when we moved some AP to the another cisco switch. For your information we also moved to the previous configuration afterwards. I confirmed that configuration and vlans are available on the all required switches.
  • 10.  RE: Strange behaviour with AP70 provisoned on the A2400. %0D%0A
    Posted Dec 08, 2013 07:54 PM
    Let's confirm the following :
    - One thing that I noticed was that the VLAN 401 associated with your Virtual AP looks like it doesn't exist on your controller , you need to make sure that the VLAN is there .
    - Also run the show ap essid command
    - Do you have all your APs behaving that way or just the APs in that AP-Group.
    - Run the show vlan and show ip interface brief to make sure that VLAN 401 / interface vlan 401 has been created.
    - If you moved those APs to another switch and you see the APs rebooting a lot , then you may have a layer 1 issue .
  • 11.  RE: Strange behaviour with AP70 provisoned on the A2400. %0D%0A
    Posted Dec 09, 2013 06:31 AM
    Good morning Fabian
    I saw it as well. I fixed this problem, thank you.
    Below you can find result of sh ap essid.
    It looks that there are some clients connected, but from Gui interface I can see that clients can not obtain correct IP.
    In User Role these information "logon" and Roaming Status -> Wired(Remote)
    ESSID APs Clients VLAN(s) Encryption
    xnet-Mobile 21 2 420 WPA2 8021X AES
    guestnet 22 2 421 Open
    xnet-Mac 21 0 401 WPA2 8021X AES
    xnet-Enterprise 21 3 401 WPA2 8021X AES
    x-527 21 7 401 Static WEP
    Num ESSID:5
    There is only a problem with AP70's. For example AP60's works fine. For your information all access points are associated with only one vlan.
    Best regards
    Patryk Zatorski
