Hello Everyone,
I am trying to setup a dhcp pool for IAPs to pull from during configuration off of a S1500 switch.
I have the following in the switch... but what else is needed?
ip dhcp pool "pool-1"
domain-name "doc-domain"
network 192.168.1.0 255.255.255.0
lease 30 24 60 60
default-router 192.168.1.1
dns-server 8.8.8.8
exclude-address 192.168.1.1 192.168.1.3
vendor-class-identifier testVendor
option 50 ip 192.168.1.1
option 54 text server1
# Configuration file for ArubaOS
version 7.2
enable secret "******"
hostname "ArubaS1500-24P"
clock timezone EST -5
location "Building1.floor1"
controller config 2
ip access-list eth validuserethacl
permit any
netservice svc-dhcp udp 67 68
netservice svc-dns udp 53
netservice svc-ftp tcp 21
netservice svc-h323-tcp tcp 1720
netservice svc-h323-udp udp 1718 1719
netservice svc-http tcp 80
netservice svc-https tcp 443
netservice svc-icmp 1
netservice svc-kerberos udp 88
netservice svc-natt udp 4500
netservice svc-ntp udp 123
netservice svc-sip-tcp tcp 5060
netservice svc-sip-udp udp 5060
netservice svc-sips tcp 5061
netservice svc-smtp tcp 25
netservice svc-ssh tcp 22
netservice svc-telnet tcp 23
netservice svc-tftp udp 69
netservice svc-vocera udp 5002
netexthdr default
ip access-list stateless allowall-stateless
any any any permit
ip access-list stateless dhcp-acl-stateless
any any svc-dhcp permit
ip access-list stateless dns-acl-stateless
any any svc-dns permit
ip access-list stateless http-acl-stateless
any any svc-http permit
ip access-list stateless https-acl-stateless
any any svc-https permit
ip access-list stateless icmp-acl-stateless
any any svc-icmp permit
ip access-list stateless logon-control-stateless
any any svc-natt permit
ip access-list session validuser
network 169.254.0.0 255.255.0.0 any any deny
any any any permit
ipv6 alias any6 alias any6 any permit
user-role authenticated
user-role denyall
user-role guest
user-role logon
crypto ipsec transform-set default-boc-bm-transform esp-3des esp-sha-hmac
crypto ipsec transform-set default-rap-transform esp-aes256 esp-sha-hmac
crypto isakmp eap-passthrough eap-tls
crypto isakmp eap-passthrough eap-peap
crypto isakmp eap-passthrough eap-mschapv2
no firewall attack-rate cp 1024
ipv6 firewall ext-hdr-parse-len 100
firewall cp
packet-capture-defaults tcp disable udp disable sysmsg disable other disable
ip domain lookup
country US
aaa authentication mac "default"
aaa authentication dot1x "default"
aaa server-group "default"
auth-server Internal
set role condition role value-of
aaa profile "default"
aaa authentication captive-portal "default"
aaa authentication vpn "default"
aaa authentication mgmt
aaa authentication wired
web-server
aaa password-policy mgmt
traceoptions
lease 30 24 60 60
dns-server 8.8.8.8
service dhcp
qos-profile "default"
policer-profile "default"
ip-profile
interface-profile ospf-profile "default"
area 0.0.0.0
interface-profile pim-profile "default"
interface-profile igmp-profile "default"
stack-profile
ipv6-profile
interface-profile switching-profile "default"
interface-profile poe-profile "default"
interface-profile poe-profile "poe-factory-initial"
enable
interface-profile enet-link-profile "default"
interface-profile lldp-profile "default"
interface-profile lldp-profile "lldp-factory-initial"
lldp transmit
lldp receive
med enable
interface-profile mstp-profile "default"
interface-profile pvst-port-profile "default"
vlan-profile mld-snooping-profile "default"
vlan-profile igmp-snooping-profile "default"
vlan-profile igmp-snooping-profile "igmp-snooping-factory-initial"
spanning-tree
mode mstp
gvrp
mstp
lacp
vlan "1"
interface gigabitethernet "0/0/22"
interface vlan "1"
interface-group gigabitethernet "default"
apply-to ALL
snmp-server view ALL oid-tree iso included
snmp-server group ALLPRIV v1 read ALL notify ALL
snmp-server group ALLPRIV v2c read ALL notify ALL
snmp-server group ALLPRIV v3 noauth read ALL notify ALL
snmp-server group AUTHPRIV v3 priv read ALL notify ALL
snmp-server group AUTHNOPRIV v3 auth read ALL notify ALL
snmp-server enable trap
process monitor log
end
