Wired Intelligent Edge
Switch management
  • 1.  Switch management
    Posted Apr 23, 2019 05:45 AM
    Hi there,
    I'm new to Aruba Switches; we have replaced several Cisco switches with Aruba Swithes. The only issue here is we can manage the switches indiviudaly (via VLAN management ) to add/remove VLANs, port status, ..etc, so is there a way for example to use one IP address to manage/veiw all the switches.
  • 2.  RE: Switch management
    Posted Apr 23, 2019 12:35 PM
    Hello you can add them all in Airwave and manage them from Airwave. I am not sure, if there is a way on Switches directly if you do not have Airwave.
  • 3.  RE: Switch management
    Posted Apr 23, 2019 01:32 PM
    Greetings!
    Depending on your switch model, you may be able to utilize our front plane stacking feature (Virtual Switching Framework, or VSF) or dedicated backplane stacking, which would combine multiple switches into a single logical switch that has a single point of management.
    The other option is to utilize a management platform such as AirWave or Central to manage multiple devices from a single interface.
