Wired Intelligent Edge
Syslog and Logging - Aruba 8325 to Syslog server
  • 1.  Syslog and Logging - Aruba 8325 to Syslog server
    Posted Feb 28, 2024 12:28 PM
    Hi there we are using Solarwinds to view logging and sflow data from our Aruba 8325 cores but it is not showing up in Solarwinds. However all other switches (Aruba 6300M) are. Any idea what the issue could be? Thanks
    sflow
    sflow collector 172.18.3.66 port 2055
    sflow agent-ip 172.27.1.253
    logging 172.18.1.4
    logging 172.18.3.66
    logging 172.18.3.69
    logging facility local2
  • 2.  RE: Syslog and Logging - Aruba 8325 to Syslog server
    Posted Feb 28, 2024 12:46 PM
    Without any knowledge of your network:
    Would your environment require you to specifically configure Syslog to a particular VRF and then also to a particular interface?
    If my post was useful, please Accept Solution and Give Kudos.
    Zak Chalupka
    Principal Engineer - HPE Aruba
    ACDX | ACMP | ACSP | ACCP
    wifizak@hpe.com
    Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
  • 3.  RE: Syslog and Logging - Aruba 8325 to Syslog server
    Posted Feb 28, 2024 12:52 PM
    Hi there
     I'm just trying to get the syslogs and logging information to the syslog server. Is there a guide or anything I need to follow?
  • 4.  RE: Syslog and Logging - Aruba 8325 to Syslog server
    Posted Feb 28, 2024 01:05 PM
    There are two components to my original thoughts here:
    Look through below document. Specifically the "Remote syslog commands" and the VRF parameter.
    https://www.arubanetworks.com/techdocs/AOS-CX/10.10/PDF/diagnostics_83xx-10000.pdf
    Also for the source interface, look for the "ip source-interface" command set
    https://www.arubanetworks.com/techdocs/AOS-CX/10.07/PDF/5200-7838.pdf
    Zak Chalupka
    wifizak@hpe.com
  • 5.  RE: Syslog and Logging - Aruba 8325 to Syslog server
    Posted Feb 28, 2024 01:33 PM
    Thanks so much Zak.
