Strange model 105 series
  • 1.  Strange model 105 series
    Posted Jul 14, 2016 05:57 PM
    Which model do i have?
    I have 6 model 105 ap's or iap's. Who can help? They have no extra label stating the right model AP-105 or IAP-105. They have a reset button. So I think that they must be IAP. But they seem to be loaded with AOS firmware.
  • 2.  RE: Strange model 105 series
    Posted Jul 14, 2016 05:58 PM
    All APs have a reset button.  You would only know what an AP is by emailing tac with the serial number.
  • 3.  RE: Strange model 105 series
    Posted Jul 14, 2016 06:09 PM
    My other AP--105 have no reset button.
  • 4.  RE: Strange model 105 series
    Posted Jul 14, 2016 07:52 PM
    Let me check.  When the AP105s first were made, they did not have reset buttons.  When IAP-105s started being made, I think reset buttons were added to all APs after that..
    I think...
  • 5.  RE: Strange model 105 series
    Posted Jul 14, 2016 08:17 PM
    So the answer is yes.  After we released the IAP-105, we starting also producing AP-105s with reset buttons.  You might have to ask TAC which serial numbers you have started life as an IAP vs. a CAP 105.
  • 6.  RE: Strange model 105 series
    MVP GURU
    Posted Jul 23, 2016 08:33 AM
    Good to known :-)
  • 7.  RE: Strange model 105 series
    Posted Jul 15, 2016 01:13 PM
    Thx Colin. I will check with TAC if they are ap or iap.
