Wired Intelligent Edge
switch fabric speed vs. routing/switching capacity
  • 1.  switch fabric speed vs. routing/switching capacity
    Posted Sep 05, 2019 01:33 PM
    after reading through the Datasheet of the Aruba 5406 the following question came up... what is meant by switch fabric speed vs. routing/switching capacity and where is the difference?
    If someone could help me to better understand that in detail, I`d be really grateful!
  • 2.  RE: switch fabric speed vs. routing/switching capacity
    Posted Sep 09, 2019 12:08 PM
    Hi Daniel.
    If you see, maximun port capacity por Aruba 5406R is reached with 12 40GE ports. In that situation, your routing/switching capacity is: 12x40Gbps = 480 Gbps, and considering in/out direction (full duplex) you get the 960 Gbps of the datasheet. So your switch needs a minimun switching capacity of 960 Gbps to work at wire-speed. It seems that switch fabric speed is the internal swithing structure of the switch (not available to public, only to Aruba HPE personnel) that is used to serve that minimun switching capacity.
    You need 960 Gbps (that depends on the physical port configuration of your switch) considering the mentioned port configuration, and the switch has 1015 Gbps to serve that demand (switch fabric speed). If we suposse there is no other routing/switching demand, the switch has 55 Gbps to serve a higher demand.
    I hope we have another extra input about this info in the datasheets.
    Regards
  • 3.  RE: switch fabric speed vs. routing/switching capacity
    MVP GURU
    Posted Sep 12, 2019 06:40 PM
    Hi! I think the 55 Gbps delta between calculated switching speeds (960 Gbps versus 1015 Gbps) would be directly related to the Packet Size used to perform the speed test: 64 Bytes long versus > 64 Bytes long.
