Comware
  • 1.  Switch HP V1910-24G JE006A - Program does not exist
    Posted Feb 10, 2020 03:06 PM
    Hello people. I was trying to reset my HP V1910-24G JE006A Switch, and by mistake, I ended up pressing Ctrl + F Format File System.
    Now I'm unable to access it via the web or access the CLI, to restore it to the factory default. Only the message appears: Application does not exist.
    I have already imported several images via Serial / XMODEM, however, the switch does not apply these images. Some help?
    #switch
    #factory
    #Default
    #reset
  • 2.  RE: Switch HP V1910-24G JE006A - Program does not exist
    Posted Feb 27, 2020 07:43 AM
    Hi NikolasDelfino,
    You can use the below procedure:
    1. Download the images from https://h10145.www1.hpe.com/support/SupportLookUp.aspx. Example 1910-CMW520-R1519P06.bin
    1. Connect a PC to the switch console and connect the PC to a switch port using a LAN cable.
    1. Configure FTP server on the PC. Example Filezilla
    1. From the boot menu:
                - Download application file to flash, select FTP and configure the FTP parameters – filename, switch IP, server IP, etc. Wait for the transfer.
                - Verify the upload with Display all files in flash then Select application file to boot.
                - Reboot.
    I hope this helps.
