Syntax error spotted on Controller
  • 1.  Syntax error spotted on Controller
    Posted Jan 05, 2015 12:55 AM
    While check the system health, we spotted following error message on the debug log, is this something normal?
    Jan 5 12:10:43 :307072:  <DBUG> |cfgm|  Current Version is 6.4
    Jan 5 12:10:43 :307144:  <DBUG> |cfgm|  Request for configuration for 0
    Jan 5 12:10:43 :307146:  <DBUG> |cfgm| Parsing the Configuration file to get Snapshot data
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#9::ip NAT pool dynamic-srcnat 0.0.0.0 0.0.0.0
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#17::netexthdr default
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#28::  network 127.0.0.0 255.0.0.0 any any  deny
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#29::  network 169.254.0.0 255.255.0.0 any any  deny
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#30::  network 224.0.0.0 240.0.0.0 any any  deny
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#31::  host 255.255.255.255 any any  deny
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#32::  network 240.0.0.0 240.0.0.0 any any  deny
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#33::  any any any  permit
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#34::  ipv6 host fe80:: any any  deny
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#35::  ipv6 network fc00::/7 any any  permit
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#36::  ipv6 network fe80::/64 any any  permit
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#37::  ipv6  alias ipv6-reserved-range any any  deny
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#38::  ipv6  any any any  permit
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#44::dot1x low-watermark 80
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#45::user-role ap-role
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#47::user-role stateful-dot1x
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#51::user-role guest-logon
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#53::user-role logon
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#55::user-role guest
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#263::  hash sha2-256-128
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#264::  group 19
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#265::  authentication ecdsa-256
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#266::  prf prf-hmac-sha256
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#272::  hash sha2-384-192
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#273::  group 20
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#274::  authentication ecdsa-384
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#275::  prf prf-hmac-sha384
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#286::crypto map GLOBAL-IKEV2-MAP 10000 ipsec-isakmp dynamic default-rap-ipsecmap
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#456::firewall enable ICE-STUN based firewall traversal
    Jan 5 12:10:43 :399821:  <DBUG> |cfgm|  Syntax error processing line#1011::remote-node config-id 1
    Jan 5 12:10:43 :307147:  <DBUG> |cfgm| Done Parsing the Configuration file
    Jan 5 12:10:43 :307374:  <DBUG> |cfgm|  Size of configuration data is 18776
    Is this something normal?
    regards,
    Wilson
  • 2.  RE: Syntax error spotted on Controller
    Posted Jan 05, 2015 01:10 AM
    You should open a TAC case.  It may or may not be an issue.
