Inside the interface-group subconfig, use the apply-to command and then
add, remove or just lost a group of ports. It behaves similar to a trunk
configuration so be careful when making changes. (if you want to add a port
to an existing group, make sure you use add otherwise you'll blow out the
existing ports)
