AOS-CX Switch Simulator
Sub-interfaces is simulator - do they work?
This thread has been viewed 42 times
  • 1.  Sub-interfaces is simulator - do they work?
    Posted Sep 26, 2022 12:26 PM
    I'm trying to figure out if sub-interfaces work in the simulator (I can't get them to work) and from my searching I'm getting conflicting answers. The release notes for version 10.08 shows IP sub-interface as an enhancement for that release:
    However a video I found on the Airheads youtube channel about sub-interfaces seems to indicate that it's not supported:
    When I do a "show capacities subinterface" on any of my virtual switches, I get "No capacities found with given filter." I am running version 10.0.9
    Can anyone clarify if sub-interfaces should work in the simulator?
  • 2.  RE: Sub-interfaces is simulator - do they work?
    Posted Sep 26, 2022 01:49 PM
    I tested sub-interfaces in 10.08 and 10.09 and they don't work.
    Give me a few days to test 10.10.
    Regards, Ruben.
  • 3.  RE: Sub-interfaces is simulator - do they work?
    Posted Sep 26, 2022 01:54 PM
    I tried it in 10.10 also and couldn't get it to work but I may be doing something wrong as well. I wanted to make sure it's actually possible before I spend too much more time troubleshooting my config
  • 4.  RE: Sub-interfaces is simulator - do they work?
    Posted Sep 29, 2022 10:57 AM
    I just tested sub-interfaces with 10.10.1000 and you can configure them, but they do not work.
  • 5.  RE: Sub-interfaces is simulator - do they work?
    Posted Sep 29, 2022 02:39 PM
    Thanks for trying!
  • 6.  RE: Sub-interfaces is simulator - do they work?
    Posted Nov 01, 2023 05:37 PM
    I just spent a couple of hours figuring this out for myself before stumbling across this post. It would be nice is Aruba could include this in their release notes!
