Switch Dell N2024 CoA
  • 1.  Switch Dell N2024 CoA
    Posted 8 days ago
    Hello guys,
    I have configured Dell switch N2024 with 802.1X, Authc, authz, accounting and dyn-author, in ClearPass side I add this switch as IETF device and create a profile named Dell CoA using IETF CoA default from system.
    The authentication it's occurred perfectly, but when I will in change status via access tracker I unable send someone CoA actions, I remove configuration from switch e reinsert, but doesn't work.
    The firmware that using is 6.7.1.21.
    Any ideias?
    Thank you.
  • 2.  RE: Switch Dell N2024 CoA
    Posted 7 days ago
    i think your clearpass configuration is fine. In the past i had lots of issues with Dell switches and most of them caused by the switch firmware.
  • 3.  RE: Switch Dell N2024 CoA
    Posted 5 days ago
    I will to check if has other firmware version.
    I let you know.
