syslogs send a different interface vlan on controller ?
  • 1.  syslogs send a different interface vlan on controller ?
    Posted Jan 24, 2017 03:49 AM
    hi all
    in deployment there is a controller 650 and running version 6.4.x.
    we are sending "auth. success logs" to palo alto firewall for User-Ip Mapping.
    we want  to send different syslogs  from different interface vlan . Is it possible.?
    thanks for your replies !!
  • 2.  RE: syslogs send a different interface vlan on controller ?
    Posted Jan 24, 2017 04:34 AM
    Are you wanting to send logs to the same location via 2 different routes?
    If so, this isn't possible.
  • 3.  RE: syslogs send a different interface vlan on controller ?
    Posted Jan 24, 2017 05:05 AM
    Yes james. i needed it.
    Well, is it possible sending different location via different routes ?
    thanks
  • 4.  RE: syslogs send a different interface vlan on controller ?
    Posted Jan 24, 2017 05:14 AM
    It certainly is possible to send to different locations via different routes. You just need to configure a static route to the different location.
    CLI
    (Aruba7010) (config) #ip route <dest> <desmask> <nexthop> <cost>
    CLI Example:
    (Aruba7010) (config) #ip route 10.10.10.99 255.255.255.255 11.11.11.200 1
    GUI Example
