Syslog with ClearPass
  • 1.  Syslog with ClearPass
    Posted Sep 11, 2017 11:05 AM
    Hi All
    I've been testing Clearpass for use with eduroam and am just setting up the logging to our Syslog server. I have created a new Data Filter that looks for ( Common:Service CONTAINS eduroam ), and the logging is working for Accepts and Rejects. During my testing I took too long to login and received a TIMEOUT in Access Tracker, however this was not logged to Syslog. Does anyone know why Timeouts are not logged to Syslog.
    Clearpass Version is 6.5.7
    Dave
  • 2.  RE: Syslog with ClearPass
    Posted Sep 11, 2017 11:07 AM
    Is that the only rule in the data filter?
    When you apply the same data filter in Access Tracker, are the timeouts also not visible?
  • 3.  RE: Syslog with ClearPass
    Posted Sep 11, 2017 11:13 AM
    Hi Tim
    Yep, that is the only rule in the data filter.
    When I apply the filter to access tracker I can see the timeouts but I can't see them in Syslog, I can see every other request for that service but not the timeouts.
    Dave
  • 4.  RE: Syslog with ClearPass
    Posted Sep 11, 2017 11:22 AM
    If you’re seeing them in AT, you should be seeing them via Syslog. Please open a TAC case.
  • 5.  RE: Syslog with ClearPass
