Wired Intelligent Edge
Strange behaviour with port-access local-mac authentication
  • 1.  Strange behaviour with port-access local-mac authentication
    Posted Feb 17, 2020 04:06 PM
    Hi all,
    We have a bunch of Aruba 2930F switches, organized in stacks (vsf).
    # show vsf
    VSF Domain ID : 1
    MAC Address : 8030e0-xxxxxx
    VSF Topology : Ring
    VSF Status : Active
    Uptime : 354d 2h 23m
    VSF MAD : None
    VSF Port Speed : 10G
    Software Version : WC.16.05.0007
    Mbr
    ID MAC Address Model Pri Status
    1 8030e0-955540 Aruba JL558A 2930F-48G-740W-PoE+-4... 128 Commander
    2 8030e0-95df40 Aruba JL558A 2930F-48G-740W-PoE+-4... 128 Standby
    3 8030e0-96f3c0 Aruba JL558A 2930F-48G-740W-PoE+-4... 128 Member
    We also use port-access local-mac to authenticate and place the devices on the right vlans.
    Our work areas are formed of huawei 7910/7950 phones linked to desktops of several manufacturers/models.
    The normal configuration of our ports is:
    interface x/y
     tagged vlan <voice>
     untagged vlan <user>
     aaa port-access local-mac
     aaa port-access local-mac address-limit 2
     aaa port-access local-mac mac-pin
    Normal case works. We see two devices authenticated to the ports:
    # show port-access local-mac 1/12 cli
    Port Access Local MAC Authentication Client Status
    Port MAC Address IP Address Client Status
    1/12 3464a9-00acf8 n/a authenticated
    1/12 a08cf8-68e2af n/a authenticated
    and see both devices on the MAC-Address table, associated to the port:
    # show mac-address 1/12
    Status and Counters - Port Address Table - 1/12
    MAC Address VLANs
    3464a9-00acf8 160
    a08cf8-68e2af 152
    But, for some reason, some ports aren't working as expected. Even when we have 2 devices authenticated, only one of them get to the MAC-Address Table.
    # show port-access local-mac 3/31 cli
    3/31 0040a7-2f8445 n/a authenticated
    3/31 a08cf8-36a09b n/a authenticated
    # show mac-address 3/31
    Status and Counters - Port Address Table - 3/31
    MAC Address VLANs
    0040a7-2f8445 160
    This seems to be happening only on vsf member 3, which was last added to the stack.
    Does anyone ever saw this behaviour?
  • 2.  RE: Strange behaviour with port-access local-mac authentication
    Posted Feb 18, 2020 04:02 AM
    Please double check that both ports have the exact same configuration, and you use the exact same devices to test with.
    I wouldn't see a reason to have different behavior on different stack members with the same configuration.
    If there is no difference, please work with Aruba Support to further investigate.
  • 3.  RE: Strange behaviour with port-access local-mac authentication
    Posted Mar 13, 2020 04:55 PM
    Thanks for your attention.
    Opened a support case, and was instructed to update the switches' software. This solved the big case.
    In the mean time, I saw that the IP Phones needed a special configuration, as they was trying to authenticate on the switch both on the tagged and on the untagged VLAN. So, I changed:
    aaa port-access local-mac profile IP-Phone
     vlan tagged 152
     exit
    to:
     vlan tagged 152
     vlan untagged 160
     exit
    After that, the IP phones started to figure out both on the tagged and on the untagged VLANs:
    # show port-acc local-mac cli 1/6
    1/6 a08cf8-68e81e n/a authenticated
    1/6 d02788-5deca7 n/a authenticated
    # show mac-addr 1/6
    Status and Counters - Port Address Table - 1/6
    MAC Address VLANs
    a08cf8-68e81e 152,160
    d02788-5deca7 160
    This did the trick. Now I have peace!!!
