Network Management
swap memory usage on airwave
  • 1.  swap memory usage on airwave
    Posted Mar 15, 2018 01:24 PM
    Hello community:
    since January 2018, my swap is reaching its maximum capacity, why does it happen? reports are taking to long to be generated. could it be the cause of full swap?
    [root@localhost ~]# free -m
                 total       used       free     shared    buffers     cached
    Mem:         32057      31825        232       2753         40       3190
    -/+ buffers/cache:      28594       3463
    Swap:         4095       4095          0
  • 2.  RE: swap memory usage on airwave
    Posted Mar 15, 2018 11:45 PM
    For a healthy Linux box Swap is typically not a concern. The only concern we should have is if total used memory - (buffers + cache) is greater than the total memory. In your scenario,
    Swap:         4095       4095          0
    31825/32057 is used, but if you remove buffers/cache, only 28594/32057 is used.
    Swap would have been got used at some point of time and if we have enough free RAM we dont have to be concerned of this, this should eventually come down or we can manually clear it.
    There is a Linux kernel parameter known as Swappiness which determines how a Linux system will use swap space: http://en.wikipedia.org/wiki/Swappiness
    By default, including on AirWave, this is set to 60. A value of 0 means swap will only be used if there no available memory, meaning the total used memory - (buffers + cache) has exceeded the available memory on the system. A value of 100 indicates that the kernel will attempt to swap any inactive memory pages to disk as often as possible. There is a drawback to setting this value too low or too high as explained in the Wikipedia article.
    What this means for AirWave is that customers will see swap being used regularly if their system is active, even if they have more than adequate free memory available.
    Below KB link should have more explanation on this,
    https://community.arubanetworks.com/t5/Monitoring-Management-Location/How-does-AirWave-use-memory-and-swap-space-and-when-is-it-a/ta-p/179984
    You can also get the help of TAC to check the overall health of the server and set appropriate swappiness value.
