Wired Intelligent Edge
  • 1.  SU 2930 - ERROR: SRAM BIST Failed
    Posted Mar 30, 2021 04:36 AM
    Hello, i am new in this forum and would like to get an answer to a note from the serial port of a SU 2930M 24G PoE
    The Switch is out of order and i tried too get the config file of this server.
    I01
    0x80200000 0x00006000 0x00000000 0x00000000
    The SRAM BIST is the memory check, or? How can i prefend the Switch to check the memory?
    Thank you for your support.
    Kind regards Alexander
    #2930
    #BIST
    #config
    #SRAM
  • 2.  RE: SU 2930 - ERROR: SRAM BIST Failed
    Posted Mar 30, 2021 09:10 AM
    It seems switch memoy has been failed.
    Its difficult to get the config file now.
    I believe you need to replace the switch.
    Thanks!
  • 3.  RE: SU 2930 - ERROR: SRAM BIST Failed
    Posted Mar 31, 2021 04:15 AM
    Hi  @alha_support BIST is the Built-In-Self-Test internal and automatic procedure to test the switch Hardware running at boot, in this case your switch didn't pass the SRAM test...I'm with @akg7 , you should ask for an RMA if you're entitled to do so.
