Cloud Managed Networks
Switch config guide or manual
This thread has been viewed 37 times
  • 1.  Switch config guide or manual
    Posted 25 days ago
    Where can I find a guide that will list all the different config lines I can add to my 6200/6300 switches? We have all central managed switches but there are many things we cannot do in central that must be done via multi-edit. I need a guide that can tell me what can be added to the configs in multi-edit. For example, we need to disable POE per port. We also need to setup some port mirrors. CLI commands do not help since we can't use the CLI with central to make changes. Thanks!
  • 2.  RE: Switch config guide or manual
    Posted 24 days ago
    for that you need to refer to the switch user guides
    you can use MultiEdit and configure the switches for port mirrors.
  • 3.  RE: Switch config guide or manual
    Posted 24 days ago
    And ArubaOS-CX CLI Bank is a great resource for quickly find the command syntax.
    Don't forget to explore the CLI Bank home for other platforms :-)
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 4.  RE: Switch config guide or manual
    Posted 23 days ago
    But how do I use the CLI within multiedit? The guide gives you commands to use in sequence but I can't do that in multiedit. I need to add the final lines to the config.
  • 5.  RE: Switch config guide or manual
    Posted 22 days ago
    give us an example CLI snippet that you can not use in multi-edit.
  • 6.  RE: Switch config guide or manual
    Posted 22 days ago
    Examples
    Creating a mirror session and adding a VLAN as a source of traffic in both directions on that port:
    switch# configure terminal
    switch(config)# mirror session 1
    switch(config-mirror-1)# source vlan 10 both
    Creating a mirror session and adding two VLANs as sources of traffic:
    directions:
    switch(config)# mirror session 2
    switch(config-mirror-2)# source vlan 10 tx
    switch(config-mirror-2)# source vlan 20 both
  • 7.  RE: Switch config guide or manual
    Posted 21 days ago
    it works for me.
  • 8.  RE: Switch config guide or manual
    Posted 21 days ago
    Cool thanks. I'm so glad we paid all this money for central so we could get "multi edit" instead of a regular cli.
