Wired Intelligent Edge
last person joined: 10 hours ago
Switch 2930F member stack rebooting
This thread has been viewed 32 times
  • 1.  Switch 2930F member stack rebooting
    Posted Oct 08, 2021 10:13 AM
    I am having problem with a stack of 5 switches. Two member of the stack reboot every day.
    Member  1 and 5 reboot often, i already change VSF port and cable.
    Here the show log:
    10/06/21 00:17:03 00076 ports: ST2-CMDR: port 1/46 is now on-line
    I 10/06/21 00:17:03 00076 ports: ST2-CMDR: port 1/33 is now on-line
    I 10/06/21 00:17:03 00076 ports: ST2-CMDR: port 1/8 is now on-line
    I 10/06/21 00:17:04 00076 ports: ST2-CMDR: port 1/36 is now on-line
    I 10/06/21 00:17:07 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3895
    I 10/06/21 00:17:34 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3896
    I 10/06/21 00:17:38 00077 ports: ST2-CMDR: port 2/23 is now off-line
    I 10/06/21 00:17:40 00076 ports: ST2-CMDR: port 2/23 is now on-line
    I 10/06/21 00:17:40 05824 ports: ST2-CMDR: Port 2/23: PD stopped responding to
    LLDP PoE TLVs from PSE. Previous LLDP negotiated power values will
    be retained.
    I 10/06/21 00:18:09 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3897
    I 10/06/21 00:18:34 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3898
    I 10/06/21 00:19:00 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3899
    I 10/06/21 00:23:39 00077 ports: ST2-CMDR: port 1/20 is now off-line
    I 10/06/21 00:23:42 00076 ports: ST2-CMDR: port 1/20 is now on-line
    I 10/06/21 00:23:42 05824 ports: ST2-CMDR: Port 1/20: PD stopped responding to
    be retained.
    I 10/06/21 00:24:45 00077 ports: ST2-CMDR: port 2/23 is now off-line
    I 10/06/21 00:24:48 00076 ports: ST2-CMDR: port 2/23 is now on-line
    I 10/06/21 00:24:48 05824 ports: ST2-CMDR: Port 2/23: PD stopped responding to
    be retained.
    I 10/06/21 00:25:06 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 00:25:10 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 00:28:23 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 00:36:24 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 00:36:28 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 00:45:26 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 00:47:42 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 00:47:46 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 00:57:12 00077 ports: ST2-CMDR: port 4/38 is now off-line
    I 10/06/21 00:57:14 00076 ports: ST2-CMDR: port 4/38 is now on-line
    I 10/06/21 00:58:59 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 00:59:04 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 01:02:32 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 01:10:17 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 01:10:21 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 01:19:39 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 01:21:37 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 01:21:41 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 01:32:54 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 01:32:58 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 01:36:43 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 01:44:11 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 01:44:16 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 01:53:49 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 01:55:29 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 01:55:34 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 02:06:47 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 02:06:51 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 02:10:53 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 02:18:07 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 02:18:11 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 02:27:56 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 02:29:24 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 02:29:29 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 02:40:43 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 02:40:47 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 02:45:00 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 02:52:00 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 02:52:04 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 03:02:06 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 03:03:17 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 03:03:22 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 03:14:37 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 03:14:42 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 03:19:09 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 03:25:55 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 03:25:59 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 03:36:14 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 03:37:12 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 03:37:17 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 03:48:32 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 03:48:36 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 03:53:21 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 03:59:50 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 03:59:54 00076 ports: ST2-CMDR: port 5/30 is now on-line
    W 10/06/21 04:03:47 00236 snmp: ST2-CMDR: Security access violation from
    ......                  for the community name or user name : public
    I 10/06/21 04:03:52 03362 auth: ST2-CMDR: User 'unknown' logged in from
    x.x.x.x to TELNET session
    I 10/06/21 04:03:52 00179 mgr: ST2-CMDR: SME TELNET from x.x.x.x  - OPERATOR
    Mode
    I 10/06/21 04:03:57 03363 auth: ST2-CMDR: User 'unknown' logged out of TELNET
    session from x.x.x.x.140
    W 10/06/21 04:04:02 00419 auth: ST2-CMDR: Invalid user name/password on TELNET
    session User 'GET / HTTP/1.0' is trying to login from x.x.x.x.140
    W 10/06/21 04:04:16 00419 auth: ST2-CMDR: Invalid user name/password on TELNET
    session User 'OPTIONS sip:nm SIP/2.0' is trying to login from
    x.x.x.x.140
    W 10/06/21 04:04:21 00419 auth: ST2-CMDR: Invalid user name/password on TELNET
    session User 'From: <sip:nm@nm>;tag=root' is trying to login from
    x.x.x.x.140
    I 10/06/21 04:10:25 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 04:11:10 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 04:11:14 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 04:22:27 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 04:22:32 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 04:27:29 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 04:33:53 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 04:33:57 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 04:44:34 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 04:45:10 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 04:45:15 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 04:56:28 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 04:56:32 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 05:01:40 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 05:07:48 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 05:07:51 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 05:18:46 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 05:19:05 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 05:19:10 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 05:30:25 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 05:30:29 00076 ports: ST2-CMDR: port 5/30 is now on-line
    W 10/06/21 05:31:19 05919 ssh: ST2-CMDR: Login failed for SSH session from
    x.x.x.x.140 due to no matching host key algorithm.
    W 10/06/21 05:31:21 05919 ssh: ST2-CMDR: Login failed for SSH session from
    W 10/06/21 05:31:22 05919 ssh: ST2-CMDR: Login failed for SSH session from
    W 10/06/21 05:31:23 05919 ssh: ST2-CMDR: Login failed for SSH session from
    W 10/06/21 05:31:33 05918 ssh: ST2-CMDR: Login failed for SSH session from
    x.x.x.x.140 due to no matching key exchange algorithm.
    W 10/06/21 05:34:14 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    session User 'vulnerability.scan' is trying to login from
    x.x.x.x.140
    x.x.x.x.140
    W 10/06/21 05:34:19 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    x.x.x.x.140
    W 10/06/21 05:34:24 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    session User 'vulnerabilityscan.fw' is trying to login from
    x.x.x.x.140
    x.x.x.x.140
    W 10/06/21 05:34:29 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    x.x.x.x.140
    W 10/06/21 05:34:34 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    x.x.x.x.140
    x.x.x.x.140
    W 10/06/21 05:34:39 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    x.x.x.x.140
    W 10/06/21 05:35:05 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : public
    W 10/06/21 05:35:12 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : exfo-snmpv3
    I 10/06/21 05:35:52 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 05:41:42 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 05:41:46 00076 ports: ST2-CMDR: port 5/30 is now on-line
    W 10/06/21 05:42:18 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : exfoscan
    W 10/06/21 05:42:23 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : password
    W 10/06/21 05:42:24 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    session User 'admin' is trying to login from x.x.x.x.140
    W 10/06/21 05:42:29 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:42:31 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    session User 'root' is trying to login from x.x.x.x.140
    W 10/06/21 05:42:36 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:42:37 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : openview
    W 10/06/21 05:42:38 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:42:43 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:42:44 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    session User 'jack' is trying to login from x.x.x.x.140
    W 10/06/21 05:42:49 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:42:51 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:42:51 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : admin
    W 10/06/21 05:42:56 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:42:58 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:03 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:07 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:07 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : agent
    W 10/06/21 05:43:12 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:15 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    session User 'zyfwp' is trying to login from x.x.x.x.140
    W 10/06/21 05:43:20 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:22 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : all
    W 10/06/21 05:43:22 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:27 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:29 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:34 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : secret
    W 10/06/21 05:43:34 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:37 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:42 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:45 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    session User 'vmware' is trying to login from x.x.x.x.140
    W 10/06/21 05:43:48 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : snmpd
    W 10/06/21 05:43:50 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:52 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:57 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:43:59 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    session User 'remotessh' is trying to login from x.x.x.x.140
    W 10/06/21 05:44:01 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : manager
    W 10/06/21 05:44:04 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:44:06 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    session User 'guest' is trying to login from x.x.x.x.140
    W 10/06/21 05:44:11 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    I 10/06/21 05:44:11 04753 system: ST2-CMDR: Event log buffer has wrapped; older
    logs will be overwritten.
    W 10/06/21 05:44:13 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    session User 'suse-gm' is trying to login from x.x.x.x.140
    W 10/06/21 05:44:15 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : system
    W 10/06/21 05:44:18 00419 auth: ST2-CMDR: Invalid user name/password on SSH
    W 10/06/21 05:44:27 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : ANYCOM
    W 10/06/21 05:44:40 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : public (3 times
    in 60 seconds)
    W 10/06/21 05:44:52 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : ilmi
    W 10/06/21 05:45:05 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : ILMI
    W 10/06/21 05:45:18 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : Secret C0de
    W 10/06/21 05:45:30 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : all private
    W 10/06/21 05:45:42 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : rmon_admin
    W 10/06/21 05:45:54 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : NoGaH$@!
    W 10/06/21 05:46:06 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : security
    W 10/06/21 05:46:19 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : tivoli
    W 10/06/21 05:46:31 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : community
    W 10/06/21 05:46:43 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : monitor
    W 10/06/21 05:46:55 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : cable-docsis
    W 10/06/21 05:47:07 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : OrigEquipMfr
    W 10/06/21 05:47:19 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : proxy
    W 10/06/21 05:47:31 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : private
    W 10/06/21 05:47:43 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : hp_admin
    W 10/06/21 05:47:55 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : cascade
    W 10/06/21 05:48:07 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : write
    W 10/06/21 05:48:19 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : default
    W 10/06/21 05:48:31 00236 snmp: ST2-CMDR: Security access violation from
    W 10/06/21 05:48:43 00236 snmp: ST2-CMDR: Security access violation from
    x.x.x.x.140 for the community name or user name : read
    W 10/06/21 05:48:55 00236 snmp: ST2-CMDR: Security access violation from
    W 10/06/21 05:49:38 05918 ssh: ST2-CMDR: Login failed for SSH session from
    W 10/06/21 05:51:12 00236 snmp: ST2-CMDR: Security access violation from
    in 60 seconds)
    I 10/06/21 05:52:55 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 05:52:59 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 05:53:04 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 06:04:20 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 06:04:24 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 06:09:59 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 06:15:37 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 06:15:41 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 06:26:56 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 06:27:00 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 06:27:02 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 06:38:13 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 06:38:17 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 06:44:06 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 06:49:30 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 06:49:35 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 07:00:50 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 07:00:54 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 07:01:11 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 07:12:15 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 07:12:19 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 07:18:16 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 07:23:35 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 07:23:39 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 07:34:53 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 07:34:57 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 07:35:21 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 07:46:10 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 07:46:14 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 07:52:24 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 07:57:30 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 07:57:34 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 08:08:47 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 08:08:51 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 08:09:28 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 08:11:52 00076 ports: ST2-CMDR: port 4/17 is now on-line
    I 10/06/21 08:11:54 00077 ports: ST2-CMDR: port 4/17 is now off-line
    I 10/06/21 08:11:58 00076 ports: ST2-CMDR: port 4/17 is now on-line
    I 10/06/21 08:12:14 00077 ports: ST2-CMDR: port 4/17 is now off-line
    I 10/06/21 08:12:17 00076 ports: ST2-CMDR: port 4/17 is now on-line
    I 10/06/21 08:20:07 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 08:20:11 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 08:26:34 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 08:31:25 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 08:31:29 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 08:42:42 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 08:42:46 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 08:43:40 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 08:54:02 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 08:54:06 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 08:54:55 00077 ports: ST2-CMDR: port 4/38 is now off-line
    I 10/06/21 08:54:57 00076 ports: ST2-CMDR: port 4/38 is now on-line
    I 10/06/21 09:00:46 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 09:05:19 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 09:05:23 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 09:06:29 00077 ports: ST2-CMDR: port 5/45 is now off-line
    I 10/06/21 09:09:11 00076 ports: ST2-CMDR: port 5/45 is now on-line
    I 10/06/21 09:09:39 00077 ports: ST2-CMDR: port 5/45 is now off-line
    I 10/06/21 09:09:41 00076 ports: ST2-CMDR: port 5/45 is now on-line
    I 10/06/21 09:16:39 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 09:16:43 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 09:17:51 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 09:27:57 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 09:28:01 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 09:34:54 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 09:39:14 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 09:39:18 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 09:50:34 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 09:50:38 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 09:52:00 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 09:56:33 03362 auth: ST2-CMDR: User 'admin' logged in from
    x.x.x.x.123.19 to SSH session
    I 10/06/21 09:56:36 00179 mgr: ST2-CMDR: SME SSH from x.x.x.x.123.19 - MANAGER
    Mode
    I 10/06/21 10:01:52 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 10:01:56 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 10:03:07 00077 ports: ST2-CMDR: port 4/38 is now off-line
    I 10/06/21 10:03:09 00076 ports: ST2-CMDR: port 4/38 is now on-line
    I 10/06/21 10:03:29 00077 ports: ST2-CMDR: port 4/17 is now off-line
    I 10/06/21 10:09:06 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 10:13:11 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 10:13:15 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 10:24:29 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 10:24:33 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 10:26:10 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 10:35:47 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 10:35:51 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 10:43:17 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 10:47:06 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 10:47:10 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 10:58:24 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 10:58:28 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 11:00:22 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 11:09:44 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 11:09:48 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 11:15:21 03003 system: ST2-CMDR: Configuration hash calculation
    started.
    I 10/06/21 11:15:21 03004 system: ST2-CMDR: Configuration hash calculation
    finished.
    I 10/06/21 11:17:27 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 11:21:01 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 11:21:05 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 11:30:39 04992 vsf: ST2-CMDR: VSF port 2/51 is in error state
    I 10/06/21 11:30:39 04992 vsf: ST2-CMDR: VSF link 1 is down
    W 10/06/21 11:30:39 03270 stacking: ST2-CMDR: Topology is a Chain
    W 10/06/21 11:30:39 03258 stacking: ST2-CMDR: Member switch with Member ID 1
    removed due to loss of communication
    I 10/06/21 11:30:39 03272 stacking: ST2-CMDR: Stack fragment active
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/7 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/8 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/9 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/10 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/12 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/14 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/15 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/16 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/20 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/23 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/24 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/26 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/27 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/31 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/32 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/33 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/35 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/36 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/38 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/40 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/41 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/42 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/43 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/45 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/46 is now off-line
    I 10/06/21 11:30:39 00077 ports: ST2-CMDR: port 1/48 in Trk2 is now off-line
    I 10/06/21 11:30:39 04992 vsf: ST5-MMBR: VSF port 5/50 is in error state
    I 10/06/21 11:30:39 04992 vsf: ST2-CMDR: VSF port 2/51 is down
    I 10/06/21 11:30:39 04992 vsf: ST5-MMBR: VSF link 2 is down
    I 10/06/21 11:30:39 04992 vsf: ST5-MMBR: VSF port 5/50 is down
    I 10/06/21 11:31:30 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3900
    I 10/06/21 11:32:02 04988 vsf: ST5-MMBR: VSF link 2 port 5/50 up: Peer validated
    I 10/06/21 11:32:02 04987 vsf: ST5-MMBR: VSF link 2 up: Peer has mac
    64e881-0c1b80
    I 10/06/21 11:32:03 04988 vsf: ST2-CMDR: VSF link 1 port 2/51 up: Peer validated
    I 10/06/21 11:32:03 04987 vsf: ST2-CMDR: VSF link 1 up: Peer has mac
    64e881-0c1b80
    I 10/06/21 11:32:06 04992 vsf: ST5-MMBR: VSF link 2 is up
    I 10/06/21 11:32:07 04992 vsf: ST2-CMDR: VSF link 1 is up
    I 10/06/21 11:32:07 03271 stacking: ST2-CMDR: Topology is a Ring
    I 10/06/21 11:32:07 03803 chassis: ST2-CMDR: System Self test completed on
    1/1-52
    I 10/06/21 11:32:07 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3902
    I 10/06/21 11:32:10 02555 chassis: ST2-CMDR: Co-processor Ready
    I 10/06/21 11:32:10 00256 ports: ST2-CMDR: Port 1/50 is reserved for VSF use
    I 10/06/21 11:32:10 00256 ports: ST2-CMDR: Port 1/52 is reserved for VSF use
    I 10/06/21 11:32:10 00539 stacking: ST2-CMDR: Initial sync to member 1 starting
    I 10/06/21 11:32:10 00405 ports: ST2-CMDR: port 1/50 xcvr hot-swap insert.
    I 10/06/21 11:32:10 00405 ports: ST2-CMDR: port 1/52 xcvr hot-swap insert.
    I 10/06/21 11:32:13 00076 ports: ST2-CMDR: port 1/26 is now on-line
    I 10/06/21 11:32:13 00435 ports: ST2-CMDR: port 1/48 is Blocked by LACP
    I 10/06/21 11:32:15 00539 stacking: ST2-CMDR: Initial sync to member 1 complete
    I 01/01/90 00:00:16 03802 chassis: ST1-UKWN: System Self test started on Master
    I 01/01/90 00:00:16 03803 chassis: ST1-UKWN: System Self test completed on
    Master
    I 01/01/90 00:00:17 03802 chassis: ST1-UKWN: System Self test started on Master
    I 01/01/90 00:00:17 03803 chassis: ST1-UKWN: System Self test completed on
    Master
    M 01/01/90 00:00:18 02796 chassis: ST1-UKWN: Internal power supply 1 inserted.
    Total fault count: 0.
    M 01/01/90 00:00:18 02797 chassis: ST1-UKWN: Internal power supply 1 is OK.
    M 01/01/90 00:00:18 02798 chassis: ST1-UKWN: Internal power supply 1 main PoE
    power OK. Total fault count: 0
    I 01/01/90 00:00:18 02550 chassis: ST1-UKWN: Requesting Co-processor OS image
    location in flash.
    I 01/01/90 00:00:18 02552 chassis: ST1-UKWN: Loading of Co-processor OS image in
    progress.
    I 01/01/90 00:00:19 02553 chassis: ST1-UKWN: Loading of Co-processor OS image
    complete.
    I 01/01/90 00:00:20 03802 chassis: ST1-UKWN: System Self test started on 1/1-52
    I 01/01/90 00:00:33 03803 chassis: ST1-UKWN: System Self test completed on
    1/1-52
    I 01/01/90 00:00:41 04988 vsf: ST1-UKWN: VSF link 1 port 1/50 up: Peer validated
    I 01/01/90 00:00:41 04987 vsf: ST1-UKWN: VSF link 1 up: Peer has mac
    64e881-0dc000
    I 01/01/90 00:00:41 04992 vsf: ST1-UKWN: VSF link 1 is up
    I 01/01/90 00:00:41 04988 vsf: ST1-UKWN: VSF link 2 port 1/52 up: Peer validated
    I 01/01/90 00:00:41 04987 vsf: ST1-UKWN: VSF link 2 up: Peer has mac
    64e881-0c2fc0
    I 01/01/90 00:00:41 04992 vsf: ST1-UKWN: VSF link 2 is up
    I 10/06/21 11:32:15 03260 stacking: ST1-MMBR: Member booted
    I 10/06/21 11:32:15 03272 stacking: ST2-CMDR: Stack active
    I 10/06/21 11:32:15 00061 system: ST1-MMBR: ------------------------------------
    I 10/06/21 11:32:15 00062 system: ST1-MMBR: Member 1 went down without saving
    crash information
    M 10/06/21 11:32:15 03001 system: ST1-MMBR: System reboot due to Power Failure
    I 10/06/21 11:32:18 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3903
    I 10/06/21 11:32:18 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 11:32:20 00076 ports: ST2-CMDR: port 1/48 in Trk2 is now on-line
    I 10/06/21 11:32:23 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/7 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/7 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/8 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/8 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/9 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/9 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/12 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/12 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/16 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/16 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/20 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/20 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/23 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/23 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/24 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/24 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/27 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/27 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/31 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/31 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/32 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/32 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/33 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/33 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/38 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/38 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/40 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/40 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/45 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/45 Applying Power to PD.
    I 10/06/21 11:32:42 00560 ports: ST2-CMDR: port 1/46 PD Detected.
    I 10/06/21 11:32:42 00561 ports: ST2-CMDR: port 1/46 Applying Power to PD.
    I 10/06/21 11:32:43 00560 ports: ST2-CMDR: port 1/14 PD Detected.
    I 10/06/21 11:32:43 00561 ports: ST2-CMDR: port 1/14 Applying Power to PD.
    I 10/06/21 11:32:43 00560 ports: ST2-CMDR: port 1/15 PD Detected.
    I 10/06/21 11:32:43 00561 ports: ST2-CMDR: port 1/15 Applying Power to PD.
    I 10/06/21 11:32:43 00560 ports: ST2-CMDR: port 1/35 PD Detected.
    I 10/06/21 11:32:43 00561 ports: ST2-CMDR: port 1/35 Applying Power to PD.
    I 10/06/21 11:32:43 00560 ports: ST2-CMDR: port 1/36 PD Detected.
    I 10/06/21 11:32:43 00561 ports: ST2-CMDR: port 1/36 Applying Power to PD.
    I 10/06/21 11:32:43 00560 ports: ST2-CMDR: port 1/41 PD Detected.
    I 10/06/21 11:32:43 00561 ports: ST2-CMDR: port 1/41 Applying Power to PD.
    I 10/06/21 11:32:43 00560 ports: ST2-CMDR: port 1/42 PD Detected.
    I 10/06/21 11:32:43 00561 ports: ST2-CMDR: port 1/42 Applying Power to PD.
    I 10/06/21 11:32:43 00560 ports: ST2-CMDR: port 1/43 PD Detected.
    I 10/06/21 11:32:43 00561 ports: ST2-CMDR: port 1/43 Applying Power to PD.
    I 10/06/21 11:32:43 00076 ports: ST2-CMDR: port 1/45 is now on-line
    I 10/06/21 11:32:43 00076 ports: ST2-CMDR: port 1/31 is now on-line
    I 10/06/21 11:32:43 00076 ports: ST2-CMDR: port 1/12 is now on-line
    I 10/06/21 11:32:43 00076 ports: ST2-CMDR: port 1/23 is now on-line
    I 10/06/21 11:32:43 00076 ports: ST2-CMDR: port 1/7 is now on-line
    I 10/06/21 11:32:44 00076 ports: ST2-CMDR: port 1/27 is now on-line
    I 10/06/21 11:32:44 00076 ports: ST2-CMDR: port 1/16 is now on-line
    I 10/06/21 11:32:44 00560 ports: ST2-CMDR: port 1/10 PD Detected.
    I 10/06/21 11:32:44 00561 ports: ST2-CMDR: port 1/10 Applying Power to PD.
    I 10/06/21 11:32:44 00076 ports: ST2-CMDR: port 1/9 is now on-line
    I 10/06/21 11:32:44 00076 ports: ST2-CMDR: port 1/40 is now on-line
    I 10/06/21 11:32:44 00076 ports: ST2-CMDR: port 1/46 is now on-line
    I 10/06/21 11:32:44 00076 ports: ST2-CMDR: port 1/35 is now on-line
    I 10/06/21 11:32:44 00076 ports: ST2-CMDR: port 1/20 is now on-line
    I 10/06/21 11:32:44 00076 ports: ST2-CMDR: port 1/32 is now on-line
    I 10/06/21 11:32:44 00076 ports: ST2-CMDR: port 1/24 is now on-line
    I 10/06/21 11:32:44 00076 ports: ST2-CMDR: port 1/33 is now on-line
    I 10/06/21 11:32:44 00076 ports: ST2-CMDR: port 1/38 is now on-line
    I 10/06/21 11:32:44 00076 ports: ST2-CMDR: port 1/42 is now on-line
    I 10/06/21 11:32:45 00076 ports: ST2-CMDR: port 1/8 is now on-line
    I 10/06/21 11:32:45 00076 ports: ST2-CMDR: port 1/14 is now on-line
    I 10/06/21 11:32:45 00076 ports: ST2-CMDR: port 1/41 is now on-line
    I 10/06/21 11:32:45 00076 ports: ST2-CMDR: port 1/10 is now on-line
    I 10/06/21 11:32:45 00076 ports: ST2-CMDR: port 1/36 is now on-line
    I 10/06/21 11:32:45 00076 ports: ST2-CMDR: port 1/15 is now on-line
    I 10/06/21 11:32:45 00076 ports: ST2-CMDR: port 1/43 is now on-line
    W 10/06/21 11:32:54 03270 stacking: ST2-CMDR: Topology is a Chain
    W 10/06/21 11:32:54 03258 stacking: ST2-CMDR: Member switch with Member ID 5
    I 10/06/21 11:32:54 03272 stacking: ST2-CMDR: Stack fragment active
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/2 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/5 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/6 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/7 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/8 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/22 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/23 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/24 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/26 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/27 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/32 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/34 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/35 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/37 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/38 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/39 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/42 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/43 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/45 is now off-line
    I 10/06/21 11:32:54 00077 ports: ST2-CMDR: port 5/47 is now off-line
    I 10/06/21 11:32:54 04992 vsf: ST1-MMBR: VSF port 1/50 is in error state
    I 10/06/21 11:32:54 04992 vsf: ST4-MMBR: VSF port 4/52 is in error state
    I 10/06/21 11:32:54 04992 vsf: ST1-MMBR: VSF link 1 is down
    I 10/06/21 11:32:54 04992 vsf: ST4-MMBR: VSF link 2 is down
    I 10/06/21 11:32:54 04992 vsf: ST4-MMBR: VSF port 4/52 is down
    I 10/06/21 11:32:54 04992 vsf: ST1-MMBR: VSF port 1/50 is down
    I 10/06/21 11:32:56 00077 ports: ST2-CMDR: port 1/16 is now off-line
    I 10/06/21 11:32:56 00077 ports: ST2-CMDR: port 1/27 is now off-line
    I 10/06/21 11:32:56 00077 ports: ST2-CMDR: port 1/46 is now off-line
    I 10/06/21 11:32:56 00077 ports: ST2-CMDR: port 1/32 is now off-line
    I 10/06/21 11:32:56 00077 ports: ST2-CMDR: port 1/24 is now off-line
    I 10/06/21 11:32:56 00077 ports: ST2-CMDR: port 1/33 is now off-line
    I 10/06/21 11:32:56 00077 ports: ST2-CMDR: port 1/8 is now off-line
    I 10/06/21 11:32:57 00077 ports: ST2-CMDR: port 1/36 is now off-line
    I 10/06/21 11:32:59 00076 ports: ST2-CMDR: port 1/16 is now on-line
    I 10/06/21 11:33:00 00076 ports: ST2-CMDR: port 1/27 is now on-line
    I 10/06/21 11:33:00 00076 ports: ST2-CMDR: port 1/46 is now on-line
    I 10/06/21 11:33:00 00076 ports: ST2-CMDR: port 1/32 is now on-line
    I 10/06/21 11:33:00 00076 ports: ST2-CMDR: port 1/24 is now on-line
    I 10/06/21 11:33:00 00076 ports: ST2-CMDR: port 1/33 is now on-line
    I 10/06/21 11:33:00 00076 ports: ST2-CMDR: port 1/8 is now on-line
    I 10/06/21 11:33:01 00076 ports: ST2-CMDR: port 1/36 is now on-line
    I 10/06/21 11:33:22 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3904
    I 10/06/21 11:34:00 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3905
    I 10/06/21 11:34:17 04988 vsf: ST1-MMBR: VSF link 1 port 1/50 up: Peer validated
    I 10/06/21 11:34:17 04987 vsf: ST1-MMBR: VSF link 1 up: Peer has mac
    64e881-0dc000
    I 10/06/21 11:34:17 04988 vsf: ST4-MMBR: VSF link 2 port 4/52 up: Peer validated
    I 10/06/21 11:34:17 04987 vsf: ST4-MMBR: VSF link 2 up: Peer has mac
    64e881-0dc000
    I 10/06/21 11:34:22 04992 vsf: ST1-MMBR: VSF link 1 is up
    I 10/06/21 11:34:22 03271 stacking: ST2-CMDR: Topology is a Ring
    I 10/06/21 11:34:22 03803 chassis: ST2-CMDR: System Self test completed on
    5/1-52
    I 10/06/21 11:34:22 04992 vsf: ST4-MMBR: VSF link 2 is up
    I 10/06/21 11:34:22 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3907
    I 10/06/21 11:34:25 02555 chassis: ST2-CMDR: Co-processor Ready
    I 10/06/21 11:34:25 00256 ports: ST2-CMDR: Port 5/50 is reserved for VSF use
    I 10/06/21 11:34:25 00256 ports: ST2-CMDR: Port 5/51 is reserved for VSF use
    I 10/06/21 11:34:25 00539 stacking: ST2-CMDR: Initial sync to member 5 starting
    I 10/06/21 11:34:25 00405 ports: ST2-CMDR: port 5/50 xcvr hot-swap insert.
    I 10/06/21 11:34:25 00405 ports: ST2-CMDR: port 5/51 xcvr hot-swap insert.
    I 10/06/21 11:34:27 00076 ports: ST2-CMDR: port 5/47 is now on-line
    I 10/06/21 11:34:28 00076 ports: ST2-CMDR: port 5/7 is now on-line
    I 10/06/21 11:34:28 00076 ports: ST2-CMDR: port 5/45 is now on-line
    I 10/06/21 11:34:28 00539 stacking: ST2-CMDR: Initial sync to member 5 complete
    I 01/01/90 00:00:16 03802 chassis: ST5-UKWN: System Self test started on Master
    I 01/01/90 00:00:16 03803 chassis: ST5-UKWN: System Self test completed on
    Master
    I 01/01/90 00:00:17 03802 chassis: ST5-UKWN: System Self test started on Master
    I 01/01/90 00:00:17 03803 chassis: ST5-UKWN: System Self test completed on
    Master
    I 10/06/21 11:34:28 03260 stacking: ST5-MMBR: Member booted
    I 10/06/21 11:34:28 03272 stacking: ST2-CMDR: Stack active
    M 01/01/90 00:00:18 02796 chassis: ST5-UKWN: Internal power supply 1 inserted.
    M 01/01/90 00:00:18 02797 chassis: ST5-UKWN: Internal power supply 1 is OK.
    M 01/01/90 00:00:18 02798 chassis: ST5-UKWN: Internal power supply 1 main PoE
    I 01/01/90 00:00:18 02550 chassis: ST5-UKWN: Requesting Co-processor OS image
    location in flash.
    I 01/01/90 00:00:18 02552 chassis: ST5-UKWN: Loading of Co-processor OS image in
    progress.
    I 01/01/90 00:00:19 02553 chassis: ST5-UKWN: Loading of Co-processor OS image
    complete.
    I 01/01/90 00:00:20 03802 chassis: ST5-UKWN: System Self test started on 5/1-52
    I 01/01/90 00:00:33 03803 chassis: ST5-UKWN: System Self test completed on
    5/1-52
    I 01/01/90 00:00:41 04988 vsf: ST5-UKWN: VSF link 2 port 5/50 up: Peer validated
    I 01/01/90 00:00:41 04987 vsf: ST5-UKWN: VSF link 2 up: Peer has mac
    64e881-0c1b80
    I 01/01/90 00:00:41 04992 vsf: ST5-UKWN: VSF link 2 is up
    I 01/01/90 00:00:41 04988 vsf: ST5-UKWN: VSF link 1 port 5/51 up: Peer validated
    I 01/01/90 00:00:41 04987 vsf: ST5-UKWN: VSF link 1 up: Peer has mac
    64e881-0c3fc0
    I 01/01/90 00:00:41 04992 vsf: ST5-UKWN: VSF link 1 is up
    I 10/06/21 11:34:28 00061 system: ST5-MMBR: ------------------------------------
    I 10/06/21 11:34:28 00062 system: ST5-MMBR: Member 5 went down without saving
    crash information
    M 10/06/21 11:34:28 03001 system: ST5-MMBR: System reboot due to Power Failure
    I 10/06/21 11:34:28 00076 ports: ST2-CMDR: port 5/2 is now on-line
    I 10/06/21 11:34:30 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 11:34:30 00076 ports: ST2-CMDR: port 5/8 is now on-line
    I 10/06/21 11:34:44 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3908
    I 10/06/21 11:34:46 00076 ports: ST2-CMDR: port 5/22 is now on-line
    I 10/06/21 11:34:55 00560 ports: ST2-CMDR: port 5/5 PD Detected.
    I 10/06/21 11:34:55 00561 ports: ST2-CMDR: port 5/5 Applying Power to PD.
    I 10/06/21 11:34:55 00560 ports: ST2-CMDR: port 5/6 PD Detected.
    I 10/06/21 11:34:55 00561 ports: ST2-CMDR: port 5/6 Applying Power to PD.
    I 10/06/21 11:34:55 00560 ports: ST2-CMDR: port 5/23 PD Detected.
    I 10/06/21 11:34:55 00561 ports: ST2-CMDR: port 5/23 Applying Power to PD.
    I 10/06/21 11:34:55 00560 ports: ST2-CMDR: port 5/24 PD Detected.
    I 10/06/21 11:34:55 00561 ports: ST2-CMDR: port 5/24 Applying Power to PD.
    I 10/06/21 11:34:55 00560 ports: ST2-CMDR: port 5/27 PD Detected.
    I 10/06/21 11:34:55 00561 ports: ST2-CMDR: port 5/27 Applying Power to PD.
    I 10/06/21 11:34:55 00560 ports: ST2-CMDR: port 5/30 PD Detected.
    I 10/06/21 11:34:55 00561 ports: ST2-CMDR: port 5/30 Applying Power to PD.
    I 10/06/21 11:34:55 00560 ports: ST2-CMDR: port 5/32 PD Detected.
    I 10/06/21 11:34:55 00561 ports: ST2-CMDR: port 5/32 Applying Power to PD.
    I 10/06/21 11:34:55 00560 ports: ST2-CMDR: port 5/34 PD Detected.
    I 10/06/21 11:34:55 00561 ports: ST2-CMDR: port 5/34 Applying Power to PD.
    I 10/06/21 11:34:55 00560 ports: ST2-CMDR: port 5/35 PD Detected.
    I 10/06/21 11:34:55 00561 ports: ST2-CMDR: port 5/35 Applying Power to PD.
    I 10/06/21 11:34:55 00560 ports: ST2-CMDR: port 5/38 PD Detected.
    I 10/06/21 11:34:55 00561 ports: ST2-CMDR: port 5/38 Applying Power to PD.
    I 10/06/21 11:34:55 00560 ports: ST2-CMDR: port 5/39 PD Detected.
    I 10/06/21 11:34:55 00561 ports: ST2-CMDR: port 5/39 Applying Power to PD.
    I 10/06/21 11:34:55 00560 ports: ST2-CMDR: port 5/42 PD Detected.
    I 10/06/21 11:34:55 00561 ports: ST2-CMDR: port 5/42 Applying Power to PD.
    I 10/06/21 11:34:55 00560 ports: ST2-CMDR: port 5/43 PD Detected.
    I 10/06/21 11:34:55 00561 ports: ST2-CMDR: port 5/43 Applying Power to PD.
    I 10/06/21 11:34:56 00560 ports: ST2-CMDR: port 5/26 PD Detected.
    I 10/06/21 11:34:56 00561 ports: ST2-CMDR: port 5/26 Applying Power to PD.
    I 10/06/21 11:34:56 00560 ports: ST2-CMDR: port 5/37 PD Detected.
    I 10/06/21 11:34:56 00561 ports: ST2-CMDR: port 5/37 Applying Power to PD.
    I 10/06/21 11:34:56 00076 ports: ST2-CMDR: port 5/6 is now on-line
    I 10/06/21 11:34:57 00076 ports: ST2-CMDR: port 5/24 is now on-line
    I 10/06/21 11:34:57 00076 ports: ST2-CMDR: port 5/27 is now on-line
    I 10/06/21 11:34:57 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 11:34:57 00076 ports: ST2-CMDR: port 5/38 is now on-line
    I 10/06/21 11:34:57 00076 ports: ST2-CMDR: port 5/5 is now on-line
    I 10/06/21 11:34:57 00076 ports: ST2-CMDR: port 5/39 is now on-line
    I 10/06/21 11:34:57 00076 ports: ST2-CMDR: port 5/42 is now on-line
    I 10/06/21 11:34:57 00076 ports: ST2-CMDR: port 5/23 is now on-line
    I 10/06/21 11:34:57 00076 ports: ST2-CMDR: port 5/32 is now on-line
    I 10/06/21 11:34:57 00076 ports: ST2-CMDR: port 5/43 is now on-line
    I 10/06/21 11:34:57 00076 ports: ST2-CMDR: port 5/34 is now on-line
    I 10/06/21 11:34:58 00076 ports: ST2-CMDR: port 5/35 is now on-line
    I 10/06/21 11:34:58 00076 ports: ST2-CMDR: port 5/37 is now on-line
    I 10/06/21 11:34:58 00076 ports: ST2-CMDR: port 5/26 is now on-line
    I 10/06/21 11:35:09 00077 ports: ST2-CMDR: port 5/39 is now off-line
    I 10/06/21 11:35:09 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 11:35:09 00077 ports: ST2-CMDR: port 5/23 is now off-line
    I 10/06/21 11:35:09 00077 ports: ST2-CMDR: port 5/42 is now off-line
    I 10/06/21 11:35:09 00077 ports: ST2-CMDR: port 5/43 is now off-line
    I 10/06/21 11:35:09 00077 ports: ST2-CMDR: port 5/34 is now off-line
    I 10/06/21 11:35:10 00077 ports: ST2-CMDR: port 5/35 is now off-line
    I 10/06/21 11:35:10 00077 ports: ST2-CMDR: port 5/37 is now off-line
    I 10/06/21 11:35:10 00077 ports: ST2-CMDR: port 5/26 is now off-line
    I 10/06/21 11:35:13 00076 ports: ST2-CMDR: port 5/39 is now on-line
    I 10/06/21 11:35:13 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 11:35:13 00076 ports: ST2-CMDR: port 5/23 is now on-line
    I 10/06/21 11:35:13 00076 ports: ST2-CMDR: port 5/42 is now on-line
    I 10/06/21 11:35:13 00076 ports: ST2-CMDR: port 5/43 is now on-line
    I 10/06/21 11:35:13 00076 ports: ST2-CMDR: port 5/34 is now on-line
    I 10/06/21 11:35:13 00076 ports: ST2-CMDR: port 5/37 is now on-line
    I 10/06/21 11:35:14 00076 ports: ST2-CMDR: port 5/35 is now on-line
    I 10/06/21 11:35:14 00076 ports: ST2-CMDR: port 5/26 is now on-line
    I 10/06/21 11:35:32 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3909
    I 10/06/21 11:36:18 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3910
    I 10/06/21 11:36:53 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3911
    I 10/06/21 11:37:27 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3912
    I 10/06/21 11:38:14 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3913
    I 10/06/21 11:43:46 00077 ports: ST2-CMDR: port 2/41 is now off-line
    I 10/06/21 11:43:48 00076 ports: ST2-CMDR: port 2/41 is now on-line
    I 10/06/21 11:43:59 00077 ports: ST2-CMDR: port 2/41 is now off-line
    I 10/06/21 11:44:02 00076 ports: ST2-CMDR: port 2/41 is now on-line
    I 10/06/21 11:46:26 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 11:46:30 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 11:48:15 00077 ports: ST2-CMDR: port 5/45 is now off-line
    I 10/06/21 11:51:33 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    W 10/06/21 11:52:22 03270 stacking: ST2-CMDR: Topology is a Chain
    W 10/06/21 11:52:22 03258 stacking: ST2-CMDR: Member switch with Member ID 5
    I 10/06/21 11:52:22 03272 stacking: ST2-CMDR: Stack fragment active
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/2 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/5 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/6 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/7 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/8 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/22 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/23 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/24 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/26 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/27 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/32 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/34 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/35 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/37 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/38 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/39 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/42 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/43 is now off-line
    I 10/06/21 11:52:22 00077 ports: ST2-CMDR: port 5/47 is now off-line
    I 10/06/21 11:52:22 04992 vsf: ST4-MMBR: VSF port 4/52 is in error state
    I 10/06/21 11:52:22 04992 vsf: ST1-MMBR: VSF port 1/50 is in error state
    I 10/06/21 11:52:22 04992 vsf: ST4-MMBR: VSF link 2 is down
    I 10/06/21 11:52:22 04992 vsf: ST1-MMBR: VSF link 1 is down
    I 10/06/21 11:52:22 04992 vsf: ST1-MMBR: VSF port 1/50 is down
    I 10/06/21 11:52:22 04992 vsf: ST4-MMBR: VSF port 4/52 is down
    I 10/06/21 11:53:10 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3914
    I 10/06/21 11:53:44 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3915
    I 10/06/21 11:53:45 04988 vsf: ST4-MMBR: VSF link 2 port 4/52 up: Peer validated
    I 10/06/21 11:53:45 04987 vsf: ST4-MMBR: VSF link 2 up: Peer has mac
    64e881-0dc000
    I 10/06/21 11:53:49 04988 vsf: ST1-MMBR: VSF link 1 port 1/50 up: Peer validated
    I 10/06/21 11:53:49 04987 vsf: ST1-MMBR: VSF link 1 up: Peer has mac
    64e881-0dc000
    I 10/06/21 11:53:49 04992 vsf: ST4-MMBR: VSF link 2 is up
    I 10/06/21 11:53:49 04992 vsf: ST1-MMBR: VSF link 1 is up
    I 10/06/21 11:53:50 03271 stacking: ST2-CMDR: Topology is a Ring
    I 10/06/21 11:53:50 03803 chassis: ST2-CMDR: System Self test completed on
    5/1-52
    I 10/06/21 11:53:50 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3917
    I 10/06/21 11:53:52 02555 chassis: ST2-CMDR: Co-processor Ready
    I 10/06/21 11:53:52 00256 ports: ST2-CMDR: Port 5/50 is reserved for VSF use
    I 10/06/21 11:53:52 00256 ports: ST2-CMDR: Port 5/51 is reserved for VSF use
    I 10/06/21 11:53:52 00539 stacking: ST2-CMDR: Initial sync to member 5 starting
    I 10/06/21 11:53:53 00405 ports: ST2-CMDR: port 5/50 xcvr hot-swap insert.
    I 10/06/21 11:53:53 00405 ports: ST2-CMDR: port 5/51 xcvr hot-swap insert.
    I 10/06/21 11:53:55 00076 ports: ST2-CMDR: port 5/47 is now on-line
    I 10/06/21 11:53:56 00076 ports: ST2-CMDR: port 5/7 is now on-line
    I 10/06/21 11:53:56 00076 ports: ST2-CMDR: port 5/2 is now on-line
    I 10/06/21 11:53:57 00539 stacking: ST2-CMDR: Initial sync to member 5 complete
    Master
    Master
    location in flash.
    progress.
    complete.
    5/1-52
    I 01/01/90 00:00:37 04988 vsf: ST5-UKWN: VSF link 2 port 5/50 up: Peer validated
    I 01/01/90 00:00:37 04987 vsf: ST5-UKWN: VSF link 2 up: Peer has mac
    64e881-0c1b80
    64e881-0c3fc0
    I 10/06/21 11:53:57 03260 stacking: ST5-MMBR: Member booted
    I 10/06/21 11:53:57 03272 stacking: ST2-CMDR: Stack active
    I 10/06/21 11:53:57 00061 system: ST5-MMBR: ------------------------------------
    I 10/06/21 11:53:57 00062 system: ST5-MMBR: Member 5 went down without saving
    crash information
    M 10/06/21 11:53:57 03001 system: ST5-MMBR: System reboot due to Power Failure
    I 10/06/21 11:53:58 00076 ports: ST2-CMDR: port 5/8 is now on-line
    I 10/06/21 11:54:14 00076 ports: ST2-CMDR: port 5/22 is now on-line
    I 10/06/21 11:54:24 00560 ports: ST2-CMDR: port 5/5 PD Detected.
    I 10/06/21 11:54:24 00561 ports: ST2-CMDR: port 5/5 Applying Power to PD.
    I 10/06/21 11:54:24 00560 ports: ST2-CMDR: port 5/6 PD Detected.
    I 10/06/21 11:54:24 00561 ports: ST2-CMDR: port 5/6 Applying Power to PD.
    I 10/06/21 11:54:24 00560 ports: ST2-CMDR: port 5/23 PD Detected.
    I 10/06/21 11:54:24 00561 ports: ST2-CMDR: port 5/23 Applying Power to PD.
    I 10/06/21 11:54:24 00560 ports: ST2-CMDR: port 5/24 PD Detected.
    I 10/06/21 11:54:24 00561 ports: ST2-CMDR: port 5/24 Applying Power to PD.
    I 10/06/21 11:54:24 00560 ports: ST2-CMDR: port 5/27 PD Detected.
    I 10/06/21 11:54:24 00561 ports: ST2-CMDR: port 5/27 Applying Power to PD.
    I 10/06/21 11:54:24 00560 ports: ST2-CMDR: port 5/30 PD Detected.
    I 10/06/21 11:54:24 00561 ports: ST2-CMDR: port 5/30 Applying Power to PD.
    I 10/06/21 11:54:24 00560 ports: ST2-CMDR: port 5/32 PD Detected.
    I 10/06/21 11:54:24 00561 ports: ST2-CMDR: port 5/32 Applying Power to PD.
    I 10/06/21 11:54:24 00560 ports: ST2-CMDR: port 5/34 PD Detected.
    I 10/06/21 11:54:24 00561 ports: ST2-CMDR: port 5/34 Applying Power to PD.
    I 10/06/21 11:54:24 00560 ports: ST2-CMDR: port 5/35 PD Detected.
    I 10/06/21 11:54:24 00561 ports: ST2-CMDR: port 5/35 Applying Power to PD.
    I 10/06/21 11:54:24 00560 ports: ST2-CMDR: port 5/38 PD Detected.
    I 10/06/21 11:54:24 00561 ports: ST2-CMDR: port 5/38 Applying Power to PD.
    I 10/06/21 11:54:24 00560 ports: ST2-CMDR: port 5/39 PD Detected.
    I 10/06/21 11:54:24 00561 ports: ST2-CMDR: port 5/39 Applying Power to PD.
    I 10/06/21 11:54:24 00560 ports: ST2-CMDR: port 5/42 PD Detected.
    I 10/06/21 11:54:24 00561 ports: ST2-CMDR: port 5/42 Applying Power to PD.
    I 10/06/21 11:54:24 00560 ports: ST2-CMDR: port 5/43 PD Detected.
    I 10/06/21 11:54:24 00561 ports: ST2-CMDR: port 5/43 Applying Power to PD.
    I 10/06/21 11:54:25 00560 ports: ST2-CMDR: port 5/26 PD Detected.
    I 10/06/21 11:54:25 00561 ports: ST2-CMDR: port 5/26 Applying Power to PD.
    I 10/06/21 11:54:25 00560 ports: ST2-CMDR: port 5/37 PD Detected.
    I 10/06/21 11:54:25 00561 ports: ST2-CMDR: port 5/37 Applying Power to PD.
    I 10/06/21 11:54:25 00076 ports: ST2-CMDR: port 5/6 is now on-line
    I 10/06/21 11:54:26 00076 ports: ST2-CMDR: port 5/24 is now on-line
    I 10/06/21 11:54:26 00076 ports: ST2-CMDR: port 5/38 is now on-line
    I 10/06/21 11:54:26 00076 ports: ST2-CMDR: port 5/27 is now on-line
    I 10/06/21 11:54:26 00076 ports: ST2-CMDR: port 5/39 is now on-line
    I 10/06/21 11:54:26 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 11:54:26 00076 ports: ST2-CMDR: port 5/5 is now on-line
    I 10/06/21 11:54:26 00076 ports: ST2-CMDR: port 5/23 is now on-line
    I 10/06/21 11:54:26 00076 ports: ST2-CMDR: port 5/32 is now on-line
    I 10/06/21 11:54:26 00076 ports: ST2-CMDR: port 5/42 is now on-line
    I 10/06/21 11:54:26 00076 ports: ST2-CMDR: port 5/34 is now on-line
    I 10/06/21 11:54:27 00076 ports: ST2-CMDR: port 5/43 is now on-line
    I 10/06/21 11:54:27 00076 ports: ST2-CMDR: port 5/35 is now on-line
    I 10/06/21 11:54:27 00076 ports: ST2-CMDR: port 5/37 is now on-line
    I 10/06/21 11:54:27 00076 ports: ST2-CMDR: port 5/26 is now on-line
    I 10/06/21 11:54:38 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 11:54:38 00077 ports: ST2-CMDR: port 5/39 is now off-line
    I 10/06/21 11:54:38 00077 ports: ST2-CMDR: port 5/23 is now off-line
    I 10/06/21 11:54:38 00077 ports: ST2-CMDR: port 5/42 is now off-line
    I 10/06/21 11:54:38 00077 ports: ST2-CMDR: port 5/34 is now off-line
    I 10/06/21 11:54:38 00077 ports: ST2-CMDR: port 5/43 is now off-line
    I 10/06/21 11:54:38 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3918
    I 10/06/21 11:54:39 00077 ports: ST2-CMDR: port 5/35 is now off-line
    I 10/06/21 11:54:39 00077 ports: ST2-CMDR: port 5/37 is now off-line
    I 10/06/21 11:54:39 00077 ports: ST2-CMDR: port 5/26 is now off-line
    I 10/06/21 11:54:42 00076 ports: ST2-CMDR: port 5/39 is now on-line
    I 10/06/21 11:54:42 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 11:54:42 00076 ports: ST2-CMDR: port 5/42 is now on-line
    I 10/06/21 11:54:42 00076 ports: ST2-CMDR: port 5/23 is now on-line
    I 10/06/21 11:54:42 00076 ports: ST2-CMDR: port 5/34 is now on-line
    I 10/06/21 11:54:42 00076 ports: ST2-CMDR: port 5/35 is now on-line
    I 10/06/21 11:54:43 00076 ports: ST2-CMDR: port 5/37 is now on-line
    I 10/06/21 11:54:43 00076 ports: ST2-CMDR: port 5/43 is now on-line
    I 10/06/21 11:54:43 00076 ports: ST2-CMDR: port 5/26 is now on-line
    I 10/06/21 11:55:17 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3919
    I 10/06/21 11:55:43 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3920
    I 10/06/21 11:56:03 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3921
    I 10/06/21 11:56:47 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3922
    I 10/06/21 11:57:21 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3923
    I 10/06/21 12:05:55 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 12:05:59 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 12:06:38 00077 ports: ST2-CMDR: port 2/41 is now off-line
    I 10/06/21 12:06:40 00076 ports: ST2-CMDR: port 2/41 is now on-line
    I 10/06/21 12:06:44 00077 ports: ST2-CMDR: port 2/41 is now off-line
    I 10/06/21 12:06:46 00076 ports: ST2-CMDR: port 2/41 is now on-line
    I 10/06/21 12:06:50 00077 ports: ST2-CMDR: port 2/41 is now off-line
    I 10/06/21 12:06:51 00076 ports: ST2-CMDR: port 2/41 is now on-line
    I 10/06/21 12:07:02 00077 ports: ST2-CMDR: port 2/41 is now off-line
    I 10/06/21 12:07:05 00076 ports: ST2-CMDR: port 2/41 is now on-line
    I 10/06/21 12:07:35 00077 ports: ST2-CMDR: port 2/41 is now off-line
    I 10/06/21 12:07:38 00076 ports: ST2-CMDR: port 2/41 is now on-line
    I 10/06/21 12:08:37 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 12:17:13 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 12:17:17 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 12:17:45 00076 ports: ST2-CMDR: port 5/45 is now on-line
    I 10/06/21 12:18:14 00077 ports: ST2-CMDR: port 5/45 is now off-line
    I 10/06/21 12:18:17 00076 ports: ST2-CMDR: port 5/45 is now on-line
    I 10/06/21 12:25:40 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 12:28:33 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 12:28:37 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 12:39:50 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 12:39:54 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 12:42:45 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 12:49:28 00077 ports: ST2-CMDR: port 4/38 is now off-line
    I 10/06/21 12:49:30 00076 ports: ST2-CMDR: port 4/38 is now on-line
    I 10/06/21 12:51:10 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 12:51:14 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 12:53:40 00077 ports: ST2-CMDR: port 4/38 is now off-line
    I 10/06/21 12:53:42 00076 ports: ST2-CMDR: port 4/38 is now on-line
    I 10/06/21 12:59:50 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 13:00:50 00077 ports: ST2-CMDR: port 4/38 is now off-line
    I 10/06/21 13:00:52 00076 ports: ST2-CMDR: port 4/38 is now on-line
    I 10/06/21 13:02:28 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 13:02:32 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 13:13:45 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 13:13:49 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 13:16:53 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 13:25:05 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 13:25:09 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 13:33:58 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 13:36:23 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 13:36:27 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 13:37:40 04908 ntp: ST2-CMDR: The system clock time was changed by -1
    sec 283752066 nsec. The new time is Wed Oct 6 13:37:40 2021
    I 10/06/21 13:37:40 04910 ntp: ST2-CMDR: All the NTP server associations reset.
    I 10/06/21 13:47:39 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 13:47:43 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 13:51:02 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 13:58:57 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 13:59:01 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 14:08:05 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 14:10:14 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 14:10:19 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 14:21:37 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 14:21:41 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 14:25:11 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 14:32:55 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 14:32:58 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 14:42:15 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 14:44:12 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 14:44:16 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 14:55:32 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 14:55:36 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 14:59:18 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 15:06:49 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 15:06:53 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 15:11:27 04992 vsf: ST2-CMDR: VSF port 2/51 is in error state
    I 10/06/21 15:11:27 04992 vsf: ST2-CMDR: VSF link 1 is down
    W 10/06/21 15:11:27 03270 stacking: ST2-CMDR: Topology is a Chain
    W 10/06/21 15:11:27 03258 stacking: ST2-CMDR: Member switch with Member ID 1
    I 10/06/21 15:11:27 03272 stacking: ST2-CMDR: Stack fragment active
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/7 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/8 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/9 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/10 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/12 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/14 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/15 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/16 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/20 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/23 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/24 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/26 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/27 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/31 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/32 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/33 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/35 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/36 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/38 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/40 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/41 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/42 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/43 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/45 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/46 is now off-line
    I 10/06/21 15:11:27 00077 ports: ST2-CMDR: port 1/48 in Trk2 is now off-line
    I 10/06/21 15:11:27 04992 vsf: ST5-MMBR: VSF port 5/50 is in error state
    I 10/06/21 15:11:27 04992 vsf: ST5-MMBR: VSF link 2 is down
    I 10/06/21 15:11:28 04992 vsf: ST2-CMDR: VSF port 2/51 is down
    I 10/06/21 15:11:28 04992 vsf: ST5-MMBR: VSF port 5/50 is down
    I 10/06/21 15:11:58 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3924
    I 10/06/21 15:12:47 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3925
    I 10/06/21 15:12:51 04988 vsf: ST5-MMBR: VSF link 2 port 5/50 up: Peer validated
    I 10/06/21 15:12:51 04987 vsf: ST5-MMBR: VSF link 2 up: Peer has mac
    64e881-0c1b80
    I 10/06/21 15:12:56 04988 vsf: ST2-CMDR: VSF link 1 port 2/51 up: Peer validated
    I 10/06/21 15:12:56 04987 vsf: ST2-CMDR: VSF link 1 up: Peer has mac
    64e881-0c1b80
    I 10/06/21 15:12:56 04992 vsf: ST2-CMDR: VSF link 1 is up
    I 10/06/21 15:12:56 03803 chassis: ST2-CMDR: System Self test completed on
    1/1-52
    I 10/06/21 15:12:56 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3927
    I 10/06/21 15:12:56 04992 vsf: ST5-MMBR: VSF link 2 is up
    I 10/06/21 15:12:56 03271 stacking: ST2-CMDR: Topology is a Ring
    I 10/06/21 15:12:58 02555 chassis: ST2-CMDR: Co-processor Ready
    I 10/06/21 15:12:58 00256 ports: ST2-CMDR: Port 1/50 is reserved for VSF use
    I 10/06/21 15:12:58 00256 ports: ST2-CMDR: Port 1/52 is reserved for VSF use
    I 10/06/21 15:12:58 00539 stacking: ST2-CMDR: Initial sync to member 1 starting
    I 10/06/21 15:12:59 00405 ports: ST2-CMDR: port 1/50 xcvr hot-swap insert.
    I 10/06/21 15:12:59 00405 ports: ST2-CMDR: port 1/52 xcvr hot-swap insert.
    I 10/06/21 15:13:02 00076 ports: ST2-CMDR: port 1/26 is now on-line
    I 10/06/21 15:13:02 00435 ports: ST2-CMDR: port 1/48 is Blocked by LACP
    I 10/06/21 15:13:04 00539 stacking: ST2-CMDR: Initial sync to member 1 complete
    Master
    Master
    location in flash.
    progress.
    complete.
    1/1-52
    I 01/01/90 00:00:37 04988 vsf: ST1-UKWN: VSF link 2 port 1/52 up: Peer validated
    I 01/01/90 00:00:37 04987 vsf: ST1-UKWN: VSF link 2 up: Peer has mac
    64e881-0c2fc0
    64e881-0dc000
    I 10/06/21 15:13:04 03260 stacking: ST1-MMBR: Member booted
    I 10/06/21 15:13:04 03272 stacking: ST2-CMDR: Stack active
    I 10/06/21 15:13:04 00061 system: ST1-MMBR: ------------------------------------
    I 10/06/21 15:13:04 00062 system: ST1-MMBR: Member 1 went down without saving
    crash information
    M 10/06/21 15:13:04 03001 system: ST1-MMBR: System reboot due to Power Failure
    I 10/06/21 15:13:09 00076 ports: ST2-CMDR: port 1/48 in Trk2 is now on-line
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/7 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/7 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/8 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/8 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/9 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/9 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/10 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/10 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/12 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/12 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/16 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/16 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/20 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/20 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/23 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/23 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/24 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/24 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/27 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/27 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/31 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/31 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/32 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/32 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/33 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/33 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/38 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/38 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/40 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/40 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/45 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/45 Applying Power to PD.
    I 10/06/21 15:13:30 00560 ports: ST2-CMDR: port 1/46 PD Detected.
    I 10/06/21 15:13:30 00561 ports: ST2-CMDR: port 1/46 Applying Power to PD.
    I 10/06/21 15:13:31 00560 ports: ST2-CMDR: port 1/14 PD Detected.
    I 10/06/21 15:13:31 00561 ports: ST2-CMDR: port 1/14 Applying Power to PD.
    I 10/06/21 15:13:31 00560 ports: ST2-CMDR: port 1/15 PD Detected.
    I 10/06/21 15:13:31 00561 ports: ST2-CMDR: port 1/15 Applying Power to PD.
    I 10/06/21 15:13:31 00560 ports: ST2-CMDR: port 1/35 PD Detected.
    I 10/06/21 15:13:31 00561 ports: ST2-CMDR: port 1/35 Applying Power to PD.
    I 10/06/21 15:13:31 00560 ports: ST2-CMDR: port 1/36 PD Detected.
    I 10/06/21 15:13:31 00561 ports: ST2-CMDR: port 1/36 Applying Power to PD.
    I 10/06/21 15:13:31 00560 ports: ST2-CMDR: port 1/41 PD Detected.
    I 10/06/21 15:13:31 00561 ports: ST2-CMDR: port 1/41 Applying Power to PD.
    I 10/06/21 15:13:31 00076 ports: ST2-CMDR: port 1/10 is now on-line
    I 10/06/21 15:13:31 00560 ports: ST2-CMDR: port 1/42 PD Detected.
    I 10/06/21 15:13:31 00561 ports: ST2-CMDR: port 1/42 Applying Power to PD.
    I 10/06/21 15:13:31 00560 ports: ST2-CMDR: port 1/43 PD Detected.
    I 10/06/21 15:13:31 00561 ports: ST2-CMDR: port 1/43 Applying Power to PD.
    I 10/06/21 15:13:31 00076 ports: ST2-CMDR: port 1/45 is now on-line
    I 10/06/21 15:13:31 00076 ports: ST2-CMDR: port 1/31 is now on-line
    I 10/06/21 15:13:31 00076 ports: ST2-CMDR: port 1/12 is now on-line
    I 10/06/21 15:13:31 00076 ports: ST2-CMDR: port 1/23 is now on-line
    I 10/06/21 15:13:32 00076 ports: ST2-CMDR: port 1/7 is now on-line
    I 10/06/21 15:13:32 00076 ports: ST2-CMDR: port 1/16 is now on-line
    I 10/06/21 15:13:32 00076 ports: ST2-CMDR: port 1/9 is now on-line
    I 10/06/21 15:13:32 00076 ports: ST2-CMDR: port 1/27 is now on-line
    I 10/06/21 15:13:32 00076 ports: ST2-CMDR: port 1/46 is now on-line
    I 10/06/21 15:13:32 00076 ports: ST2-CMDR: port 1/35 is now on-line
    I 10/06/21 15:13:32 00076 ports: ST2-CMDR: port 1/40 is now on-line
    I 10/06/21 15:13:32 00076 ports: ST2-CMDR: port 1/20 is now on-line
    I 10/06/21 15:13:32 00076 ports: ST2-CMDR: port 1/42 is now on-line
    I 10/06/21 15:13:32 00076 ports: ST2-CMDR: port 1/32 is now on-line
    I 10/06/21 15:13:32 00076 ports: ST2-CMDR: port 1/24 is now on-line
    I 10/06/21 15:13:33 00076 ports: ST2-CMDR: port 1/33 is now on-line
    I 10/06/21 15:13:33 00076 ports: ST2-CMDR: port 1/38 is now on-line
    I 10/06/21 15:13:33 00076 ports: ST2-CMDR: port 1/8 is now on-line
    I 10/06/21 15:13:33 00076 ports: ST2-CMDR: port 1/41 is now on-line
    I 10/06/21 15:13:33 00076 ports: ST2-CMDR: port 1/14 is now on-line
    I 10/06/21 15:13:33 00076 ports: ST2-CMDR: port 1/36 is now on-line
    I 10/06/21 15:13:33 00076 ports: ST2-CMDR: port 1/15 is now on-line
    I 10/06/21 15:13:33 00076 ports: ST2-CMDR: port 1/43 is now on-line
    I 10/06/21 15:13:39 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3929
    I 10/06/21 15:13:44 00077 ports: ST2-CMDR: port 1/16 is now off-line
    I 10/06/21 15:13:44 00077 ports: ST2-CMDR: port 1/27 is now off-line
    I 10/06/21 15:13:44 00077 ports: ST2-CMDR: port 1/46 is now off-line
    I 10/06/21 15:13:44 00077 ports: ST2-CMDR: port 1/32 is now off-line
    I 10/06/21 15:13:44 00077 ports: ST2-CMDR: port 1/24 is now off-line
    I 10/06/21 15:13:44 00077 ports: ST2-CMDR: port 1/33 is now off-line
    I 10/06/21 15:13:45 00077 ports: ST2-CMDR: port 1/8 is now off-line
    I 10/06/21 15:13:45 00077 ports: ST2-CMDR: port 1/36 is now off-line
    I 10/06/21 15:13:48 00076 ports: ST2-CMDR: port 1/16 is now on-line
    I 10/06/21 15:13:48 00076 ports: ST2-CMDR: port 1/27 is now on-line
    I 10/06/21 15:13:48 00076 ports: ST2-CMDR: port 1/46 is now on-line
    I 10/06/21 15:13:48 00076 ports: ST2-CMDR: port 1/32 is now on-line
    I 10/06/21 15:13:48 00076 ports: ST2-CMDR: port 1/24 is now on-line
    I 10/06/21 15:13:48 00076 ports: ST2-CMDR: port 1/33 is now on-line
    I 10/06/21 15:13:48 00076 ports: ST2-CMDR: port 1/8 is now on-line
    I 10/06/21 15:13:49 00076 ports: ST2-CMDR: port 1/36 is now on-line
    I 10/06/21 15:14:13 00077 ports: ST2-CMDR: port 4/38 is now off-line
    I 10/06/21 15:14:15 00076 ports: ST2-CMDR: port 4/38 is now on-line
    I 10/06/21 15:14:23 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3930
    I 10/06/21 15:14:58 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3931
    I 10/06/21 15:15:27 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3932
    I 10/06/21 15:15:52 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3933
    I 10/06/21 15:16:24 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 15:18:09 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 15:18:13 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 15:29:26 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 15:29:30 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 15:33:29 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 15:40:46 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 15:40:50 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 15:50:36 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 15:52:04 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 15:52:08 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 16:03:21 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 16:03:25 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 16:07:41 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 16:14:41 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 16:14:45 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 16:24:44 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 16:25:58 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 16:26:02 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 16:37:18 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 16:37:22 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 16:41:49 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 16:48:36 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 16:48:40 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 16:58:55 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 16:59:53 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 16:59:57 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 17:10:27 00077 ports: ST2-CMDR: port 4/38 is now off-line
    I 10/06/21 17:10:30 00076 ports: ST2-CMDR: port 4/38 is now on-line
    I 10/06/21 17:11:11 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 17:11:15 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 17:15:58 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 17:22:29 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 17:22:33 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 17:33:03 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 17:33:48 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 17:33:52 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 17:45:07 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 17:45:11 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 17:50:09 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 17:56:24 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 17:56:28 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 18:07:16 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 18:07:42 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 18:07:46 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 18:19:00 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 18:19:04 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 18:24:20 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 18:25:03 00077 ports: ST2-CMDR: port 2/41 is now off-line
    I 10/06/21 18:30:19 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 18:30:23 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 18:41:25 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 18:41:37 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 18:41:41 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 18:52:55 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 18:52:58 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 18:58:30 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 19:04:12 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 19:04:16 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 19:15:30 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 19:15:35 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 19:15:37 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 19:26:53 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 19:26:58 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 19:32:41 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 19:38:15 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 19:38:19 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 19:49:32 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 19:49:37 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 19:49:46 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 20:00:50 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 20:00:54 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 20:06:49 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 20:12:08 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 20:12:12 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 20:23:27 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 20:23:31 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 20:23:55 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 20:34:45 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 20:34:49 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 20:41:02 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 20:46:07 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 20:46:11 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 20:57:24 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 20:57:28 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 20:58:07 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 21:08:41 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 21:08:46 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 21:15:11 04911 ntp: ST2-CMDR: The NTP Server x.x.x.x. is
    unreachable.
    I 10/06/21 21:20:01 00077 ports: ST2-CMDR: port 5/30 is now off-line
    I 10/06/21 21:20:06 00076 ports: ST2-CMDR: port 5/30 is now on-line
    I 10/06/21 21:25:03 00076 ports: ST2-CMDR: port 2/41 is now on-line
    I 10/06/21 21:25:06 00077 ports: ST2-CMDR: port 2/41 is now off-line
    I 10/06/21 21:25:09 00076 ports: ST2-CMDR: port 2/41 is now on-line
    I 10/06/21 21:25:18 00077 ports: ST2-CMDR: port 2/41 is now off-line
    I 10/06/21 21:27:23 04992 vsf: ST2-CMDR: VSF port 2/51 is in error state
    I 10/06/21 21:27:23 04992 vsf: ST2-CMDR: VSF link 1 is down
    W 10/06/21 21:27:23 03270 stacking: ST2-CMDR: Topology is a Chain
    W 10/06/21 21:27:23 03258 stacking: ST2-CMDR: Member switch with Member ID 1
    I 10/06/21 21:27:23 03272 stacking: ST2-CMDR: Stack fragment active
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/7 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/8 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/9 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/10 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/12 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/14 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/15 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/16 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/20 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/23 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/24 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/26 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/27 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/31 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/32 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/33 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/35 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/36 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/38 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/40 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/41 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/42 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/43 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/45 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/46 is now off-line
    I 10/06/21 21:27:23 00077 ports: ST2-CMDR: port 1/48 in Trk2 is now off-line
    I 10/06/21 21:27:22 04992 vsf: ST5-MMBR: VSF port 5/50 is in error state
    I 10/06/21 21:27:23 04992 vsf: ST2-CMDR: VSF port 2/51 is down
    I 10/06/21 21:27:22 04992 vsf: ST5-MMBR: VSF link 2 is down
    I 10/06/21 21:27:23 04992 vsf: ST5-MMBR: VSF port 5/50 is down
    I 10/06/21 21:28:10 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3934
    I 10/06/21 21:28:39 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3935
    I 10/06/21 21:28:46 04988 vsf: ST2-CMDR: VSF link 1 port 2/51 up: Peer validated
    I 10/06/21 21:28:46 04987 vsf: ST2-CMDR: VSF link 1 up: Peer has mac
    64e881-0c1b80
    I 10/06/21 21:28:51 04992 vsf: ST2-CMDR: VSF link 1 is up
    I 10/06/21 21:28:51 03803 chassis: ST2-CMDR: System Self test completed on
    1/1-52
    I 10/06/21 21:28:51 03271 stacking: ST2-CMDR: Topology is a Ring
    I 10/06/21 21:28:51 04988 vsf: ST5-MMBR: VSF link 2 port 5/50 up: Peer validated
    I 10/06/21 21:28:51 04987 vsf: ST5-MMBR: VSF link 2 up: Peer has mac
    64e881-0c1b80
    I 10/06/21 21:28:51 04992 vsf: ST5-MMBR: VSF link 2 is up
    I 10/06/21 21:28:51 03125 mgr: ST2-CMDR: Startup configuration changed by SNMP.
    New seq. number 3937
    I 10/06/21 21:28:53 02555 chassis: ST2-CMDR: Co-processor Ready
    I 10/06/21 21:28:53 00256 ports: ST2-CMDR: Port 1/50 is reserved for VSF use
    I 10/06/21 21:28:53 00256 ports: ST2-CMDR: Port 1/52 is reserved for VSF use
    I 10/06/21 21:28:54 00539 stacking: ST2-CMDR: Initial sync to member 1 starting
    I 10/06/21 21:28:54 00405 ports: ST2-CMDR: port 1/50 xcvr hot-swap insert.
    I 10/06/21 21:28:54 00405 ports: ST2-CMDR: port 1/52 xcvr hot-swap insert.
    I 10/06/21 21:28:57 00076 ports: ST2-CMDR: port 1/26 is now on-line
    I 10/06/21 21:28:57 00435 ports: ST2-CMDR: port 1/48 is Blocked by LACP
    I 10/06/21 21:28:59 00539 stacking: ST2-CMDR: Initial sync to member 1 complete
    Show  vsf detail:
    show vsf link detail
    VSF Member: 1 Link: 1
    Port State
    1/50 Up: Connected to port 5/50
    VSF Member: 1 Link: 2
    Port State
    1/52 Up: Connected to port 2/51
    VSF Member: 2 Link: 1
    Port State
    2/51 Up: Connected to port 1/52
    VSF Member: 2 Link: 2
    Port State
    2/52 Up: Connected to port 3/51
    VSF Member: 3 Link: 1
    Show run:
    Running configuration:
    ; hpStack_WC Configuration Editor; Created on release #WC.16.10.0015
    ; Ver #14:67.6f.f8.1d.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:44
    hostname ""
    vsf
    enable domain 2
    member 1
    type "JL256A" mac-addres x.x.x.x
    priority 255
    link 1 1/50
    link 1 name "Stack1"
    link 2 1/52
    link 2 name "Stack2"
    exit
    member 2
    type "JL256A" mac-address x.x.x.x
    priority 254
    link 1 2/51
    link 2 2/52
    exit
    member 3
    priority 253
    link 1 3/51
    link 2 3/52
    exit
    member 4
    priority 252
    link 1 4/51
    link 2 4/52
    exit
    member 5
    type "JL256A" mac-address 64e881-........
    priority 251
    link 1 5/51
    link 2 5/50
    exit
    port-speed 10g
    exit
    no cwmp enable
    dhcp-snooping authorized-server 1x.x.x.x
    no dhcp-snooping option 82
    dhcp-snooping vlan 20-22 120-122
    trunk 1/48,4/48 trk2 lacp
    include-credentials
    timesync ntp
    ntp unicast
    ntp server
    ntp server
    ntp server
    ntp enable
    time daylight-time-rule user-defined begin-date 03/08 end-date 11/01
    time timezone -240
    ip default-gateway x.x.x.x
    ip dns server-address priority 1 x.x.x.x
    interface 1/1
    rate-limit bcast in percent 25
    rate-limit mcast in percent 25
    exit
    interface 1/2
    exit
    interface 1/3
    exit
    interface 1/4
    exit
    interface 1/5
    exit
    interface 1/6
    exit
    interface 1/7
    exit
    interface 1/8
    exit
    interface 1/9
    exit
    interface 1/10
    exit
    interface 1/11
    exit
    interface 1/12
    exit
    interface 1/13
    exit
    interface 1/14
    exit
    interface 1/15
    exit
    interface 1/16
    exit
    interface 1/17
    exit
    interface 1/18
    exit
    interface 1/19
    exit
    interface 1/20
    name "AP1994_Shipping_EXFO3"
    exit
    interface 1/21
    exit
    interface 1/22
    exit
    interface 1/23
    exit
    interface 1/24
    exit
    interface 1/25
    exit
    interface 1/26
    exit
    interface 1/27
    exit
    interface 1/28
    exit
    interface 1/29
    exit
    interface 1/30
    exit
    interface 1/31
    exit
    interface 1/32
    exit
    interface 1/33
    exit
    interface 1/34
    exit
    interface 1/35
    exit
    interface 1/36
    exit
    interface 1/37
    exit
    interface 1/38
    exit
    interface 1/39
    exit
    interface 1/40
    exit
    interface 1/41
    exit
    interface 1/42
    exit
    interface 1/43
    exit
    interface 1/44
    exit
    interface 1/45
    exit
    interface 1/46
    exit
    interface 1/47
    exit
    interface 1/48
    exit
    interface 1/49
    exit
    interface 2/1
    exit
    interface 2/2
    exit
    interface 2/3
    exit
    interface 2/4
    exit
    interface 2/5
    exit
    interface 2/6
    exit
    interface 2/7
    exit
    interface 2/8
    exit
    interface 2/9
    exit
    interface 2/10
    exit
    interface 2/11
    exit
    interface 2/12
    exit
    interface 2/13
    exit
    interface 2/14
    exit
    interface 2/15
    exit
    interface 2/16
    exit
    interface 2/17
    exit
    interface 2/18
    exit
    interface 2/19
    exit
    interface 2/20
    exit
    interface 2/21
    exit
    interface 2/22
    exit
    interface 2/23
    exit
    interface 2/24
    exit
    interface 2/25
    exit
    interface 2/26
    exit
    interface 2/27
    exit
    interface 2/28
    exit
    interface 2/29
    exit
    interface 2/30
    exit
    interface 2/31
    exit
    interface 2/32
    exit
    interface 2/33
    exit
    interface 2/34
    exit
    interface 2/35
    exit
    interface 2/36
    exit
    interface 2/37
    exit
    interface 2/38
    exit
    interface 2/39
    exit
    interface 2/40
    exit
    interface 2/41
    exit
    interface 2/42
    exit
    interface 2/43
    exit
    interface 2/44
    exit
    interface 2/45
    exit
    interface 2/46
    exit
    interface 2/47
    exit
    interface 2/48
    exit
    interface 2/49
    exit
    interface 2/50
    exit
    interface 3/1
    dhcp-snooping trust
    exit
    interface 3/2
    exit
    interface 3/3
    exit
    interface 3/4
    exit
    interface 3/5
    exit
    interface 3/6
    exit
    interface 3/7
    exit
    interface 3/8
    exit
    interface 3/9
    exit
    interface 3/10
    exit
    interface 3/11
    exit
    interface 3/12
    exit
    interface 3/13
    exit
    interface 3/14
    exit
    interface 3/15
    exit
    interface 3/16
    exit
    interface 3/17
    exit
    interface 3/18
    exit
    interface 3/19
    exit
    interface 3/20
    exit
    interface 3/21
    exit
    interface 3/22
    exit
    interface 3/23
    exit
    interface 3/24
    exit
    interface 3/25
    exit
    interface 3/26
    exit
    interface 3/27
    exit
    interface 3/28
    exit
    interface 3/29
    exit
    interface 3/30
    exit
    interface 3/31
    exit
    interface 3/32
    exit
    interface 3/33
    exit
    interface 3/34
    exit
    interface 3/35
    exit
    interface 3/36
    exit
    interface 3/37
    exit
    interface 3/38
    exit
    interface 3/39
    exit
    interface 3/40
    exit
    interface 3/41
    exit
    interface 3/42
    exit
    interface 3/43
    exit
    interface 3/44
    exit
    interface 3/45
    exit
    interface 3/46
    exit
    interface 3/47
    exit
    interface 3/48
    exit
    interface 3/49
    exit
    interface 3/50
    exit
    interface 4/1
    exit
    interface 4/2
    exit
    interface 4/3
    exit
    interface 4/4
    exit
    interface 4/5
    exit
    interface 4/6
    exit
    interface 4/7
    exit
    interface 4/8
    exit
    interface 4/9
    exit
    interface 4/10
    exit
    interface 4/11
    exit
    interface 4/12
    exit
    interface 4/13
    exit
    interface 4/14
    exit
    interface 4/15
    exit
    interface 4/16
    exit
    interface 4/17
    exit
    interface 4/18
    exit
    interface 4/19
    exit
    interface 4/20
    exit
    interface 4/21
    exit
    interface 4/22
    exit
    interface 4/23
    exit
    interface 4/24
    exit
    interface 4/25
    exit
    interface 4/26
    exit
    interface 4/27
    exit
    interface 4/28
    exit
    interface 4/29
    exit
    interface 4/30
    exit
    interface 4/31
    exit
    interface 4/32
    exit
    interface 4/33
    exit
    interface 4/34
    exit
    interface 4/35
    exit
    interface 4/36
    exit
    interface 4/37
    exit
    interface 4/38
    exit
    interface 4/39
    exit
    interface 4/40
    exit
    interface 4/41
    exit
    interface 4/42
    exit
    interface 4/43
    exit
    interface 4/44
    exit
    interface 4/45
    exit
    interface 4/46
    exit
    interface 4/47
    exit
    interface 4/48
    exit
    interface 4/49
    exit
    interface 4/50
    exit
    interface 5/1
    exit
    interface 5/2
    exit
    interface 5/3
    exit
    interface 5/4
    exit
    interface 5/5
    exit
    interface 5/6
    exit
    interface 5/7
    exit
    interface 5/8
    exit
    interface 5/9
    exit
    interface 5/10
    exit
    interface 5/11
    exit
    interface 5/12
    exit
    interface 5/13
    exit
    interface 5/14
    exit
    interface 5/15
    exit
    interface 5/16
    exit
    interface 5/17
    exit
    interface 5/18
    exit
    interface 5/19
    exit
    interface 5/20
    exit
    interface 5/21
    exit
    interface 5/22
    exit
    interface 5/23
    exit
    interface 5/24
    exit
    interface 5/25
    exit
    interface 5/26
    exit
    interface 5/27
    exit
    interface 5/28
    exit
    interface 5/29
    exit
    interface 5/30
    exit
    interface 5/31
    exit
    interface 5/32
    exit
    interface 5/33
    exit
    interface 5/34
    exit
    interface 5/35
    exit
    interface 5/36
    exit
    interface 5/37
    exit
    interface 5/38
    exit
    interface 5/39
    exit
    interface 5/40
    exit
    interface 5/41
    exit
    interface 5/42
    exit
    interface 5/43
    exit
    interface 5/44
    exit
    interface 5/45
    exit
    interface 5/46
    exit
    interface 5/47
    exit
    interface 5/48
    exit
    interface 5/49
    exit
    interface Trk2
    dhcp-snooping trust
    exit
    snmp-server community "2G7dsC0X"
    snmp-server enable traps mac-count-notify
    snmp-server location "Exfo3 - 1st floor"
    snmpv3 engineid "00:00:00:0b:00:00:64:e8:81:0c:1b:8a"
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 1/1-1/47,2/1-2/48,3/1-3/48,4/1-4/47,5/1-5/48,Trk2
    untagged 1/49,1/51,2/49-2/50,3/49-3/50,4/49-4/50,5/49,5/52
    no ip address
    ipv6 enable
    ipv6 address dhcp full
    exit
    vlan 20
    name "VLAN020_USERS"
    untagged 1/1-1/46,2/1-2/48
    tagged 1/47,Trk2
    no ip address
    exit
    vlan 21
    name "VLAN021_USERS"
    untagged 3/1-3/34,3/36-3/40,3/42-3/48,4/1-4/47,5/7
    tagged 1/47,Trk2
    no ip address
    exit
    vlan 22
    name "VLAN022_USERS"
    untagged 5/1-5/6,5/8-5/46,5/48
    tagged 1/47,Trk2
    no ip address
    exit
    vlan 120
    name "VLAN120_VOICE"
    tagged 1/1-1/47,2/1-2/48,Trk2
    no ip address
    voice
    exit
    vlan 121
    name "VLAN121_VOICE"
    tagged 1/47,3/1-3/48,4/1-4/47,5/7,Trk2
    no ip address
    voice
    exit
    vlan 122
    name "VLAN122_VOICE"
    tagged 1/47,5/1-5/48,Trk2
    no ip address
    voice
    exit
    vlan 606
    name "Legacy-EXFO-III"
    tagged 1/47,Trk2
    no ip address
    exit
    vlan 660
    name "Controles"
    untagged 3/35,3/41,5/47
    tagged 1/47,Trk2
    no ip address
    exit
    vlan 904
    name "Network_Management_VLAN_904"
    tagged 1/47,Trk2
    ip address x.x.x.x 255.255.255.0
    exit
    vlan 999
    name "NATIVE"
    untagged 1/47,Trk2
    no ip address
    exit
    primary-vlan 904
    management-vlan 904
    spanning-tree 1/1 admin-edge-port
    spanning-tree 1/1 bpdu-protection
    spanning-tree 1/2 admin-edge-port
    spanning-tree 1/2 bpdu-protection
    spanning-tree 1/3 admin-edge-port
    spanning-tree 1/3 bpdu-protection
    spanning-tree 1/4 admin-edge-port
    spanning-tree 1/4 bpdu-protection
    spanning-tree 1/5 admin-edge-port
    spanning-tree 1/5 bpdu-protection
    spanning-tree 1/6 admin-edge-port
    spanning-tree 1/6 bpdu-protection
    spanning-tree 1/7 admin-edge-port
    spanning-tree 1/7 bpdu-protection
    spanning-tree 1/8 admin-edge-port
    spanning-tree 1/8 bpdu-protection
    spanning-tree 1/9 admin-edge-port
    spanning-tree 1/9 bpdu-protection
    spanning-tree 1/10 admin-edge-port
    spanning-tree 1/10 bpdu-protection
    spanning-tree 1/11 admin-edge-port
    spanning-tree 1/11 bpdu-protection
    spanning-tree 1/12 admin-edge-port
    spanning-tree 1/12 bpdu-protection
    spanning-tree 1/13 admin-edge-port
    spanning-tree 1/13 bpdu-protection
    spanning-tree 1/14 admin-edge-port
    spanning-tree 1/14 bpdu-protection
    spanning-tree 1/15 admin-edge-port
    spanning-tree 1/15 bpdu-protection
    spanning-tree 1/16 admin-edge-port
    spanning-tree 1/16 bpdu-protection
    spanning-tree 1/17 admin-edge-port
    spanning-tree 1/17 bpdu-protection
    spanning-tree 1/18 admin-edge-port
    spanning-tree 1/18 bpdu-protection
    spanning-tree 1/19 admin-edge-port
    spanning-tree 1/19 bpdu-protection
    spanning-tree 1/20 admin-edge-port
    spanning-tree 1/20 bpdu-protection
    spanning-tree 1/21 admin-edge-port
    spanning-tree 1/21 bpdu-protection
    spanning-tree 1/22 admin-edge-port
    spanning-tree 1/22 bpdu-protection
    spanning-tree 1/23 admin-edge-port
    spanning-tree 1/23 bpdu-protection
    spanning-tree 1/24 admin-edge-port
    spanning-tree 1/24 bpdu-protection
    spanning-tree 1/25 admin-edge-port
    spanning-tree 1/25 bpdu-protection
    spanning-tree 1/26 admin-edge-port
    spanning-tree 1/26 bpdu-protection
    spanning-tree 1/27 admin-edge-port
    spanning-tree 1/27 bpdu-protection
    spanning-tree 1/28 admin-edge-port
    spanning-tree 1/28 bpdu-protection
    spanning-tree 1/29 admin-edge-port
    spanning-tree 1/29 bpdu-protection
    spanning-tree 1/30 admin-edge-port
    spanning-tree 1/30 bpdu-protection
    spanning-tree 1/31 admin-edge-port
    spanning-tree 1/31 bpdu-protection
    spanning-tree 1/32 admin-edge-port
    spanning-tree 1/32 bpdu-protection
    spanning-tree 1/33 admin-edge-port
    spanning-tree 1/33 bpdu-protection
    spanning-tree 1/34 admin-edge-port
    spanning-tree 1/34 bpdu-protection
    spanning-tree 1/35 admin-edge-port
    spanning-tree 1/35 bpdu-protection
    spanning-tree 1/36 admin-edge-port
    spanning-tree 1/36 bpdu-protection
    spanning-tree 1/37 admin-edge-port
    spanning-tree 1/37 bpdu-protection
    spanning-tree 1/38 admin-edge-port
    spanning-tree 1/38 bpdu-protection
    spanning-tree 1/39 admin-edge-port
    spanning-tree 1/39 bpdu-protection
    spanning-tree 1/40 admin-edge-port
    spanning-tree 1/40 bpdu-protection
    spanning-tree 1/41 admin-edge-port
    spanning-tree 1/41 bpdu-protection
    spanning-tree 1/42 admin-edge-port
    spanning-tree 1/42 bpdu-protection
    spanning-tree 1/43 admin-edge-port
    spanning-tree 1/43 bpdu-protection
    spanning-tree 1/44 admin-edge-port
    spanning-tree 1/44 bpdu-protection
    spanning-tree 1/45 admin-edge-port
    spanning-tree 1/45 bpdu-protection
    spanning-tree 1/46 admin-edge-port
    spanning-tree 1/46 bpdu-protection
    spanning-tree 2/1 admin-edge-port
    spanning-tree 2/1 bpdu-protection
    spanning-tree 2/2 admin-edge-port
    spanning-tree 2/2 bpdu-protection
    spanning-tree 2/3 admin-edge-port
    spanning-tree 2/3 bpdu-protection
    spanning-tree 2/4 admin-edge-port
    spanning-tree 2/4 bpdu-protection
    spanning-tree 2/5 admin-edge-port
    spanning-tree 2/5 bpdu-protection
    spanning-tree 2/6 admin-edge-port
    spanning-tree 2/6 bpdu-protection
    spanning-tree 2/7 admin-edge-port
    spanning-tree 2/7 bpdu-protection
    spanning-tree 2/8 admin-edge-port
    spanning-tree 2/8 bpdu-protection
    spanning-tree 2/9 admin-edge-port
    spanning-tree 2/9 bpdu-protection
    spanning-tree 2/10 admin-edge-port
    spanning-tree 2/10 bpdu-protection
    spanning-tree 2/11 admin-edge-port
    spanning-tree 2/11 bpdu-protection
    spanning-tree 2/12 admin-edge-port
    spanning-tree 2/12 bpdu-protection
    spanning-tree 2/13 admin-edge-port
    spanning-tree 2/13 bpdu-protection
    spanning-tree 2/14 admin-edge-port
    spanning-tree 2/14 bpdu-protection
    spanning-tree 2/15 admin-edge-port
    spanning-tree 2/15 bpdu-protection
    spanning-tree 2/16 admin-edge-port
    spanning-tree 2/16 bpdu-protection
    spanning-tree 2/17 admin-edge-port
    spanning-tree 2/17 bpdu-protection
    spanning-tree 2/18 admin-edge-port
    spanning-tree 2/18 bpdu-protection
    spanning-tree 2/19 admin-edge-port
    spanning-tree 2/19 bpdu-protection
    spanning-tree 2/20 admin-edge-port
    spanning-tree 2/20 bpdu-protection
    spanning-tree 2/21 admin-edge-port
    spanning-tree 2/21 bpdu-protection
    spanning-tree 2/22 admin-edge-port
    spanning-tree 2/22 bpdu-protection
    spanning-tree 2/23 admin-edge-port
    spanning-tree 2/23 bpdu-protection
    spanning-tree 2/24 admin-edge-port
    spanning-tree 2/24 bpdu-protection
    spanning-tree 2/25 admin-edge-port
    spanning-tree 2/25 bpdu-protection
    spanning-tree 2/26 admin-edge-port
    spanning-tree 2/26 bpdu-protection
    spanning-tree 2/27 admin-edge-port
    spanning-tree 2/27 bpdu-protection
    spanning-tree 2/28 admin-edge-port
    spanning-tree 2/28 bpdu-protection
    spanning-tree 2/29 admin-edge-port
    spanning-tree 2/29 bpdu-protection
    spanning-tree 2/30 admin-edge-port
    spanning-tree 2/30 bpdu-protection
    spanning-tree 2/31 admin-edge-port
    spanning-tree 2/31 bpdu-protection
    spanning-tree 2/32 admin-edge-port
    spanning-tree 2/32 bpdu-protection
    spanning-tree 2/33 admin-edge-port
    spanning-tree 2/33 bpdu-protection
    spanning-tree 2/34 admin-edge-port
    spanning-tree 2/34 bpdu-protection
    spanning-tree 2/35 admin-edge-port
    spanning-tree 2/35 bpdu-protection
    spanning-tree 2/36 admin-edge-port
    spanning-tree 2/36 bpdu-protection
    spanning-tree 2/37 admin-edge-port
    spanning-tree 2/37 bpdu-protection
    spanning-tree 2/38 admin-edge-port
    spanning-tree 2/38 bpdu-protection
    spanning-tree 2/39 admin-edge-port
    spanning-tree 2/39 bpdu-protection
    spanning-tree 2/40 admin-edge-port
    spanning-tree 2/40 bpdu-protection
    spanning-tree 2/41 admin-edge-port
    spanning-tree 2/41 bpdu-protection
    spanning-tree 2/42 admin-edge-port
    spanning-tree 2/42 bpdu-protection
    spanning-tree 2/43 admin-edge-port
    spanning-tree 2/43 bpdu-protection
    spanning-tree 2/44 admin-edge-port
    spanning-tree 2/44 bpdu-protection
    spanning-tree 2/45 admin-edge-port
    spanning-tree 2/45 bpdu-protection
    spanning-tree 2/46 admin-edge-port
    spanning-tree 2/46 bpdu-protection
    spanning-tree 2/47 admin-edge-port
    spanning-tree 2/47 bpdu-protection
    spanning-tree 2/48 admin-edge-port
    spanning-tree 2/48 bpdu-protection
    spanning-tree 3/1 admin-edge-port
    spanning-tree 3/1 bpdu-protection
    spanning-tree 3/2 admin-edge-port
    spanning-tree 3/2 bpdu-protection
    spanning-tree 3/3 admin-edge-port
    spanning-tree 3/3 bpdu-protection
    spanning-tree 3/4 admin-edge-port
    spanning-tree 3/4 bpdu-protection
    spanning-tree 3/5 admin-edge-port
    spanning-tree 3/5 bpdu-protection
    spanning-tree 3/6 admin-edge-port
    spanning-tree 3/6 bpdu-protection
    spanning-tree 3/7 admin-edge-port
    spanning-tree 3/7 bpdu-protection
    spanning-tree 3/8 admin-edge-port
    spanning-tree 3/8 bpdu-protection
    spanning-tree 3/9 admin-edge-port
    spanning-tree 3/9 bpdu-protection
    spanning-tree 3/10 admin-edge-port
    spanning-tree 3/10 bpdu-protection
    spanning-tree 3/11 admin-edge-port
    spanning-tree 3/11 bpdu-protection
    spanning-tree 3/12 admin-edge-port
    spanning-tree 3/12 bpdu-protection
    spanning-tree 3/13 admin-edge-port
    spanning-tree 3/13 bpdu-protection
    spanning-tree 3/14 admin-edge-port
    spanning-tree 3/14 bpdu-protection
    spanning-tree 3/15 admin-edge-port
    spanning-tree 3/15 bpdu-protection
    spanning-tree 3/16 admin-edge-port
    spanning-tree 3/16 bpdu-protection
    spanning-tree 3/17 admin-edge-port
    spanning-tree 3/17 bpdu-protection
    spanning-tree 3/18 admin-edge-port
    spanning-tree 3/18 bpdu-protection
    spanning-tree 3/19 admin-edge-port
    spanning-tree 3/19 bpdu-protection
    spanning-tree 3/20 admin-edge-port
    spanning-tree 3/20 bpdu-protection
    spanning-tree 3/21 admin-edge-port
    spanning-tree 3/21 bpdu-protection
    spanning-tree 3/22 admin-edge-port
    spanning-tree 3/22 bpdu-protection
    spanning-tree 3/23 admin-edge-port
    spanning-tree 3/23 bpdu-protection
    spanning-tree 3/24 admin-edge-port
    spanning-tree 3/24 bpdu-protection
    spanning-tree 3/25 admin-edge-port
    spanning-tree 3/25 bpdu-protection
    spanning-tree 3/26 admin-edge-port
    spanning-tree 3/26 bpdu-protection
    spanning-tree 3/27 admin-edge-port
    spanning-tree 3/27 bpdu-protection
    spanning-tree 3/28 admin-edge-port
    spanning-tree 3/28 bpdu-protection
    spanning-tree 3/29 admin-edge-port
    spanning-tree 3/29 bpdu-protection
    spanning-tree 3/30 admin-edge-port
    spanning-tree 3/30 bpdu-protection
    spanning-tree 3/31 admin-edge-port
    spanning-tree 3/31 bpdu-protection
    spanning-tree 3/32 admin-edge-port
    spanning-tree 3/32 bpdu-protection
    spanning-tree 3/33 admin-edge-port
    spanning-tree 3/33 bpdu-protection
    spanning-tree 3/34 admin-edge-port
    spanning-tree 3/34 bpdu-protection
    spanning-tree 3/35 admin-edge-port
    spanning-tree 3/35 bpdu-protection
    spanning-tree 3/36 admin-edge-port
    spanning-tree 3/36 bpdu-protection
    spanning-tree 3/37 admin-edge-port
    spanning-tree 3/37 bpdu-protection
    spanning-tree 3/38 admin-edge-port
    spanning-tree 3/38 bpdu-protection
    spanning-tree 3/39 admin-edge-port
    spanning-tree 3/39 bpdu-protection
    spanning-tree 3/40 admin-edge-port
    spanning-tree 3/40 bpdu-protection
    spanning-tree 3/41 admin-edge-port
    spanning-tree 3/41 bpdu-protection
    spanning-tree 3/42 admin-edge-port
    spanning-tree 3/42 bpdu-protection
    spanning-tree 3/43 admin-edge-port
    spanning-tree 3/43 bpdu-protection
    spanning-tree 3/44 admin-edge-port
    spanning-tree 3/44 bpdu-protection
    spanning-tree 3/45 admin-edge-port
    spanning-tree 3/45 bpdu-protection
    spanning-tree 3/46 admin-edge-port
    spanning-tree 3/46 bpdu-protection
    spanning-tree 3/47 admin-edge-port
    spanning-tree 3/47 bpdu-protection
    spanning-tree 3/48 admin-edge-port
    spanning-tree 3/48 bpdu-protection
    spanning-tree 4/1 admin-edge-port
    spanning-tree 4/1 bpdu-protection
    spanning-tree 4/2 admin-edge-port
    spanning-tree 4/2 bpdu-protection
    spanning-tree 4/3 admin-edge-port
    spanning-tree 4/3 bpdu-protection
    spanning-tree 4/4 admin-edge-port
    spanning-tree 4/4 bpdu-protection
    spanning-tree 4/5 admin-edge-port
    spanning-tree 4/5 bpdu-protection
    spanning-tree 4/6 admin-edge-port
    spanning-tree 4/6 bpdu-protection
    spanning-tree 4/7 admin-edge-port
    spanning-tree 4/7 bpdu-protection
    spanning-tree 4/8 admin-edge-port
    spanning-tree 4/8 bpdu-protection
    spanning-tree 4/9 admin-edge-port
    spanning-tree 4/9 bpdu-protection
    spanning-tree 4/10 admin-edge-port
    spanning-tree 4/10 bpdu-protection
    spanning-tree 4/11 admin-edge-port
    spanning-tree 4/11 bpdu-protection
    spanning-tree 4/12 admin-edge-port
    spanning-tree 4/12 bpdu-protection
    spanning-tree 4/13 admin-edge-port
    spanning-tree 4/13 bpdu-protection
    spanning-tree 4/14 admin-edge-port
    spanning-tree 4/14 bpdu-protection
    spanning-tree 4/15 admin-edge-port
    spanning-tree 4/15 bpdu-protection
    spanning-tree 4/16 admin-edge-port
    spanning-tree 4/16 bpdu-protection
    spanning-tree 4/17 admin-edge-port
    spanning-tree 4/17 bpdu-protection
    spanning-tree 4/18 admin-edge-port
    spanning-tree 4/18 bpdu-protection
    spanning-tree 4/19 admin-edge-port
    spanning-tree 4/19 bpdu-protection
    spanning-tree 4/20 admin-edge-port
    spanning-tree 4/20 bpdu-protection
    spanning-tree 4/21 admin-edge-port
    spanning-tree 4/21 bpdu-protection
    spanning-tree 4/22 admin-edge-port
    spanning-tree 4/22 bpdu-protection
    spanning-tree 4/23 admin-edge-port
    spanning-tree 4/23 bpdu-protection
    spanning-tree 4/24 admin-edge-port
    spanning-tree 4/24 bpdu-protection
    spanning-tree 4/25 admin-edge-port
    spanning-tree 4/25 bpdu-protection
    spanning-tree 4/26 admin-edge-port
    spanning-tree 4/26 bpdu-protection
    spanning-tree 4/27 admin-edge-port
    spanning-tree 4/27 bpdu-protection
    spanning-tree 4/28 admin-edge-port
    spanning-tree 4/28 bpdu-protection
    spanning-tree 4/29 admin-edge-port
    spanning-tree 4/29 bpdu-protection
    spanning-tree 4/30 admin-edge-port
    spanning-tree 4/30 bpdu-protection
    spanning-tree 4/31 admin-edge-port
    spanning-tree 4/31 bpdu-protection
    spanning-tree 4/32 admin-edge-port
    spanning-tree 4/32 bpdu-protection
    spanning-tree 4/33 admin-edge-port
    spanning-tree 4/33 bpdu-protection
    spanning-tree 4/34 admin-edge-port
    spanning-tree 4/34 bpdu-protection
    spanning-tree 4/35 admin-edge-port
    spanning-tree 4/35 bpdu-protection
    spanning-tree 4/36 admin-edge-port
    spanning-tree 4/36 bpdu-protection
    spanning-tree 4/37 admin-edge-port
    spanning-tree 4/37 bpdu-protection
    spanning-tree 4/38 admin-edge-port
    spanning-tree 4/38 bpdu-protection
    spanning-tree 4/39 admin-edge-port
    spanning-tree 4/39 bpdu-protection
    spanning-tree 4/40 admin-edge-port
    spanning-tree 4/40 bpdu-protection
    spanning-tree 4/41 admin-edge-port
    spanning-tree 4/41 bpdu-protection
    spanning-tree 4/42 admin-edge-port
    spanning-tree 4/42 bpdu-protection
    spanning-tree 4/43 admin-edge-port
    spanning-tree 4/43 bpdu-protection
    spanning-tree 4/44 admin-edge-port
    spanning-tree 4/44 bpdu-protection
    spanning-tree 4/45 admin-edge-port
    spanning-tree 4/45 bpdu-protection
    spanning-tree 4/46 admin-edge-port
    spanning-tree 4/46 bpdu-protection
    spanning-tree 4/47 admin-edge-port
    spanning-tree 4/47 bpdu-protection
    spanning-tree 5/1 admin-edge-port
    spanning-tree 5/1 bpdu-protection
    spanning-tree 5/2 admin-edge-port
    spanning-tree 5/2 bpdu-protection
    spanning-tree 5/3 admin-edge-port
    spanning-tree 5/3 bpdu-protection
    spanning-tree 5/4 admin-edge-port
    spanning-tree 5/4 bpdu-protection
    spanning-tree 5/5 admin-edge-port
    spanning-tree 5/5 bpdu-protection
    spanning-tree 5/6 admin-edge-port
    spanning-tree 5/6 bpdu-protection
    spanning-tree 5/7 admin-edge-port
    spanning-tree 5/7 bpdu-protection
    spanning-tree 5/8 admin-edge-port
    spanning-tree 5/8 bpdu-protection
    spanning-tree 5/9 admin-edge-port
    spanning-tree 5/9 bpdu-protection
    spanning-tree 5/10 admin-edge-port
    spanning-tree 5/10 bpdu-protection
    spanning-tree 5/11 admin-edge-port
    spanning-tree 5/11 bpdu-protection
    spanning-tree 5/12 admin-edge-port
    spanning-tree 5/12 bpdu-protection
    spanning-tree 5/13 admin-edge-port
    spanning-tree 5/13 bpdu-protection
    spanning-tree 5/14 admin-edge-port
    spanning-tree 5/14 bpdu-protection
    spanning-tree 5/15 admin-edge-port
    spanning-tree 5/15 bpdu-protection
    spanning-tree 5/16 admin-edge-port
    spanning-tree 5/16 bpdu-protection
    spanning-tree 5/17 admin-edge-port
    spanning-tree 5/17 bpdu-protection
    spanning-tree 5/18 admin-edge-port
    spanning-tree 5/18 bpdu-protection
    spanning-tree 5/19 admin-edge-port
    spanning-tree 5/19 bpdu-protection
    spanning-tree 5/20 admin-edge-port
    spanning-tree 5/20 bpdu-protection
    spanning-tree 5/21 admin-edge-port
    spanning-tree 5/21 bpdu-protection
    spanning-tree 5/22 admin-edge-port
    spanning-tree 5/22 bpdu-protection
    spanning-tree 5/23 admin-edge-port
    spanning-tree 5/23 bpdu-protection
    spanning-tree 5/24 admin-edge-port
    spanning-tree 5/24 bpdu-protection
    spanning-tree 5/25 admin-edge-port
    spanning-tree 5/25 bpdu-protection
    spanning-tree 5/26 admin-edge-port
    spanning-tree 5/26 bpdu-protection
    spanning-tree 5/27 admin-edge-port
    spanning-tree 5/27 bpdu-protection
    spanning-tree 5/28 admin-edge-port
    spanning-tree 5/28 bpdu-protection
    spanning-tree 5/29 admin-edge-port
    spanning-tree 5/29 bpdu-protection
    spanning-tree 5/30 admin-edge-port
    spanning-tree 5/30 bpdu-protection
    spanning-tree 5/31 admin-edge-port
    spanning-tree 5/31 bpdu-protection
    spanning-tree 5/32 admin-edge-port
    spanning-tree 5/32 bpdu-protection
    spanning-tree 5/33 admin-edge-port
    spanning-tree 5/33 bpdu-protection
    spanning-tree 5/34 admin-edge-port
    spanning-tree 5/34 bpdu-protection
    spanning-tree 5/35 admin-edge-port
    spanning-tree 5/35 bpdu-protection
    spanning-tree 5/36 admin-edge-port
    spanning-tree 5/36 bpdu-protection
    spanning-tree 5/37 admin-edge-port
    spanning-tree 5/37 bpdu-protection
    spanning-tree 5/38 admin-edge-port
    spanning-tree 5/38 bpdu-protection
    spanning-tree 5/39 admin-edge-port
    spanning-tree 5/39 bpdu-protection
    spanning-tree 5/40 admin-edge-port
    spanning-tree 5/40 bpdu-protection
    spanning-tree 5/41 admin-edge-port
    spanning-tree 5/41 bpdu-protection
    spanning-tree 5/42 admin-edge-port
    spanning-tree 5/42 bpdu-protection
    spanning-tree 5/43 admin-edge-port
    spanning-tree 5/43 bpdu-protection
    spanning-tree 5/44 admin-edge-port
    spanning-tree 5/44 bpdu-protection
    spanning-tree 5/45 admin-edge-port
    spanning-tree 5/45 bpdu-protection
    spanning-tree 5/46 admin-edge-port
    spanning-tree 5/46 bpdu-protection
    spanning-tree 5/47 admin-edge-port
    spanning-tree 5/47 bpdu-protection
    spanning-tree 5/48 admin-edge-port
    spanning-tree 5/48 bpdu-protection
    spanning-tree Trk2 priority 4
    no tftp server
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    no dhcp tr69-acs-url
    Cheikh mbow
  • 2.  RE: Switch 2930F member stack rebooting
    Posted Oct 08, 2021 01:04 PM
    NPQ3ASW002# show vsf
    VSF Domain ID : 2
    MAC Address :
    VSF Topology : Ring
    VSF Status : Active
    Uptime : 2d 17h 56m
    VSF MAD : None
    VSF Port Speed : 10G
    Software Version : WC.16.10.0015
    Mbr
    ID MAC Address Model Pri Status
    1 64e881-0c1b80 Aruba JL256A 2930F-48G-PoE+-4SFP+ ... 255 Member
    2 64e881-0c2fc0 Aruba JL256A 2930F-48G-PoE+-4SFP+ ... 254 Commander
    3 64e881-0c3a40 Aruba JL256A 2930F-48G-PoE+-4SFP+ ... 253 Standby
    4 64e881-0c3fc0 Aruba JL256A 2930F-48G-PoE+-4SFP+ ... 252 Member
    5 64e881-0dc000 Aruba JL256A 2930F-48G-PoE+-4SFP+ ... 251 Member
    Member 1 was the commander before
    Cheikh mbow
  • 3.  RE: Switch 2930F member stack rebooting
    MVP GURU
    Posted Oct 08, 2021 08:41 PM
    Your log reports at least 60 falied login attempts (3 using Telnet and 57 using SSH) between 04:04:02 and 05:44:18 on 06-10-2021.
    Your log reports at least 2 successful login:
    I 10/06/21 04:03:52 03362 auth: ST2-CMDR: User 'unknown' logged in from x.x.x.x to TELNET session
    I 10/06/21 09:56:33 03362 auth: ST2-CMDR: User 'admin' logged in from x.x.x.x.123.19 to SSH session
    Your log reports at least 37 Security Access violations.
    Is alle the above "normal" in your opinion?
    Davide Poletto
  • 4.  RE: Switch 2930F member stack rebooting
    Posted Oct 08, 2021 11:06 PM
  • 5.  RE: Switch 2930F member stack rebooting
    Posted Oct 08, 2021 11:30 PM
    I verified the IP that attempts to login, it's our vulnerability scan serveur... (rapid 7), So it's not a problem.
    Cheikh mbow
  • 6.  RE: Switch 2930F member stack rebooting
    MVP GURU
    Posted Oct 09, 2021 03:33 PM
    Hello Cheikh mbow, If I were you I will:
    1. try to diagnose/isolate any potential Hardware related issue (Power Supplies failures, as example).
    2. immediately stop the Rapid7 vulnerability scanner to recursively target the VSF cluster.
    3. check proper configuration of SNMP if it is a necessary service (disable it if it is not required).
    then, once done 1+2+3, observe if something (positively) change on your VSF and report back.
    Davide Poletto
  • 7.  RE: Switch 2930F member stack rebooting
    Posted Oct 09, 2021 04:18 PM
    Yes, i replace the member 1 today. I will monitor the stack and see if it will reboot.
    Thank you!!!
    Cheikh mbow
