Wired Intelligent Edge
Switch is pingable then not but all devices connected are working.
  • 1.  Switch is pingable then not but all devices connected are working.
    Posted Feb 19, 2020 05:27 PM
    Hello all I have  several switches in my environment and at times some are no longer able to be pinged but yet all the devices connected to it are working and receive and IP address.
    I'm new to this so please don't mind the lingo
    hpStack_WC Configuration Editor; Created on release #WC.16.04.0008
    ; Ver #10:9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:ad
    stacking
    member 1 type "JL322A" mac-address 040973-b60000
    member 1 flexible-module A type JL083A
    member 2 type "JL322A" mac-address 040973-b6c380
    member 2 flexible-module A type JL083A
    exit
    hostname "Aruba-Stack-2930M"
    trunk 1/A1,2/A1 trk3 lacp
    logging 172.31.192.77
    logging system-module ip
    logging notify running-config-change
    timesync sntp
    sntp unicast
    sntp server priority 1 172.31.192.1
    time daylight-time-rule continental-us-and-canada
    time timezone -5
    ip default-gateway 172.31.192.1
    snmp-server community "public" unrestricted
    snmp-server location "Bulding 3"
    oobm
    ip address dhcp-bootp
    member 1
    exit
    member 2
    exit
    exit
    vlan 1
    name "DEFAULT_VLAN"
    no untagged
    1/1-1/6,1/8-1/13,1/15,1/19,1/21,1/24-1/26,1/28-1/32,1/34-1/35,1/39,1/42-1/43,1/
    46-1/48,2/1,2/3-2/15,2/17,2/19,2/21,2/23-2/24,2/26,2/28,2/30,2/32,2/34,2/36,2/38
    ,2/48,Trk3
    untagged
    1/7,1/14,1/16-1/18,1/20,1/22-1/23,1/27,1/33,1/36-1/38,1/40-1/41,1/44-1/45,1/A2-
    1/A4,2/2,2/16,2/18,2/20,2/22,2/25,2/27,2/29,2/31,2/33,2/35,2/37,2/39-2/47,2/A2-2
    /A4
    no ip address
    exit
    Aruba-Stack-2930M# show running-config
    Running configuration:
    ; hpStack_WC Configuration Editor; Created on release #WC.16.04.0008
    stacking
    exit
    timesync sntp
    sntp unicast
    time timezone -5
    oobm
    member 1
    exit
    member 2
    exit
    exit
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 1/1-1/6,1/8-1/13,1/15,1/19,1/21,1/24-1/26,1/28-1/32,1/34-1/35,1/39,1/42-1/43,1/46-1/48,2/1,2/3-2/15,2/17,2/19,2/21,2/23-2/24,2/26,2/28,2/30,2/32,2/34,2/36,2/38,2/48,Trk3
    untagged 1/7,1/14,1/16-1/18,1/20,1/22-1/23,1/27,1/33,1/36-1/38,1/40-1/41,1/44-1/45,1/A2-1/A4,2/2,2/16,2/18,2/20,2/22,2/25,2/27,2/29,2/31,2/33,2/35,2/37,2/39-2/47,2/A2-2/A4
    no ip address
    exit
    vlan 2
    name "ECEC"
    tagged 1/3,1/5,1/11,1/13,1/15,1/21,1/29-1/32,1/35,1/39,1/43,Trk3
    no ip address
    exit
    vlan 8
    name "Elementary"
    no ip address
    exit
    vlan 16
    name "Highschool"
    no ip address
    exit
    vlan 24
    name "Admin"
    untagged 1/1,1/9,1/25
    no ip address
    exit
    vlan 32
    name "Office"
    untagged 1/2,1/4,1/10,1/24,1/28,1/34,1/42,1/46-1/47,2/24
    no ip address
    exit
    vlan 48
    name "Printers"
    untagged 1/19,1/26
    tagged Trk3
    no ip address
    exit
    vlan 64
    name "Phone"
    untagged 1/6,1/8,2/4,2/6,2/8,2/10,2/12,2/26,2/28,2/30,2/32,2/34,2/36,2/38
    tagged 1/1-1/2,1/5,1/11,1/13,1/15,1/21,1/25,1/29-1/32,1/35,1/39,1/43,2/14,2/24,Trk3
    no ip address
    exit
    vlan 96
    name "Facilities"
    tagged Trk3
    no ip address
    exit
    vlan 128
    name "SecurityCameras"
    untagged 1/12,2/1,2/3,2/5,2/7,2/9,2/11,2/13,2/15,2/17,2/19,2/21,2/23
    tagged Trk3
    no ip address
    exit
    vlan 192
    name "Management"
    untagged 1/3,1/5,1/11,1/13,1/15,1/21,1/29-1/32,1/35,1/39,1/43,1/48,2/48
    tagged Trk3
    ip address 172.31.192.13 255.255.255.0
    exit
    spanning-tree Trk3 priority 4
    no tftp client
    no tftp server
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    no dhcp tr69-acs-url
    password manager
    password operator
  • 2.  RE: Switch is pingable then not but all devices connected are working.
    MVP GURU
    Posted Feb 20, 2020 04:38 AM
    What don't work ?
  • 3.  RE: Switch is pingable then not but all devices connected are working.
    Posted Feb 20, 2020 08:23 AM
    Well all devices connected to it are working fine. But I am unable to access it either via ping from another client, from another switch, or putty cli
  • 4.  RE: Switch is pingable then not but all devices connected are working.
    Posted Feb 20, 2020 08:31 AM
    Have you ever been able to ping/telnet or ssh the "problem" switch?
    What  ip number are you pinging?
    How are you currently configuring the "problem" switch?
    If the console port, can you ping other switches from the "problem" switch?
  • 5.  RE: Switch is pingable then not but all devices connected are working.
    Posted Feb 20, 2020 09:10 AM
    Have you ever been able to ping/telnet or ssh the "problem" switch? YEs It works then all of a sudden I can't get to it anymore.
    What  ip number are you pinging? It's on the management Vlan I ping its ip address
    If the console port, can you ping other switches from the "problem" switch? Going to do that now. Standby
    /smb/air (formerly: aoscx-noob)
  • 6.  RE: Switch is pingable then not but all devices connected are working.
    Posted Feb 20, 2020 03:13 PM
    I will be offline for 18-24 hours.
    BIG guess: Try tagging at a minimum, Trk3 within VLAN 1.
    Also, can you consistently ping the "problem switch" from GW:172.31.192.1  ?
    Consistently Telnet/ssh from the GW?
    Seriously consider upgrading all problem 2930F's to WC_16_10_0005
  • 7.  RE: Switch is pingable then not but all devices connected are working.
    Posted Feb 20, 2020 07:22 AM
    I too have experienced your "ping" symptoms.  Your symptoms do not seem detrimental.
    Seeking additional information from Touche27:
    Diagram how the "several switches" are connected one to the other.
    Identify the switches by using the IP numbers that are assigned to the switches.
    Are you pinging from one switch to another or from a client?
  • 8.  RE: Switch is pingable then not but all devices connected are working.
    Posted Feb 20, 2020 08:17 AM
    from a client.
  • 9.  RE: Switch is pingable then not but all devices connected are working.
    Posted Feb 20, 2020 08:22 AM
    I just did a ping from another switch and i am getting no replies
  • 10.  RE: Switch is pingable then not but all devices connected are working.
    MVP GURU
    Posted Feb 20, 2020 04:13 PM
    Hi Touche27, first I suggest you to keep your Aruba 2930M stack updated (WC.16.04.0008 July 2017 --> WC.16.10.0005 February 2020)...then what's about providing the output of show lldp info remote-device CLI command?
    The configuration you posted shows us that trk3 (LACP) goes probably to the router responsible for IPv4 routing of VLANs defined and used into your stack...so any ICMP related issue should involve diagnosing it too.
    Suppose all of your Switches are interconnected using a particular VLAN, call it Switch Management VLAN (in a hub and spoke way and your Aruba 2930M stack is the center of your network map)...they could ping each others using that VLAN if they have a common IP Addressing (each of them uses a common IP Default Gateway to ping hosts on other VLANs provided that that gateway routes each VLAN).
    Clearly each switch must be connected through an uplink which is configured, on both ends, to carry that particular VLAN id.
