Cloud Managed Networks
Switch renew Cisco - Aruba
  • 1.  Switch renew Cisco - Aruba
    Posted May 19, 2020 03:41 PM
    Hi, sorry for my question, i am a newbie.
    We have renewed a Stack (3x 2930f) in our Office and a single Switch (2930f) in our Branch.
    Our old switches was Cisco SG 500.
    The switches works well but the VOIP Phones in our Branch are not working.
    Can anywone translate the cisco config for me?
    config-file-header
    switch5aa59b
    v1.3.0.62 / R750_NIK_1_3_647_260
    CLI v1.0
    set system mode router queues-mode 8
    file SSD indicator encrypted
    ssd-control-start
    ssd config
    ssd file passphrase control unrestricted
    no ssd file integrity control
    ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
    no cdp run
    vlan database
    vlan 130,300
    exit
    voice vlan oui-table add 0001e3 Siemens_AG_phone________
    voice vlan oui-table add 00036b Cisco_phone_____________
    voice vlan oui-table add 00096e Avaya___________________
    voice vlan oui-table add 000fe2 H3C_Aolynk______________
    voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
    voice vlan oui-table add 00d01e Pingtel_phone___________
    voice vlan oui-table add 00e075 Polycom/Veritel_phone___
    voice vlan oui-table add 00e0bb 3Com_phone______________
    no lldp run
    bonjour interface range vlan 1
    hostname switch5aa59b
    no passwords complexity enable
    username cisco password encrypted 7af78c911d5b48bea1dc2449d9d89513abeb4be5 privi                     lege 15
    ip ssh server
    interface vlan 1
     ip address 10.11.10.101 255.255.255.0
     no ip address dhcp
    interface vlan 130
     name LKH
     ip address 10.130.60.235 255.255.255.0
    interface gigabitethernet1/1/6
     switchport trunk native vlan 130
    interface gigabitethernet1/1/9
    interface gigabitethernet1/1/10
    interface gigabitethernet1/1/14
    interface gigabitethernet1/1/20
    interface gigabitethernet1/1/25
    exit
    ip default-gateway 10.11.10.254
    switch5aa59b#
    Thanks a lot!
    Renzi
  • 2.  RE: Switch renew Cisco - Aruba
    MVP GURU
    Posted May 20, 2020 03:57 AM
    Hi Rene!
    What is the configuration of VLAN tagging on uplink/downlink involved ports? In other terms the 3xAruba 2930F (VSF stack) and the single Aruba 2930F at branch location are supposed to be connected through an uplink (single link? aggregated ports?)...how involved ports are tagged?
    Perform a show vlan port <x> detail (x could be a single physical interface if the link is a single link or it could be the logical aggregated interface if the link is made of aggregated single links as in case of Port Trunking) on both ends.
    The Cisco had VLAN 1 (Default) with SVI of Subnet 10.11.10.0/24, VLAN 130 with SVI of Subnet 10.130.60.0/24 and also a VLAN 300 (with no reference on the configuration you posted), I presume no IPv4 routing enabled (but I'm not a Cisco expert)...I say that because specifying the default gateway (sitting on the VLAN 1) generally means a simple Layer 2 approach where the routing happens elsewhere (at Core).
    On Aruba side the voice dedicated VLAN should be set as "voice" but without having a sanitized configurations of both peers it's difficult to say if there are errors/mis-configurations.
  • 3.  RE: Switch renew Cisco - Aruba
    Posted May 20, 2020 12:48 PM
    Hi Davide
    The Branch Switch have this VLAN´s
    Status and Counters - VLAN Information
    Maximum VLANs to support : 256
    Primary VLAN : DEFAULT_VLAN
    Management VLAN :
    VLAN ID Name | Status Voice Jumbo
    1 DEFAULT_VLAN | Port-based No No
    130 LKH | Port-based Yes No
    sh vlan 130
    Status and Counters - VLAN Information - VLAN 130
    VLAN ID : 130
    Status : Port-based
    Voice : Yes
    Jumbo : No
    Private VLAN : none
    Associated Primary VID : none
    Associated Secondary VIDs : none
    Port Information Mode Unknown VLAN Status
    14 Untagged Learn Up
    18 Untagged Learn Up
    24 Tagged Learn Up
    sh vlan ports 24 detail
    Status and Counters - VLAN Information - for ports 24
    VLAN ID Name | Status Voice Jumbo Mode
    1 DEFAULT_VLAN | Port-based No No Untagged
    130 LKH | Port-based Yes No Tagged
    Thanks for your Support
  • 4.  RE: Switch renew Cisco - Aruba
    MVP GURU
    Posted May 21, 2020 02:34 AM
    OK, so port 24 (used for the uplink to one of your three stacked Aruba 2930F) is:
    And VLAN 130 "LKH" is set to be a voice VLAN.
    Ports 14 and 18 are untagged in VLAN 130...but, AFAIK, ports where VoIP Terminals are connected should be configured to be tagged members of voice VLAN (have you tried?).
    If I were you I would try (example for port 18 on the Branch):
    vlan 130
    tagged 18
    exit
    vlan 1
    untagged 18
    exit
    then, as usual, check with show vlan port 18 detail command.
    So the next question is: is the above matching the VLAN settings on the corresponding peer port? If so you're OK from the VLAN tagging standpoint because core and branch are permitting the VLAN 1 to flow untagged and VLAN 130 to flow tagged.
    The only other layer to check is the Layer 3 (IP) to see if packets are routed correctly.
