Syslog date format
  • 1.  Syslog date format
    Posted Dec 16, 2013 01:15 PM
    Standard Syslog messages should NOT include the year in the first few fields of a syslog entry.  Prior to our upgrade to v.6.1 syslog entries looked like this (emphasis added):
    Jan 15 14:11:04 2009 [10.1.10.10] sapd[215]: <326091> <NOTI> |AP 1.3.4@10.1.30.98 sapd|  AM: Radio Stats: APs=2 STAs=0 Mon-APs=6 Mon-STAs=2
    Jan 15 14:11:05 2009 [10.1.10.10] wms[521]: <316094> <WARN> |wms|  Could not create entry for station 00:1f:e1:1e:ee:cb
    Jan 15 14:11:05 2009 [10.1.10.10] wms[521]: <316094> <WARN> |wms|  Could not create entry for station 00:18:de:b2:f7:34
    Mar  2 09:10:56 2011 [10.1.253.5] authmgr[598]: <522008> <NOTI> |authmgr|  User authenticated: Name=jsmith MAC=c8:bc:c8:29:59:aa IP=100.100.160.249 method=802.1x server=iFolder role=pre-employee
    After upgrading to 6.1, the format changed to the correct format (no year)
    Nov 14 10:06:56 10.1.143.233 sapd[918]: <404074> <WARN> <10.1.253.5 10.1.253.5>  AM 00:24:6c:b0:6c:20: ARM - increasing power cov-index 6/1 tx-power 6 new_rra 6/7
    Nov 14 10:08:41 Sandy3600 localdb[1569]: <133019> <ERRS> <Sandy3600 10.1.253.5>  User 40:6a:ab:1c:9d:77 was not found in the database
    Nov 14 10:08:41 Sandy3600 localdb[1569]: <133006> <ERRS> <Sandy3600 10.1.253.5>  User 40:6a:ab:1c:9d:77 Failed Authentication
    Now after upgrading to 6.2, the year is back in the messages.
    Dec 12 09:06:34 2013 Sandy3600 localdb[1764]: <133006> <ERRS> <Sandy3600 10.15.253.45>  User 60:fb:42:3c:18:66 Failed Authentication
    Anyone have any idea how to disable the year being included in syslog messages? or why they might have reappeared with the 6.2 upgrade?  The year field really messes up our syslog server.
  • 2.  RE: Syslog date format
    Posted Dec 17, 2013 04:30 AM
    I'm happy to be challenged on this, but this is my understanding...
    RFC 5424 requires the year.
    RFC 3164 (obsolete) doesn't require the year.
    So, whether or not it's in there depends what RFC the developer was following.
    I don't believe the ability to format or follow as specific variant of RFC (by way of config) exists.
    Having said that, doesn't upgrading to 6.2 resolve your issue (which I assume is to do with the syslog server parsing for information/alerting) based on what you've said?
  • 3.  RE: Syslog date format
    Posted Aug 07, 2014 04:27 PM
    What you state is not completly true.
    It is correct that RFC 5424 obsoletes RFC 3164 but this also changes a lot of other things.
    When you create a syslog server that follows RFC 5424 you have the option to follow one of the 4 following formats for the timestamp field in the message:
    1985-04-12T23:20:50.52Z
    1985-04-12T19:20:50.52-04:00
    2003-10-11T22:14:15.003Z
    2003-08-24T05:14:15.000003-07:00
    When you stick with RFC 3164 the timestamp and following hostname format is very specific defined and doesn't leave any options open. The format MUST me:
    Aug  7 17:45:30 hostname
    The Aruba controller now does the following and this is very wrong:
    Aug  7 17:45:30 2014 hostname
    This is as far as I understand it so far after reading both RFC's.
    Jan Hugo Prins
  • 4.  RE: Syslog date format
    Posted Aug 07, 2014 06:48 PM
    The end result of this is that anyone scratching their head looking for their controller syslogs who is running rsyslog and putting their logs in files based on the hostname should look for files called "2014.*".
    There's no super-easy way to fix rsyslog for this nonstandard format.  You either have to build your own from source or play crazy games with variable reassignments.
  • 5.  RE: Syslog date format
    Posted Apr 28, 2016 08:57 PM
    I've run into this same issue. The fact that the year is included in the syslog message in its current format messes with the way the syslog server parses the messages.
    What's odd is if you look at the messages locally using show log user-debug, for example, the output is here does not include the year and is what I would expect the syslog message to be.
    Does anyone have a fix for this issue?
  • 6.  RE: Syslog date format
    Posted Jul 25, 2017 11:59 PM
    Managed to find a workaround for this.
    We recently changed our syslog server to Elastic Stack.  The stack includes Logstash which ingests the syslog data and has powerful grok/regex filters.  Here's the filter I came up with to workaround this issue:
    filter {
    if [type] == "syslog" {
    grok {
    match => { "message" => "(?:%{SYSLOGTIMESTAMP:syslog_timestamp}|%{TIMESTAMP_ISO8601:syslog_timestamp})(?: %{YEAR:aruba_erroneous_year})? %{SYSLOGHOST:syslog_hostname} %{DATA:syslog_program}(?:\/%{DATA:container_name}\/%{DATA:container_id})?(?:\[%{POSINT:syslog_pid}\])?: %{GREEDYDATA:syslog_message}" }
    remove_field => ["message", "aruba_erroneous_year"]
    add_field => [ "received_at", "%{@timestamp}" ]
    add_field => [ "received_from", "%{host}" ]
    syslog_pri { }
    date {
    match => [ "syslog_timestamp", "MMM d HH:mm:ss", "MMM dd HH:mm:ss", "ISO8601" ]
    dns {
    reverse => [ "host", "syslog_hostname" ]
    action => "replace"
    If it finds an erroneous year after the timestamp, it puts it in a field called aruba_erroneous_year and then promptly removes the field.  Prior to this, the year was ending up in the syslog_hostname field.
    Seems crazy, some may say arrogant, that Aruba chooses not to comply with RFC 3164 or its replacement, RFC 5424.
    EDIT: Updated the filter to make one of the surrounding spaces around the erroneous year optional too, otherwise it wouldn't match on correctly-formatted syslog messages that didn't include the year :$
    Also added support for ISO8601 date formats.
  • 7.  RE: Syslog date format
    Posted Jan 22, 2018 05:43 AM
    After lots of trial and errors, i've ended up with this solution (Ubuntu 16.04, packaged rsyslog 8.16):
    rsyslog.conf
    $template remove_year,"%TIMESTAMP% %rawmsg:R,ERE,1,FIELD:[0-9]{4} (.*)--end%
    " :rawmsg, ereregex, ".{3} [0-9][0-9] [0-9][0-9]:[0-9][0-9]:[0-9][0-9] [0-9][0-9][0-9][0-9] " /var/log/syslog;remove_year & stop *.* /var/log/syslog;RSYSLOG_TraditionalFileFormat & stop
    $ActionFileDefaultTemplate RSYSLOG_TraditionalFileFormat ############
    I'm not a regexp guru ;)
  • 8.  RE: Syslog date format
    Posted Jan 23, 2018 08:35 PM
    you can also just revert to rfc 3164 format if you so choose (aos 6.4 perhaps and up)
    (7005) (config) #logging 1.2.3.4 ?
    bsd-standard BSD standard format (RFC 3164)
  • 9.  RE: Syslog date format
    Posted Jan 24, 2018 05:48 PM
    @dugem2016, that's good to know. Unfortunately there doesn't appear to be an equivalent setting for IAPs running 6.5.
