Support Types / Simple IAP Deployments
  • 1.  Support Types / Simple IAP Deployments
    Posted Apr 07, 2015 01:35 PM
          I would like to know when designing a simple 10 IAP deployment what crucial support packages should be sold in order for the customer at a minimum recevie phone "Technical Support" along with "Aruba OS firmware upgrades"?
        Most of the Technical Phone support  packages that I found are tied in with indivudal support for specific modules that pertain to a "controller based" deployment.
    Riccardo
  • 2.  RE: Support Types / Simple IAP Deployments
    Posted Apr 07, 2015 01:42 PM
    I believe you are looking for IAP Arubacare support. The Sku should be something like
    SN1-IAP-215-RW
    SN1 is one year. Replace the 1 with anything from 2-5 for multi year support.
    215 would be replaced by the model you want support for, and 'rw' would be replaced by the region, likely -US or -RW, unless you are in Japan or Israel.
    Some more info about Arubacare support: http://www.arubanetworks.com/pdf/support/ds_arubacare_us.pdf
    _ELiasz
  • 3.  RE: Support Types / Simple IAP Deployments
    Posted Apr 07, 2015 01:45 PM
    HI,
    You can include Aruba central . it will be very handy for somebody who maintain small deployment with IAPs.
