Strange Configuration 7030
  • 1.  Strange Configuration 7030
    Posted Dec 20, 2019 02:16 AM
    We currently have two controllers which are configured as standalone / standby. When the main controller is no longer alive the standby controller is running.
    AS i can see there are three configurations:
    1. The mobility master configuration (mm) (192.168.200.140)
    2. The node configuration (standalone) (192.168.200.141)
    3. The other node configuration (standby) (192.168.200.142)
    I noticed that when i switch off the standalone, the master configuration on the standby is not identical to the standalone controller.
    I checked the nodes configuration and they are perfectly the same (Except for IP / hostname). How come the mobility master configuration is not identical on both controllers?
    Furthermore, i have posted the database sync below.
    <----Display of show database sync from standalone----------------->
    Last L2 synchronization time: Fri Dec 20 07:44:59 2019
    Last L3 synchronization time: Secondary not synchronized since last reboot
    To Master Switch at 10.100.200.142:  succeeded
    WMS Database backup file size: 96909 bytes
    Local User Database backup file size: 49536 bytes
    Global AP Database backup file size: 14964 bytes
    IAP Database backup file size: 3751 bytes
    Airgroup Database backup file size: 3055 bytes
    License Database backup file size: 4943 bytes
    CPSec Database backup file size: 3248 bytes
    Bocmgr Database backup file size: 6017 bytes
    L2 Synchronization took 8 second
    L3 Synchronization took less than one second
    87 L2 synchronization attempted
    4 L2 synchronization have failed
    0 L3 synchronization attempted
    0 L3 synchronization have failed
    L2 Periodic synchronization is enabled and runs every 30 minutes
    L3 Periodic synchronization is disabled
    Synchronization doesn't include Captive Portal Custom data
    <----Display of show database sync from standby----------------->
    From Master Switch at 10.100.200.141:  succeeded
    90 L2 synchronization attempted
    3 L2 synchronization have failed
    <----Display of show database sync from master mobility----------------->
    Last L2 synchronization time: Fri Dec 20 08:15:01 2019
    WMS Database backup file size: 97851 bytes
    Local User Database backup file size: 49550 bytes
    88 L2 synchronization attempted
  • 2.  RE: Strange Configuration 7030
    Posted Dec 20, 2019 02:50 AM
    After comparing the two configuration  line by line the only difference was an extra aaa profile which was empty on the standby which was deleted.
    After the deletion a reboot was done and the configuration sync worked.
