switch vlan id using CoA
  • 1.  switch vlan id using CoA
    Posted Sep 18, 2018 04:45 AM
    Does aruba controller support switching vlan using CoA after authenticated?
    I have aruba 3600 and AP configured vlan id(1, 40, 50,...).
    When client phone connect to the AP,  my radius server accept the client with bellow attributes.
    Tunnel-Type = VLAN
    Tunnel-Medium-Type = IEEE-802
    Tunnel-Private-Group-Id = 40
    After authentication i checked vlan id
    (Aruba-master) # show ap association.
    It showed vland id 40.
    I sent CoA request to the controller to switch vlan id 50 with following attributes. I am not using clearpass or others..., just my application send CoA request to the controller.
    Tunnel-Type = VLAN
    Tunnel-Private-Group-Id = 50
    Then the controller replied CoA-ACK. It seems there was no problem.
    but when i check vlan id again with cli (Aruba-master) # show ap association).
    vlan id is same 40.
    I tried sending  vendor specific attributes like
    Aruba-User-Vlan
    Aruba-Port-Bounce-Host
    Aruba-User-Role
    Aruba 3600 controller replies CoA ACK but vlan id doesnt have new vlan id.
    does anyone know why?
    I don't have much network knowledge but if someone wants more information with my issue. i can describe more detail.
  • 2.  RE: switch vlan id using CoA
  • 3.  RE: switch vlan id using CoA
    Posted Sep 18, 2018 05:08 AM
    Thank you for the fast answer.
    I read the thread before i post my issue.
    Actually, i don't understand the answer by Shyam_Moolayilkalarikkal.
  • 4.  RE: switch vlan id using CoA
    Posted Sep 18, 2018 08:10 AM
    When you do not see the vlan change in the session, please verify your radius setup.
    Are you using clearpass? Does clearpass send the correct vlan?
  • 5.  RE: switch vlan id using CoA
    Posted Sep 18, 2018 08:20 AM
    Did you configure an RFC 3576 profile on the Controller?   It is required for a COA. If you did, you should probably do a user debug and see what is going on with that client when you send the command.
  • 6.  RE: switch vlan id using CoA
    Posted Sep 18, 2018 08:29 AM
    You need to use a Disconnect, not a CoA when changing VLANs.
  • 7.  RE: switch vlan id using CoA
    Posted Sep 19, 2018 12:44 AM
    I tried Disconnect request it worked correctly.
    But I think CoA is more elegant way that client user can not notice what is going on back size. Because when i send disconnect, client android phone lose wifi connection then reconnect and android phone shows current wifi status using short message box on screen. and another reason is sometimes the phone tries to connect another wifi(not my ap).
    That is why i want to use Coa.
    Do you have any idea?
  • 8.  RE: switch vlan id using CoA
    Posted Sep 19, 2018 03:09 AM
    if you just change VLAN, the client will not notice this. Because of this, client will not perform DHCP refresh. That's why manually refreshing/renewing IP address works.
    If you disconnect, client will notice this. But getting kicked out has some disadvantages. Thats why I try to omit VLAN changes.
    Webauth on Aruba/Procurve switches uses a short DHCP lease time to circumvent this. But even with lease time of 5 minutes your clients have to wait a little, till IP gets refreshed...
    Maybe instead of changing VLAN you can reach same level of security by using two different user-roles with different ACLs?
    Regards, Jörg
  • 9.  RE: switch vlan id using CoA
    Posted Sep 19, 2018 04:34 AM
    Thanks everyone.
  • 10.  RE: switch vlan id using CoA
    Posted Sep 19, 2018 01:38 AM
    I had configuried already RFC 3576 Server. It is working well with Disconnect request. and in log message, there was no error about CoA or radius.
    anyway thank you for your advice.
