Wired Intelligent Edge
Switch security
  • 1.  Switch security
    Posted Aug 24, 2019 12:23 PM
    Bit of a mixed bag of questions here but am now looking to secure my switch infrastructure and after looking at some configurations online (and comparing on my switch) I think the configurations are out of date.
    I am using an HP-2530 (J9280A) and would like to know the command structure for the following features.
    Sticky mac: The ability to detect and fix mac addresses of devices per port.
    DHCP Snooping: enabling trust for a DHCP server (or trust of an uplink to the server) interface.
    Any other useful tips or settings which can help lock down the switch from wrong doers.
    Thanks as always.
  • 2.  RE: Switch security
    Posted Aug 24, 2019 03:43 PM
    I found this by googling "hpe arubaos-switch access security guide"  http://h20628.www2.hp.com/km-ext/kmcsdirect/emr_na-c05365163-4.pdf
    Is that what you mean?
  • 3.  RE: Switch security
    Posted Aug 24, 2019 04:18 PM
    Yes, very useful thanks. These commands match the model and firmware of my switch.
    Interestingly enough I have also found the command "aaa port-access use-lldp-data" like LLDP/LLDP-MED which is already enabled on the switch this is a single command (as seen above).
    Would this be all that is required in this case, run the command, plug in the phones and let them update the ports ?
    Also any additional "show" commands to confirm the settings would be useful also.
  • 4.  RE: Switch security
    MVP GURU
    Posted Aug 27, 2019 09:28 AM
    for VOIP, it is recommnaded to enable voice vlan (i will be auto configure LLDP)
  • 5.  RE: Switch security
    Posted Aug 27, 2019 09:44 AM
    I already used LLDP-MED with my deployments of VOICE VLAN so this should already be enabled.
    I assume then that the sticky mac feature for LLDP is an extra command/setting applied ontop of the VOICE VLAN feature.
  • 6.  RE: Switch security
    Posted Sep 03, 2019 05:03 PM
    Hi Eddie,
    I am sure this link could help you too:
    h22208.www2.hpe.com/eginfolib/Aruba/16.06/5200-5456/index.html#book.html
    Regards
