Strange re-connect issue with android tablets (SM-T230 4.4.2) (using 802.1x)
  • 1.  Strange re-connect issue with android tablets (SM-T230 4.4.2) (using 802.1x)
    Posted Feb 10, 2015 11:37 AM
    Good evening,
    (Controller = M3 , AOS 6.3.1.XX)
    I got a question from one of my major client , He notice some strange re-connect issue (802.1x) with android devices of Samsung , Model:
    SM-T230 ,The devices are tablets that running Android version 4.4.2.
    the devices are able to connect the SSID just fine (doing 802.1x WPA2-AES)  , but once in a while or while going out from the coverage areas and then coming back , the devices stuck on "connecting..." without connect,the only way to connect them is to Disable/Enable the wi-fi connection on the Tablet.
    In the Aruba controller , we do notice , the following log:
    Feb 10 11:35:08  authmgr[2028]: <132207> <ERRS> |authmgr|  RADIUS reject for station tasmc1\tbl-18227efe0817 18:22:7e:f8:08:17 from server 10.101.1.8.
    on the server side - We also see an error:
    INVALID_AUTH_TYPE
    Anyone encouter this issue?
    what might causing this? ...If we Enable/Disable the client wi-fi  - it's back to connect agian as needed.
    Please advise.
    Thanks AirHeads
  • 2.  RE: Strange re-connect issue with android tablets (SM-T230 4.4.2) (using 802.1x)
    Posted Feb 10, 2015 02:11 PM
    Can you try enabling user debugging for this MAC address?
    logging level debugging user-debug <mac addr>
