Enabled device fingerprinting on switch covering dhcp,lldp and. http
device-fingerprinting timer 60
device-fingerprinting policy "nd-dev-policy"
dhcp
http
lldp
exit
device-fingerprinting apply policy "nd-dev-policy" 2-8
In this case AP has a static IP so dhcp collector not in operation
But does return lldc info
Original Message:
Sent: 11/29/2023 1:41:00 AM
Subject: RE: Switch collector not identifying Arbua AP
Hello how you send information to clearpass to profile ? DHCP fingerprinting , snmp information from the switch ?
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/7a18575c33554f1a8888c25d6dc292c8.png)
This is just an example from my environment
Original Message:
Sent: Nov 28, 2023 10:28 AM
Subject: Switch collector not identifying Arbua AP
2930 switch WC.16.11.13, cppm 6.11.5
I have some aruba 225 APs connectted to a 2930 switch with device -fingerprinting enabled. (dhpc,lldp, http) The APs are using static IP addresses
in clearpass it identifies the device as /Generic/Aruba and not as /Access Points/Aruba/ArubaAP. Looking in endpoints under device fingerprints i can see that LLDP System Desciption = "ArubaOS (Model 225), Version Aruba AP"
shouldnt cppm use the lldp info to create the correct endpoint fingerprint?
Can create a custom fingerprint specficially for that lldp entry and assign the fingerprint,m but shouldnt cppm do that?
A
