Syntax for Cisco 3000 and ClearPass POC install
  • 1.  Syntax for Cisco 3000 and ClearPass POC install
    Posted Feb 27, 2015 04:56 PM
    Hello, based on your documentations, the configurations below will only work for Cisco 3750 devices and up with IOS 12.2(55) SE7 and above.   Most of our Cisco switches in the remote sites are 3560 layer 3’s.  Only our Data Centers will have Cisco 4500’s and 3750’s.   So the lower-end switches 3000’s and below are not supported by Clearpass?   So what happens with systems that are plugged into the Cisco 3000’s and below?
    authentication order dot1x mab
    authentication priority dot1x mab
    authentication port-control auto
    authentication periodic
    authentication timer reauthenticate server
    mab
    dot1x pae authenticator
    dot1x timeout server-timeout 30
    dot1x timeout tx-period 10
    dot1x max-req 3
    dot1x max-reauth-req 3
    If you have the correct sytax for above it would be greatly apprecated.
    Tahnks,
  • 2.  RE: Syntax for Cisco 3000 and ClearPass POC install
    Posted Feb 27, 2015 05:01 PM
    Sorry part of my message didnt come up, there was a POC being set up for a customer and they sent the response I posed back to me.
  • 3.  RE: Syntax for Cisco 3000 and ClearPass POC install
    Posted Feb 27, 2015 10:21 PM
    As far as cisco goes Its usually the same as CISCO ISE. Clearrpass is a huge database, radius server, we server. It will do whatever your device is capable of. You always have the option of running aruba controller in-line and using PEF licence to control traffic.
    We do NAC on 2960cg, 2960X, 3560, 3750. We got rid of 2940 and 3550 because of our environment but they would work if the network is not too complex.
  • 4.  RE: Syntax for Cisco 3000 and ClearPass POC install
    Posted Mar 02, 2015 01:40 PM
    Thanks for the reply. Do you know where I can get the Syntax for the customerso they can install it with their existing switchs? the POC documentation only has it for the higher Cisco switches.
  • 5.  RE: Syntax for Cisco 3000 and ClearPass POC install
    Posted Mar 03, 2015 09:55 PM
    Just look at cisco ISE. Most feature are supported with hardware that is not end-of-support. All hardware that's not end of life you should be okay. You need to read the notes on your hardware. Clearrpass is open standards. It will handle radius. So whatever your devices supports it will do.
