Cloud Managed Networks
Switch not in sync
This thread has been viewed 39 times
  • 1.  Switch not in sync
    Posted Nov 19, 2020 02:34 AM
    Hi All,
    I have configured a number of switches (same model and firmware) in Aruba Central using Template Groups and all are In Sync except 2.
    When the template is pushed to the switch there is very little information in the Audit Trail, and the log on the switch shows these entries which are pretty vague.
    Any ideas on troubleshooting this?
    Thanks in advance.
    ---- Reverse event Log listing: Events Since Boot ----
    I 11/19/20 16:55:56 05633 cfgRestore: Successfully restored source configuration
    REST_Payload to running configuration.
    I 11/19/20 16:55:54 05257 central: Aruba Central support mode is enabled.
    I 11/19/20 16:55:52 05639 cfgRestore: Configuration restore to REST_Payload has
    failed, started recovery to source config.
    I 11/19/20 16:55:45 05258 central: Aruba Central support mode is disabled.
    I 11/19/20 16:55:43 05690 cfgRestore: Configuration restore is initiated.
    I 11/19/20 16:55:42 05578 profile-manager: With this SW release the poe-value
    field is not allowed to be set when poe-alloc-by is not value.
    Changing to default value of 17w.
    I 11/19/20 16:55:40 02716 auth: User admin : Manager mode password is set
    Andrew Joraslafsky
  • 2.  RE: Switch not in sync
    Posted Nov 23, 2020 05:02 AM
    Please check you configure the Manager password for the Switch because its required when you add switch to Central through template
    Tharindu Pamoda
