system doesn't exist when licensing AP
  • 1.  system doesn't exist when licensing AP
    Posted Jan 28, 2015 07:46 AM
    We have purchased 1 controller 7xxx and a few AP 205. today when I tried to licensing the controller and APs, found that there is no certificate-ID with the controller , and also when tried to activate the AP certificate , the licsensing system displayed " system doesn't exist" .   the controller is pre-installed license?  Why the licensing system still display " system does not exist" after I key-in the certificate-ID and serial no. of the AP.. the numbers I keyed in are confirmed correct.  Please advise . Thanks a lot in advance.
  • 2.  RE: system doesn't exist when licensing AP
    Posted Jan 28, 2015 07:51 AM
    Either:
    1.  The controller serial number does not exist in the database - Contact TAC
    or
    2.  You put in the serial number wrong - Contact TAC
  • 3.  RE: system doesn't exist when licensing AP
    Posted Jan 28, 2015 08:11 AM
    thanks for your reply.  All new controllers  should be shipped with the certificate-ID ,right?
  • 4.  RE: system doesn't exist when licensing AP
    Posted Jan 28, 2015 08:14 AM
    BTW: certificate-ID (Is pre-key) need to be activated on the Aruba license site.
  • 5.  RE: system doesn't exist when licensing AP
    Posted Jan 28, 2015 08:23 AM
    Thanks for reply.  I will check with the distributor about the certificate-ID of new controller
  • 6.  RE: system doesn't exist when licensing AP
    Posted Jan 28, 2015 08:13 AM
    Be Sure to take down the right S/N of your controller (From the licenese tab)
    if you enter a wrong S/N , you may change the S/N in the Aruba licenese site. (RMA process)
    *If you still got issues - please contact TAC*
