Hi, hopefully someone can advise on a switch trunking query.
I have recently purchased a number of HP switches to upgrade our infrastructure. My problem with setting up 3 trunks between my core switch model HP5406zl (J8697A), HP 24p Gig-T zl Module (J8702A) and 3 new switches which are;
x2 V910-48G (JE009A) including x2 SFP GBic (J8177c) in each switch
x1 2530-48G PoE+ (J9772A including x2 SFP GBic (J8177C) in the switch.
My original set up was the same at the core switch, but the 3 switches were 2610-48 (J9088A) with 2 connections from the core switch zl module going into the 2 Gig-T ports on each of the 3 2610s.
I have set the trunks up exactly the same as on the previous switches, but when the trunks are set up on the switch the network grinds to a halt. I cannot ping from the core switch to the 3 new switches and I cannot ping between the new switches and the core switch. When I remove the 3 Trunks all is fine and the network runs great.
I am thinking that this may be a compatibility issue, has anyone had a similar experience or can you possibly advise on what I should try to resolve the issue.
Kindest Regards
Ed
#trunkissue#trunkproblem#trunks#Trinkingissue
