Supportable regulatory domain for ap-205???
  • 1.  Supportable regulatory domain for ap-205???
    Posted Jul 12, 2016 02:09 AM
    Hi All,
    We are using 7010 controllerwith 50 nos of ap-205.
    But all the AP's are going to Air-Monitor mode.All the settings were correct and we checked the mode also.We configured the ap's in country code IN.
    Please let me know the solution. Thanks in advance.
    Gowtham Elamurugan
  • 2.  RE: Supportable regulatory domain for ap-205???
    Posted Jul 12, 2016 02:38 AM
    Please run the below commands and check for  "mode"
    #show rf dot11g-radio-profile "<your g radio profile>"
    #show rf dot11a-radio-profile "<your a radio profile>"
  • 3.  RE: Supportable regulatory domain for ap-205???
    Posted Jul 12, 2016 08:29 AM
    This should be what you have, you can verify with the same command on your controller. If you don't have these channels allowed, you can upgrade to the latest AOS or the latest DRT.
    (Aruba7005) #show ap allowed-channels country-code IN ap-type 205
    Allowed Channels for AP Type 205 Country Code "IN" Country "India"
    PHY Type                 Allowed Channels
    802.11g (indoor)         1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (indoor)         36 40 44 48 52 56 60 64 149 153 157 161 165
    802.11g (outdoor)        1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (outdoor)        149 153 157 161 165
    802.11g 40MHz (indoor)   1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    802.11a 40MHz (indoor)   36-40 44-48 52-56 60-64 149-153 157-161
    802.11g 40MHz (outdoor)  1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    802.11a 40MHz (outdoor)  149-153 157-161
    802.11a 80MHz (indoor)   36-48 52-64 149-161
    802.11a 80MHz (outdoor)  149-161
    802.11a (DFS)            None
  • 4.  RE: Supportable regulatory domain for ap-205???
    Posted Jul 13, 2016 02:12 AM
    Hello jerrod,
    Thanks and it works.
    In 6.4.1.0 version, the controllerdoesnt support channels for AP205.
    After upgrading to higher version (6.4.2.15) i found that it supports for AP-205.
    Gowtham
  • 5.  RE: Supportable regulatory domain for ap-205???
    Posted Jul 13, 2016 02:09 AM
    Hello Suman,
    Thanks for the reply.
    Have checked the commands and the radios are in "ap-mode" only.
    Found that,in the firmware version 6.4.1.0  wont support for ap-205 channel in country code "IN".
    Upgrdation to 6.4.2.15 helps to sort the issue.
    Gowtham
