Original Message:
Sent: Apr 26, 2024 02:46 PM
Subject: Suitable Poe injector or bad setting
Enable Terminal Access in the Advanced Settings under Configuration > System and then SSH into the AP.
https://www.arubanetworks.com/techdocs/Instant_810_WebHelp/Content/instant-ug/prov-iap/access-iap-cli.htm
Then use the information from the link Carson sent to configure and enable IPM.
Original Message:
Sent: Apr 26, 2024 02:36 PM
Yes, that was my mistake. But how i could enable it? Is it possible without console? If not, how to use console port?
Original Message:
Sent: Apr 26, 2024 12:26 PM
You need to enable IPM, not disable.
https://www.arubanetworks.com/techdocs/Instant_810_WebHelp/Content/instant-ug/custom-iap-param/ipm.htm
Carson Hulcher, ACEX#110
Original Message:
Sent: Apr 26, 2024 12:21 PM
Okay, but, where could i set IPM to disable? Is it possible thru web gui? I don't have console cable.
Original Message:
Sent: Apr 26, 2024 11:54 AM
The 315 will run in restricted mode when powered by 802.3af and Intelligent Power Monitoring (IPM) is not enabled. Enable IPM for the AP to operate normally under most circumstances.
Original Message:
Sent: Apr 26, 2024 11:10 AM
Hello, I have a question about poe. I have some IAP-315 and need to power over ethernet. Almost everything works good, but power status is 802.3af. Is it necessary to switch on/off something to get full power of APs?
I used poe injector U-POE-at (product list https://dl.ubnt.com/datasheets/poe/PoE_Adapters_DS.pdf) that I had in my office. Could it be caused by wrong type of injector?
Thank for help or type of solution!
