Syslog format Aruba instant
  • 1.  Syslog format Aruba instant
    Posted Dec 01, 2014 03:19 AM
    I have a question regarding the syslog format which the Aruba instant OS sends. Below a sample:
    11-28-2014 09:18:46 Local1.Notice 10.54.1.33 Nov 28 08:18:45 2014 10.54.1.33 stm[1515]: <501199> <NOTI> <10.54.1.33 24:DE:C6:C4:EE:72>  User authenticated, mac-34:e2:fd:65:83:74, username-jbrouwer@pj.nl, IP-10.244.0.14, method-4, role-Educatie
    Is it possible to change the format so the , sign can be removed from the log? I am trying to configure a Palo Alto user ID agent as a sysloglistener for user to IP mapping but it sees the IP format with the , behind the IP as an invalid IP address.
    Joost Brouwer
  • 2.  RE: Syslog format Aruba instant
    Posted Dec 01, 2014 04:01 AM
    Joost,
    Please look at the article here:  http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/Services/panFirewallInt.htm and let us know if that is the integration you need.
    I am not sure that the comma can be removed from the syslog output.
  • 3.  RE: Syslog format Aruba instant
    Posted Dec 02, 2014 05:18 AM
    Hello Colin,
    Thanx for your reply. That is an option I have tried. I can see in the system log that the IAP log's in to the Palo Alto FW but I dont see any user to IP mappings in the traffic log.
  • 4.  RE: Syslog format Aruba instant
    Posted Dec 02, 2014 06:32 AM
    jstbrouwer,
    What version of the Palo Alto software and what version of Aruba Instant are you running?  If it does not work, we need to engage TAC.
  • 5.  RE: Syslog format Aruba instant
    Posted Dec 02, 2014 06:51 AM
    Hi Colin,
    InstantOS: 6.4.2.0-4.1.1.0_46028
    PANOS: 6.0.6
  • 6.  RE: Syslog format Aruba instant
    Posted Dec 02, 2014 06:59 AM
    Do you have User-ID enabled?
  • 7.  RE: Syslog format Aruba instant
    Posted Dec 02, 2014 07:04 AM
    No I don't have User-ID enabled because there is no option for InstantOS in the syslogsender option. How should I configure User-ID otherwise? thanks in advance
  • 8.  RE: Syslog format Aruba instant
    Posted Dec 02, 2014 07:05 AM
    In the Palo
  • 9.  RE: Syslog format Aruba instant
    Posted Dec 02, 2014 07:00 AM
    jstbrouwer,
    Do your users login with just "username" or "domain\username"?
  • 10.  RE: Syslog format Aruba instant
    Users login with username@domain.nl using Radius.
  • 11.  RE: Syslog format Aruba instant
    Posted Dec 02, 2014 07:20 AM
    jstbrouwer,
    Please see if the usernames are being sent by using the "show ap debug pan-sent" command on the Instant commandline to see if any username information is being sent...
  • 12.  RE: Syslog format Aruba instant
    Posted Dec 02, 2014 08:22 AM
    Hello Colin,
    The user-id's are sent. To test I changed the login of my personal device to the domain\username format. Now I get the user to IP mapping in the trafic log. Any idea if the format user@domain is supported?
  • 13.  RE: Syslog format Aruba instant
    Posted Dec 02, 2014 08:29 AM
    jstbrouwer,
    I think that is a restriction of Pan OS.  If you don’t send the DOMAIN prefix then the PAN can’t make the policy enforcement you require based up on the AD group membership.
