Survivability eap-tls
  • 1.  Survivability eap-tls
    Posted Jul 11, 2016 02:45 AM
    Hi
    We have serveral remote locations which have a controller installed. The RADIUS servers are located at HQ office. We are running EAP-TLS on our PCs. When we had a WAN outage all clients drop off the network due to the lost connection to RADIUS. To try to fix this issue, I have enabled auth-Survivability on the controllers. What I have understand so far, is that auth-Survivability works will for PEAP. For EAP-TLS a certificate has to be installed on the controller to be used with auth-Survivability.
    Our certificate chain is CA, intermidiate and client certificate.
    Which certificate(s) should I use with auth.Survivability ?
    BR
    Vollelv
  • 2.  RE: Survivability eap-tls
    Posted Jul 11, 2016 02:46 AM
    The RADIUS server certificate needs to be installed on the controller along with the rest of the trust chain.
  • 3.  RE: Survivability eap-tls
    Posted Jul 11, 2016 02:51 AM
    Thanks for the replay.
    Is it possible to export the certificate with the chain from ClearPass ?
    BR
    Vollelv
  • 4.  RE: Survivability eap-tls
    Posted Jul 11, 2016 03:02 AM
    ClearPass will export as key and cert. You can use openssl to convert it to a PFX with chain.
  • 5.  RE: Survivability eap-tls
    Posted Jul 11, 2016 04:07 AM
    Thanks again.
    I have now uploaded the certificate on the controller and added it to auth-survivalibility.
    I have not yet tested that it really works. Am I right that a client can reauthenticate as long hi has a record in the auth-survivaliblity-cache ?
    We also have a lot of AP clusters were auth-survivaliblity is activated. Should I upload the ClearPass certicicate as an auth server certificate on the master AP ?
    BR
    Vollelv
  • 6.  RE: Survivability eap-tls
    Posted Jul 11, 2016 12:39 PM
    Yes, auth-survivability works for clients who authenticated prior to the loss of connectivity to the RADIUS server.
  • 7.  RE: Survivability eap-tls
    Posted Jul 12, 2016 01:16 AM
    Thanks !
    Do you know anything about my last question ?
    BR
    Vollelv
  • 8.  RE: Survivability eap-tls
    Posted Jul 19, 2016 10:37 AM
    I have run a test today on a EAP-TLS client. The client was not able to reconnect. I have checked that the client was cached on the controller.
    BR
    Bjørn Vollelv
