Syslog Export Filter and Custom SQL
  • 1.  Syslog Export Filter and Custom SQL
    Posted Aug 07, 2018 03:18 PM
    I'm looking for a way to create SQL for a syslog export filter that will send the serial number of a valid TLS authentication to Clearpass. The serial number is present in the computed attributes of Access Tracker, so I'm hoping I can find the correct SQL syntax to fetch that same serial number and send it as part of an external syslog.
    I browsed the various tips databases, tables and views but wasn't able to find anything related to the parsed certificate information.
    Thanks!
  • 2.  RE: Syslog Export Filter and Custom SQL
    Posted Aug 07, 2018 03:20 PM
    The serial number of the certificate?
  • 3.  RE: Syslog Export Filter and Custom SQL
    Posted Aug 07, 2018 03:24 PM
    Correct - Certificate:Serial-Number.
  • 4.  RE: Syslog Export Filter and Custom SQL
    Posted Aug 08, 2018 11:05 AM
    I spent a decent amount of time browsing the various CPPM databases to no avail, but given their breadth I'm not sure I'm even looking in the right place!
  • 5.  RE: Syslog Export Filter and Custom SQL
    Posted Aug 08, 2018 01:20 PM
    Progress - I found SQL that returns the data I'm after (MAC, username, timestamp and certificate serial (without colons) - see below). However, placing this query in the export filter doesn't appear to work - I see no data in the logs now. On top of that, when I select a Data Filter and save the export filter, it doesn't save the changes. Not sure what I'm missing now.
    SELECT t1.user_name as userName, t1.host_mac as macAddress, REPLACE(attr_value,':','') AS certSerial, t1.timestamp as timeStamp FROM tips_session_log_details t2 JOIN tips_dashboard_summary t1 ON t2.session_id = t1.id WHERE t2.attr_name = 'Certificate:Serial-Number' AND t1.host_mac = '%{Connection:Client-Mac-Address}' ORDER BY t1.timestamp DESC LIMIT 1
