Suddenly, ap´s go down
  • 1.  Suddenly, ap´s go down
    Posted Mar 13, 2014 08:52 AM
    Hi all,
    I have same strange issues in my network from time to time.
    I have an environment with a M3 controller and 240 AP-61, and I have a specific vlan for ap´s. The AOS version is 6.1.3.9
    The problem is that suddenly, I can´t see my ssid and if see the controller, I have all my access points down, except one of them.
    Then I look at the switch where this access point is connected and I can see that the port is showing to me three mac address.
    I only should see the access point mac.
    SWITCH#sh mac address-table | include 4/0/47
    100 AP-MAC-ADDR DYNAMIC Gi4/0/47
    100 0218.0a03.9f80 DYNAMIC Gi4/0/47
    100 02b5.a903.9f80 DYNAMIC Gi4/0/47
    If I shutdown this port. all access point become up and it begins to work correctly.
    Any ideas?
  • 2.  RE: Suddenly, ap´s go down
    Posted Mar 13, 2014 11:11 AM
    Is that switch port configured any differently than the other AP ports?
  • 3.  RE: Suddenly, ap´s go down
    Posted Mar 13, 2014 11:43 AM
    this port has the same configuration than the other ports. In fact, I forgot to mention that this problem has happened with different access points and it happens in a random way.
    In this case, all access points are connected to switch ports in access mode to specific vlan.
  • 4.  RE: Suddenly, ap´s go down
    Posted Mar 13, 2014 12:42 PM
    When you're not experiencing problems I assume you are only seeing one MAC address per port right?
    Have you traced those MAC addresses to see what the devices are? Are they wired or wireless devices?
  • 5.  RE: Suddenly, ap´s go down
    Posted Mar 14, 2014 03:48 AM
    It is correct. When it is working without problems, I only see the access point MAC address in the switch.
    As a matter of fact, I´ve not seen these mac address in the switch "mac address table" or in the controller "user-table".
    These mac address are not well known vendor mac addresses and is for that I can´t trace these devices,
    I disable this port, and when I enable the port again, these mac addresses have disappeared and all access point have recovered.
