Syslog warning: Send awc hang detection/Recv awc hang reply
  • 1.  Syslog warning: Send awc hang detection/Recv awc hang reply
    Posted May 11, 2018 04:52 AM
    I have an instant cluster with two IAP-205H, one is mesh portal and one is mesh point. Each of them send 2 syslog messages every 5 minutes, that i have not been able to find any explanation to:
     cli[2921]: <341004> <WARN> <192.168.100.27 20:4C:03:0E:4A:90>  Send awc hang detection.
    cli[2921]: <341004> <WARN> <192.168.100.27 20:4C:03:0E:4A:90>  Recv awc hang reply.
    What is happening?
  • 2.  RE: Syslog warning: Send awc hang detection/Recv awc hang reply
    Posted May 17, 2018 12:32 PM
    What IAP version are you running on the 205Hs? What IAP models make up the rest of the cluster?
  • 3.  RE: Syslog warning: Send awc hang detection/Recv awc hang reply
    Posted May 18, 2018 03:11 AM
    Hi Ole,
    The above message is seny by CLI to detect the state of AWC process on the IAP.
    As we are seeing awc reply message, that means awc process is running fine on the IAP.
     We don't have a way to stop these messages.
