  • 1.  Switch collector not identifying Arbua AP
    Posted Nov 28, 2023 10:28 AM
    2930 switch WC.16.11.13, cppm 6.11.5
    I have some aruba 225 APs connectted to  a 2930 switch with device -fingerprinting enabled. (dhpc,lldp, http) The APs are using static IP addresses
    in clearpass it identifies the device as /Generic/Aruba and not as /Access Points/Aruba/ArubaAP. Looking in endpoints under device fingerprints i can see that  LLDP System Desciption = "ArubaOS (Model 225), Version Aruba AP"
    shouldnt cppm use the lldp info to  create  the correct endpoint fingerprint?
    Can  create a custom fingerprint specficially for  that lldp entry and assign the fingerprint,m but shouldnt  cppm do that?
    A
  • 2.  RE: Switch collector not identifying Arbua AP
    Posted Nov 29, 2023 01:41 AM
    Hello how you send information to clearpass to profile ? DHCP fingerprinting , snmp information from the switch ?
    This is just an example from my environment
  • 3.  RE: Switch collector not identifying Arbua AP
    Posted Nov 29, 2023 04:44 AM
    Enabled device fingerprinting on switch covering dhcp,lldp and. http
    device-fingerprinting timer 60
    device-fingerprinting policy "nd-dev-policy"
    dhcp
    http
    lldp
    exit
    device-fingerprinting apply policy "nd-dev-policy" 2-8
    In this case AP has a static IP so dhcp collector not in operation
    But does return lldc info
  • 4.  RE: Switch collector not identifying Arbua AP
    Posted Nov 29, 2023 04:50 AM
    Forgot to mention yes your device fingerprint looks fine, but if you go to endpoints and look at the end-host-profile in my case, when an ap has a static ip you don’t get Access Points/ Aruba/ ArubnaAP you get General/Aruba/….. so its just using the Mac OUI to identify the device
    So if you’re assigning aa role based upon th end-host-profile it fails
    Solved it by adding a custom fingerprint checking for Aruba OUI and. Lldp having a string particular to an ap 225
    A
