Successfully deploying a stack
  • 1.  Successfully deploying a stack
    Posted Dec 17, 2014 04:22 PM
    I'm configuring a new school with a 6 member stack.
    I configure the first switch which has the following config in it:
    stack-profile
       member-id 0 serial-number BZ000123 role primary-capable
       member-id 1 serial-number BZ000234 role primary-capable
       member-id 2 serial-number BZ000345 role line-card
       member-id 3 serial-number BZ000456 role line-card
       member-id 4 serial-number BZ000567 role line-card
       member-id 5 serial-number BY001678 role line-card
    After saving the config I connect the second switch in the stack and the second switch deletes the config on the first switch and makes itself Primary. How do I stop this? Its REALLY annoying.
    Why  is the Dynamic election overriding my configuration?
    How do I revert it without Facorty-defaulting everything...again?
  • 2.  RE: Successfully deploying a stack
    Posted Dec 17, 2014 04:25 PM
    Playinpearls,
    So I assume the first switch where you have the configuration is serial-number BZ000123? Is the second switch factory defaulted? Was it powered up at the same time as the first?
    Best regards,
    Madani
  • 3.  RE: Successfully deploying a stack
    Posted Dec 17, 2014 04:26 PM
    well its fake but yes, its member 1 that is configured first.
    All the rest are factory defaulted from the first time it did this.
  • 4.  RE: Successfully deploying a stack
    Posted Dec 17, 2014 05:03 PM
    So member 1 is configured first, then you attached member 0? I'm just trying to follow your order of operations. I ran a quick test with two switches and can't replicate it.
    (ArubaS1500-12P) >en
    Password:******
    Zero Touch Provisioning (Activate or DHCP based) of the system has been stopped.
    Would you like to use Quick-Setup to help with the basic configuration of the system (y|n)?n
    Quick-setup dialog can be launched by executing "quick-setup" command in enable mode
    (ArubaS1500-12P) #configure t
    Enter Configuration commands, one per line. End with CNTL/Z
    (ArubaS1500-12P) (config) #hostname ARUBASTACK
    (ARUBASTACK) (config) #stack-profile
    (ARUBASTACK) (stack-profile) #member-id 0 serial-number CD0005213 role primary-capable
    WARNING!! This profile will not be applied till the configuration is saved.
    (ARUBASTACK) (stack-profile) #member-id 1 serial-number CF0000005 role primary-capable
    (ARUBASTACK) (stack-profile) #exit
    (ARUBASTACK) (config) #mgmt-user admin root
    Password:********
    Re-Type password:********
    (ARUBASTACK) (config) #write mem
    Saving Configuration...
    Configuration Saved.
    (ARUBASTACK) (config) #exit
    (ARUBASTACK) #show stacking members
    Stack status: Active, Stack Id: 000b86991c375491fa6a
    Stack uptime: 1 minutes 35 seconds
    Id    Role       MAC Address        Priority  State     Model            Serial      Location
    0  *  Primary    00:0b:86:99:1c:37  Preset    Active    ArubaS1500-12P   CD0005213   Not Set
    # I attached the second switch at this point which should become member 1.
    Stack uptime: 2 minutes 56 seconds
    ?     NA         00:0b:86:8f:af:b7  NA        Away      ArubaS1500-48P   CF0000005   Not Set
    Stack uptime: 5 minutes 36 seconds
    1     Secondary  00:0b:86:8f:af:b7  Preset    Active    ArubaS1500-48P   CF0000005   Not Set
  • 5.  RE: Successfully deploying a stack
    Posted Dec 18, 2014 08:44 AM
    Fortunately, I've found that there is not a tiny space in the 6 of that serial thus member 0 had the wrong serial number in place. The stack is now up correctly.
    I guess its time for some glasses, lol.
    thanks!
